  3. MQTT Client gateway
MQTT Client gateway
91 Posts 33 Posters 66.3k Views 14 Watching
  • b0rmannB
    b0rmannB
    b0rmann
    PubSubClient library cannot currently be used with hardware based on the ENC28J60 :(
    N 1 Reply Last reply
    • b0rmannB b0rmann
      N
      N
      ntruchsess
      @b0rmann
      PubSubClient and ENC28J60 require more memory than an Uno provides. It should run on a Mega256 though.
      • b0rmannB
        b0rmannB
        b0rmann
        DEBUG:
        0;0;3;0;9;read: 16-16-0 s=61,c=1,t=0,pt=7,l=5:38.0
        publish: MyMQTT/16/61/V_TEMP 38.0
        0;0;3;0;9;send: 0-0-16-16 s=61,c=1,t=0,pt=0,l=5,st=ok:38.00
        0;0;3;0;9;send: 0-0-18-18 s=1,c=1,t=2,pt=0,l=5,st=ok:18.00
        mqtt payload for node 18 contain only string '1' (it's relay), '8.00'- trash from previous message :(
        yes, '18.00' may by interprait as boolean TRUE, but '01.00' (next par of log is not FALSE :(
        0;0;3;0;9;read: 16-16-0 s=91,c=1,t=0,pt=7,l=5:61.0
        publish: MyMQTT/16/91/V_TEMP 61.0
        0;0;3;0;9;send: 0-0-16-16 s=91,c=1,t=0,pt=0,l=5,st=ok:61.00
        0;0;3;0;9;send: 0-0-18-18 s=4,c=1,t=2,pt=0,l=5,st=ok:01.00
        dirty hack - i use '000000000000' instead '0' to rewrite old data
        • D
          DirkB19
          wrote on last edited by DirkB19
          Hi Norbert, Bormann or Novicit,
          I'm an Arduino newbie and so far haven't found a way to get the MqttClientGateway to compile.
          Obviously I'm using the wrong include files (libraries), so could someone give me some precise links as to where to download the right PubSubClient stuff, or other libraries, if any needed to compile. (I'm not really finding my way in Github).
          My setup is Arduino UNO+W5100, Mosquitto on RPi (working :-) and Openhab (working :-). On the Raspberry I already have the mqtt-gpio-monitor working with Mosquitto and Openhab, now I want to add Mysensors;
          Thanks in advance,
          DirkB
          UPDATE :+1:
          Ok, I found it meanwhile. Everything works now. Was complicated for a newbie, had some issues with libraries not being in the right folders as well.
            SagittaTheArrow
            Has anybody tried to get this compiled with the development branch (1.4.1) with the RFM69 radios? I have been trying to get a successful compile, but no luck thus far. I do have it working with the stable branch, but I am not happy with the radios and would love to get this client working with the RFM69 radios. I have looked over the code and started to merge the two, but I am not a C++ programmer and have had some difficulty with the following error:
            yMQTTClient.cpp:16:14: error: variable 'VAR_0' must be const in order to be put into read-only section by means of 'attribute((progmem))'
            char VAR_0[] PROGMEM = "TEMP"; //V_TEMP
            I tried some of the workarounds that I found (const char VAR_0) but then the GetType functions break and I do not understand enough of the code to correct that issue. Anyway, I thought I would check here to see if anybody else has made some headway.
            Thanks in advance for any information / help.
              what happens if you add const as the compiler suggest?
              const char VAR_0[] PROGMEM = "TEMP";
                SagittaTheArrow
                If I change the lines to this:
                const char VAR_63[] PROGMEM = "UNKNOWN"; //Custom for MQTTGateway
                And leave this line alone:
                PROGMEM const char *VAR_Type[] = [<removed to keep short>]
                I get this error:
                MyMQTTClient.cpp:82:30: error: variable 'VAR_Type' must be const in order to be put into read-only section by means of 'attribute((progmem))'
                I tried const char VAR_Type[] PROGMEM = [ ]; and char const VAR_Type[] PROGMEM = ; but I get the same error. I"m going to do some reading on PROGMEM to see if I can find out what it does.
