  3. MySensors.h erreur de compilation
7 Posts 2 Posters 2.5k Views 2 Watching
  • Nicolas PhilippartN
    Nicolas PhilippartN
    Nicolas Philippart
    wrote on last edited by Nicolas Philippart
    I am trying to make a mysensor gateway with a NodeMcu esp8266 ch340g v3.
    But when I compile the code:
    #define MY_BAUD_RATE 115200 // 9600
    //#define MY_RADIO_NRF24
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_ESP8266
    #define MY_WIFI_SSID monreseau
    #define MY_WIFI_PASSWORD 12345678
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
    //#define MY_HOSTNAME "sensor-gateway"
    #define MY_PORT 5003
    // Enable inclusion mode
    //#define MY_INCLUSION_MODE_BUTTON_PIN D1
    // Set blinking period
    //#define MY_DEFAULT_LED_BLINK_PERIOD 300
    // Flash leds on rx/tx/err
    // Led pins used if blinking feature is enabled above
    #if defined(MY_USE_UDP)
    #include <WiFiUdp.h>
    #include <ESP8266WiFi.h>
    [/code]
    Here is the error I have when I compile:
    Arduino : 1.8.5 (Windows 10), Carte : "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, 4M (1M SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
    GatewayESP8266:67: error: 'monreseau' was not declared in this scope
    C:\Users\Nico_raptor\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:163:19: note: in expansion of macro 'MY_WIFI_SSID'
      (void)WiFi.begin(MY_WIFI_SSID, MY_WIFI_PASSWORD, 0, MY_WIFI_BSSID);
    In file included from C:\Users\Nico_raptor\Documents\Arduino\libraries\MySensors/MySensors.h:420:0,
                     from C:\Users\Nico_raptor\Documents\Arduino\GatewayESP8266\GatewayESP8266.ino:118:
    C:\Users\Nico_raptor\Documents\Arduino\libraries\MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp: At global scope:
    C:\Users\Nico_raptor\Documents\Arduino\libraries\MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp:57:53: error: declaration of C function 'void ets_update_cpu_frequency(int)' conflicts with
     extern "C" void ets_update_cpu_frequency(int freqmhz);
    In file included from C:\Users\Nico_raptor\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/pgmspace.h:10:0,
                     from C:\Users\Nico_raptor\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Arduino.h:256,
                     from C:\Users\NICO_R~1\AppData\Local\Temp\arduino_build_50513\sketch\GatewayESP8266.ino.cpp:1:
    C:\Users\Nico_raptor\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2/tools/sdk/include/ets_sys.h:218:6: error: previous declaration 'void ets_update_cpu_frequency(uint32_t)' here
     void ets_update_cpu_frequency(uint32_t ticks_per_us);
    Utilisation de la bibliothèque ESP8266WiFi version 1.0 dans le dossier: C:\Users\Nico_raptor\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi
    Utilisation de la bibliothèque MySensors version 2.3.0 dans le dossier: C:\Users\Nico_raptor\Documents\Arduino\libraries\MySensors
    Utilisation de la bibliothèque EEPROM version 1.0 dans le dossier: C:\Users\Nico_raptor\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\EEPROM
    exit status 1
    And when I do not include the Mysensor library
    //#include <MySensors.h>
    Successful compilition
    Ps: I tried this code:
    http://henrysbench.capnfatz.com/henrys-bench/arduino-projects-tips-and-more/arduino-esp8266-lolin-nodemcu-getting-started/
    and it works very well
    Would there be a problem with the MySensors.h library ???
    PS: I am new in andruino
    • Nicolas PhilippartN Nicolas Philippart
      [/code]
      exit status 1
      Hi @nicolas-philippart, welcome to the MySensors forum!
      Please post questions in English. You are welcome to use google translate if you like, things don't need to be perfect :)
      To fix the error, change
      To
      #define MY_WIFI_SSID "monreseau"
        Nicolas PhilippartN
        Nicolas Philippart
        Sorry, auto translator.
        with this code:
        #define MY_WIFI_SSID "reseau_raptor_2"
        #define MY_WIFI_PASSWORD "12345678"
        ** I have a compilation error: **
        exit status 1
        Erreur de compilation pour la carte NodeMCU 1.0 (ESP-12E Module)
          Nicolas PhilippartN
          Nicolas Philippart
          ps: I noticed that the line of code
          #include <ESP8266WiFi.h> // dans cette ligne esp8266wifi est en rouge
          #include <MySensors.h> // dans cette ligne MySensors apparait en noir
          As if he did not find the library
            @nicolas-philippart see solution in https://forum.mysensors.org/topic/9558/error-compiling-gateway-for-esp8266-node-mcu-1-0-e12
              Nicolas PhilippartN
              Nicolas Philippart
              thank you very much for the information
              I look, I try and I keep you informed
                Nicolas PhilippartN
                Nicolas Philippart
                with the successful map version 2.4.1, compilation and upload :-) :-)
                I open the console serie, nothing is displayed. So I check on my router ...
                Nickel connection is established
                I will search the forum to try to have the serial console and to combine the gateway with other sensor, etc.
                And later, try to code ... there is really a way to do a lot of home automation with this little chip
                Thanks again ;-)
