  3. WIFI Gateway using ESP8266 error during compile
5 Posts 2 Posters 1.3k Views 2 Watching
  • J Offline
    J Offline
    jhussain
    I am trying to setup Building a WiFi Gateway using ESP8266 and followed the instructions carefully. When I tried to compile using Arduino IDE 1.9.0, I get the following error: exit status 1
    Error compiling for board NodeMCU 1.0 (ESP-12E Module ).
    Please help what is missing or what I am doing wrong?
    Arduino: 1.9.0-beta (Windows 8.1), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, 4M (1M SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
    In file included from C:\Users\Javed\OneDrive\Documents\MySensors-master\libraries\MySensors/MySensors.h:420:0,
                 from C:\Users\Javed\OneDrive\Documents\MySensors-master\MySensors-master\examples\GatewayESP8266\GatewayESP8266.ino:118:
    C:\Users\Javed\OneDrive\Documents\MySensors-master\libraries\MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp:57:53: error: declaration of C function 'void ets_update_cpu_frequency(int)' conflicts with
    extern "C" void ets_update_cpu_frequency(int freqmhz);
    In file included from C:\Users\Javed\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/pgmspace.h:10:0,
                 from C:\Users\Javed\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Arduino.h:256,
                 from sketch\GatewayESP8266.ino.cpp:1:
    C:\Users\Javed\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2/tools/sdk/include/ets_sys.h:218:6: error: previous declaration 'void ets_update_cpu_frequency(uint32_t)' here
    void ets_update_cpu_frequency(uint32_t ticks_per_us);
    exit status 1
    • J jhussain
      exit status 1
      @jhussain see earlier answers here
      • J Offline
        J Offline
        jhussain
        I went through the replies as pointed out but none solve the issue.
        I tried to close Arduino IDE 1.9.0 and start all over again but get the same compilation error.
        Any comprehensive solution will be appreciated.
        I can compile examples in IDE and they all run OK, so I do not think I have any hardware/software issue with IDE.
        Thanks.
        • J jhussain
          Thanks.
          @jhussain downgrading the esp8266 board files to version 2.4.1 did not help?
          J 1 Reply Last reply
            J Offline
            J Offline
            jhussain
            @mfalkvidd You mean I should try 2.4.1? I will do that today or so and report back.
            Thanks.