                  SagittaTheArrow
                  wrote on last edited by SagittaTheArrow
                  #22
                  and then changing the getType function to: char * MyMQTTClient::getType(char *b, const char *const *index)
                  Now onto trying to merge the the SerialGateway and MQTTClientGateway. Need to see if it would be easier to merge the MQTTClientGateway into the new SerialGateway or the other way around. Time to study some code.
                  • FotoFieberF
                    FotoFieberF
                    FotoFieber
                    Thanks Norbert for the great work! Works very well with mosquitto.
                    I added support for gw.requestTime(...); by modifying MyMQTTClient.cpp after the lines handling I_CONFIG)
                      else if (msg.type == I_TIME)
                        txBlink(1);
                        if (!sendRoute(
                              build(msg, GATEWAY_ADDRESS, msg.sender, 255, C_INTERNAL,
                                    I_TIME, 0).set(now())))
                          errBlink(1);
                    Now I have a timebase for low power (deep standby) sensors.
                    Next I will try to set the time on the gateway with a MQTT Message or NTP....
                    • N ntruchsess
                      I just took the time this afternoon and implemented a mqtt-gateway that works as mqtt-client:
                      https://github.com/ntruchsess/MySensors/tree/mqttclient/libraries/MySensors/examples/MQTTClientGateway
                      it is based on the work of @Damme (http://forum.mysensors.org/topic/260/mysensors-mqtt-gateway) and makes use of nick o'learys PubSubClient-library (http://knolleary.net/arduino-client-for-mqtt/)
                      The main difference to the existing MyMQTT-gateway is that it will connect to an existing mqtt-broker (e.g. mosquitto). This is beneficial if you want to integrate with other mqtt-client-devices sharing a single broker for your automation solution. It also ensures your mqtt-client that is going to pick up the messages from the gateway will talk to a 'real' broker understanding the whole mqtt protocolls semantics
                      It works both ways:
                      on startup or reconnect it subscribes to "MyMQTT/#" (configurable as MQTT_PREFIX). Any publish-messages payload that is delivered by the broker to a topic that complies with the sheme <prefix>/<nodeId>/<childId>/<variable_type> is forwarded as a C_SET-msg to the MySensors radio.
                      Any C_SET-message received from a node is published to the mqtt-broker using the same sheme.
                      • Norbert
                      mainali
                      Hi, I followed the steps, gateway started but not able to use the existing mysensors sketch. I tried with relay and motion sensor but I get nothing in the serial monitor of MQTT client gateway.
                      Am I missing something here ?
                      • FrancoisF
                        FrancoisF
                        Francois
                        @ntruschsess
                        I am getting this compile error when I compile the MQTT Client gateway on lib1.4.1.
                        In file included from MQTTClientGateway.ino:63:0:
                        MyMQTTClient.h:43:35: error: 'RF24_PA_LEVEL_GW' was not declared in this scope
                        void begin(rf24_pa_dbm_e paLevel=RF24_PA_LEVEL_GW, uint8_t channel=RF24_CHANNEL, rf24_datarate_e dataRate=RF24_DATARATE, uint8_t _rx=6, uint8_t _tx=5, uint8_t _er=4 );
                        MQTTClientGateway.ino: In function 'void setup()':
                        MQTTClientGateway.ino:136:12: error: 'RF24_PA_LEVEL_GW' was not declared in this scope
                        Error compiling.
                        • FotoFieberF
                          FotoFieberF
                          FotoFieber
                          In MyMQTTClient.cpp the function
                          MyMQTTClient::processMQTTMessage(char* topic, byte* payload, unsigned int length)
                          does ignore length. This can lead to garbage transferred to the clients in the payload
                          char* ca;
                          ca = (char *)payload;
                          ca += length;
                          *ca = '\0';
                          before
                          msg.set((const char*)payload); //Payload
                          (I am sure, this can be written in a more elegant way. :))
                          • FotoFieberF
                            FotoFieberF
                            FotoFieber
                            Added support for:
                            • sketchinfo
                            • sketchversion
                            • time
                            • batterylevel
                            • dallas RTC and message to set time from outside
                            https://github.com/FotoFieber/MySensors/tree/mqttclient/libraries/MySensors/examples/MQTTClientGateway
                            • G
                              G
                              Gambituk
                              @FotoFieber @ntruchsess i have a parallel post regarding this version of the controller, i did not know it was the same as this one when i opened the thread :8ball: but i am having some garbage issues, do you think this is the same problem as you have described 2 posts up? http://forum.mysensors.org/topic/921/strange-value-being-sent-from-controller-using-mixed-temp-relay-node thanks for any comments or pointers
                              • FotoFieberF
                                FotoFieberF
                                FotoFieber
                                @Gambituk
                                This seems to be the problem I fixed with adding \0 at the end of the payload. Try the patch from above.
