  3. Vera
  4. Multisensor with Relay control
2 Posts 2 Posters 2.6k Views 2 Watching
  • A Offline
    A Offline
    antcas2000
    I had build a multi sensor with temp,humidity, Door sensor and Relay for my garage door. I am using a Nano board. Connecting the Vera creates all sensors, but when i am using the button swich to swich the Relay, from the serial terminal i can see that this command is not received from the sensors node. I try several things without any success. Please check my code:
    Thanks in Advance.
    #include <NewPing.h>
    #include <Bounce2.h>
    #include <DHT.h>
    //Relay
    #define RELAY_1 3 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define RELAY_ON 1 // GPIO value to write to turn on attached relay
    //define temp/humidity sensor
    #define CHILD_ID_HUM 2
    #define CHILD_ID_TEMP 3
    #define HUMIDITY_SENSOR_DIGITAL_PIN 4
    //define button/magnet sensor
    #define CHILD_ID_BUT 4
    #define BUTTON_PIN 7 // Arduino Digital I/O pin for button/reed switch
    //define Distace Sensor
    #define CHILD_ID_DIS 5
    #define TRIGGER_PIN 6 // Arduino pin tied to trigger pin on the ultrasonic sensor.
    #define ECHO_PIN 5 // Arduino pin tied to echo pin on the ultrasonic sensor.
    #define MAX_DISTANCE 300 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
    unsigned long SLEEP_TIME = 1000; // Sleep time between reads (in milliseconds)
    //Distance sensor initiliazation
    NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
    int lastDist;
    boolean metric = true;
    //Temp sensor initiliazation
    DHT dht;
    float lastTemp;
    float lastHum;
    //Magnet sensor initiliazation
    Bounce debouncer = Bounce();
    int oldValue=0;
    bool state;
    //Distace Sensor
    MyMessage msgDis(CHILD_ID_DIS, V_DISTANCE);
    //Temp message
    //Magnet door sensor message
    MyMessage msgBut(CHILD_ID_BUT,V_TRIPPED);
    gw.begin(incomingMessage, AUTO, false);
    gw.sendSketchInfo("Distance & Temp Sensor & Rele & Magnet,Relay", "1.0");
    //gw.begin(incomingMessage, AUTO, true);
    // Setup the button
    pinMode(BUTTON_PIN,INPUT);
    // Activate internal pull-up
    debouncer.attach(BUTTON_PIN);
    debouncer.interval(5);
    //setup dht sensor
    // Fetch relay status
    gw.present(sensor, S_LIGHT);
    pinMode(pin, OUTPUT);
    digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
    gw.present(CHILD_ID_BUT, S_DOOR);
    gw.present(CHILD_ID_DIS, S_DISTANCE);
    //gw.present(CHILD_ID_REL, S_LIGHT);
    // Alway process incoming messages whenever possible = for Relay
    gw.process();
    debouncer.update();
    // Distance process
    int dist = metric?sonar.ping_cm():sonar.ping_in();
    Serial.print(F("Ping: "));
    Serial.print(dist); // Convert ping time to distance in cm and print result (0 = outside set distance range)
    Serial.println(metric?" cm":" in");
    if (dist != lastDist) {
    gw.send(msgDis.set(dist));
    lastDist = dist;
    //Temp
    if (isnan(temperature)) {
    Serial.println(F("Failed reading temperature from DHT"));
    lastTemp = temperature;
    if (!metric) {
    temperature = dht.toCelsius(temperature);
    Serial.print("T: ");
    Serial.println(temperature);
    if (isnan(humidity)) {
    Serial.println(F("Failed reading humidity from DHT"));
    lastHum = humidity;
    Serial.print("H: ");
    Serial.println(humidity);
    //Button - Magnet update
    debouncer.update();
    // Get the update value
    int value = debouncer.read();
    if (value != oldValue) {
    // Send in the new value
    gw.send(msgBut.set(value==HIGH ? 1 : 0));
    oldValue = value;
    //gw.sleep(SLEEP_TIME);
    if (message.type==V_LIGHT) {
    // Change relay state
    // Store state in eeprom
    // Write some debug info
    Serial.print(message.sensor);
    hekH 1 Reply Last reply
    • A antcas2000
      Thanks in Advance.
      #include <DHT.h>
      //Relay
      int lastDist;
      DHT dht;
      float lastTemp;
      float lastHum;
      int oldValue=0;
      bool state;
      //Distace Sensor
      //Temp message
      // Setup the button
      //setup dht sensor
      gw.process();
      debouncer.update();
      // Distance process
      lastDist = dist;
      //Temp
      if (!metric) {
      lastHum = humidity;
      debouncer.update();
      oldValue = value;
      hekH Offline
      hekH Offline
      @antcas2000
      http://forum.mysensors.org/topic/666/how-to-ask-for-help
