  3. IR & Timer
IR & Timer
5 Posts 2 Posters 1.1k Views 2 Watching
    please help:
    I want to press IR button to start the timer of a project. Let the project start working for 1 hour then stop. But the program I write below can not do what I want it to do . I press the IR button but the timer do nothig. Is there something wrong?
    unsigned long HR;
      unsigned long MILLIS;
      const long timingH1 = 5000;
      const byte  sw = 13;
      #include <IRremote.h>
      const byte RECV_PIN = 3;
      IRrecv irrecv(RECV_PIN);
      decode_results results;
    void setup(){
      HR = millis();
      irrecv.enableIRIn();
      pinMode(sw,OUTPUT);
      pinMode(sw,HIGH);
      digitalWrite(sw,LOW);
      Serial.begin(9600);
       if (irrecv.decode(&results)) {
            if (results.value == 16724175){
                 MILLIS = millis();
                  Serial.print("HR:");
                   Serial.println(HR);
                    Serial.print("MILLIS:");
                     Serial.println(MILLIS);
                   if (MILLIS - HR  >= timingH1){
                       HR = MILLIS;
                        digitalWrite(sw,HIGH);
           irrecv.resume();
    • 3 31597
      please help:
      unsigned long HR;
        const byte  sw = 13;
      void setup(){
        HR = millis();
        pinMode(sw,OUTPUT);
        pinMode(sw,HIGH);
        Serial.begin(9600);
                   MILLIS = millis();
                     Serial.println(HR);
                         HR = MILLIS;
             irrecv.resume();
      Welcome to the MySensors community @31597
      How about using the sleep function to sleep for one hour?
        I want to use IR remote to start the timer. Let the device work for 1 hour. After 1 hour, the device stop working. My question is that by using button program , my timer can work but using IR remote program, my timer wont work.
        Please help, I try so many times, but just cant figure it out.
        • 3 31597
          @31597 could you explain what work the device should do during 1 hour?
            It's a air cleaner. I want to put a timer inside. The timer has four choices:1,2,3,4 hours to choose from. The problem I face is that I can't use IR remote to start the timer. Thanks for asking.