                                • T
                                  TommySharp
                                  Hi guys! Took me a while but I've finally got this compiling and uploading to the Arduino Uno.
                                  I can see the Uno on my ethernet network and it's visible as the IP address I set in the sketch.
                                  But my mosquitto MQTT broker never receives anything from the Uno, I was expecting even just a New Client Connection notification or something... But nothing.... I have OpenHAB talking to Mosquitto and the Mosquitto screen shows it receiving ping requests from OpenHAB so I know the broker side of things is working well.
                                  Anyone got any ideas? I'm confident that the IP address and port for my broker have been properly configured in the sketch.
                                  I just configured 4 things in the scketch..
                                  1. Broker IP Address
                                  2. Broker Port
                                  3. Arduino IP address
                                  4. Arduino MAC Address
                                  • FotoFieberF
                                    FotoFieberF
                                    FotoFieber
                                    Hi TommySharp
                                    Question 1:
                                    Do you see the connection on mosquitto:
                                    mosquitto_sub -h mosquittoip -v -t '$SYS/broker/clients/active'
                                    Question 2:
                                    Do your mysensor-nodes get connected to the gateway? (You can have only one gateway.)
                                    Tip 1:
                                    Program your arduino with an isp (or arduinoisp): you then have more room as you don't need the bootloader and can enable debug.
                                    • T
                                      TommySharp
                                      @FotoFieber
                                      Thanks for the reply....
                                      I'm running mosquitto on windows so not sure how to "run" the command you suggest? I can see the mosquitto DOS looking dialogue box onscreen and it shows OpenHAB pinging mosquitto every few minutes, not seeing any pings or subscriptions coming from the MySensors MQTTClient Gateway though?
                                      This is the only gateway I am trying to setup and I have one wireless temperature/humidity sensor running and it's located about 1 meter from the gateway. I expected that even without any sensor nodes setup that at least the Gateway should connect to mosquitto in some way? I did mess about with trying the other MQTT gateway where it is also the broker and I did get a few temperature readings all the way into OpenHAB that way but OpenHAB randomly lost the connection to the broker and then I'd have to reboot everything. Just mentioning that because that tells me that my one sensor node is working properly I guess.
                                      Tip 1 : I'll have to do some googling about an "isp" to see what that's all about....
                                      • dakkyD
                                        dakkyD
                                        dakky
                                        will this feature be ported back to the official repo?
                                        Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
                                        Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
                                        Software: MySensors 2.0development
                                        • dakkyD
                                          dakkyD
                                          dakky
                                          wrote on last edited by dakky
                                          #34
                                          another question: i'm using the uno with the ethernet shield. Is the wiring the same as documented here?
                                          I double checked the wiring but keep on receiving the "check wires" message in the serial monitor.
                                          What did i do?
                                          • wiring the nrf
                                          • enabled DEBUG in myConfig.h
                                          • threw the PubSubClient and DS1307RTC libraries in my lib folder
                                          • "fixed" PubSub code as told by @ntruchsess somewhere in this thread
                                          • configured mqtt server and port, arduino ip an mac (btw, commenting out the arduino IP, which should result in using DHCP, does not work, because local_ip is not configured anymore?)
                                          the code itself compiled fine, but i keep on getting this wiring error :(
                                          what confuses me too: the pins noted in the sketch: are they handled through the ethernetshield?
                                          greetings
                                          dakky
                                          EDIT: Dammit .. i forgot to reenable SOFTSPI. Could this cause the wiring problem? and now the Sketch is too large (with debug enabled)
