  3. ESP8266 to act as a gateway between two PCs to transfer the data
2 Posts 2 Posters 1.4k Views 2 Watching
  • K
    K
    kishor
    I am new to arduino and to ESP module, my task is to make ESP8266 to act as Gateway for the communication between two devices. so when I transfer a data, it need to be transferred through the gateway to the other PC. I installed arduino and installed Mysensors library in it.I am using esp8266 gateway example, while compiling it is showing the error
    Arduino: 1.8.7 (Windows 10), Board: "Generic ESP8266 Module, 80 MHz, Flash, ck, 26 MHz, 40MHz, QIO, 512K (no SPIFFS), 2, v2 Lower Memory, Disabled, None, Only Sketch, 9600"
    Build options changed, rebuilding all
    In file included from C:\Users\kishor.babu\Documents\Arduino\libraries\MySensors/MySensors.h:420:0,
                     from C:\Users\kishor.babu\Documents\Arduino\libraries\MySensors\examples\GatewayESP8266\GatewayESP8266.ino:118:
    C:\Users\kishor.babu\Documents\Arduino\libraries\MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp:57:53: error: declaration of C function 'void ets_update_cpu_frequency(int)' conflicts with
     extern "C" void ets_update_cpu_frequency(int freqmhz);
    In file included from C:\Users\kishor.babu\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/pgmspace.h:10:0,
                     from C:\Users\kishor.babu\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Arduino.h:256,
                     from sketch\GatewayESP8266.ino.cpp:1:
    C:\Users\kishor.babu\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2/tools/sdk/include/ets_sys.h:218:6: error: previous declaration 'void ets_update_cpu_frequency(uint32_t)' here
     void ets_update_cpu_frequency(uint32_t ticks_per_us);
    exit status 1
    Error compiling for board Generic ESP8266 Module.
    option enabled in File -> Preferences.
    • K kishor
      exit status 1
      Hi @kishor, welcome to the forum!
      These threads might be of interest:
      https://forum.mysensors.org/post/92175
      https://forum.mysensors.org/post/93564
      https://forum.mysensors.org/post/93113
      https://forum.mysensors.org/post/90990
      https://forum.mysensors.org/post/92610
