  3. nRF5 action!
nRF5 action!
  • T Toyman
    @omemanti actually, all you need is to issue the following command:
    nrfjprog.exe --recover
    mr_redM
    mr_redM
    mr_red
    @toyman @Omemanti
    For Documentations sake:
    I was having the same problems of the Ebyte E73 Module of being locked.
    The ST_LinkV2 Clone Firmware are not able to recover the modules as the swd implementation is missing some direct register write capabilities.
    The nfrjprog and nor openocd are working with the ST_LinkV2.
    As suggested in this thread somewhere, I was able to get the modules unlocked with the Jlink clone and nrfjprog.
    see also :
    https://github.com/micooke/arduino-nRF5-smartwatches/blob/master/nrf52_disable_read_protection.txt
    That (pirated) Firmware is working with swd and is able to recover the modules. Had to solve some dll-issues before, but got it working.
    After the recovery with nrfjprog the stlink and the jlink are working as expected with openocd.
    To find out if your wiring etc. is fine and it is really the locked devices you get this when starting your openocd interface.
    The voltage is fine but the breakpoints are recognized.
    Info : using stlink api v2
    It should be
    Info : nrf52.cpu: hardware has 6 breakpoints, 4 watchpoints
    ileneken3I 1 Reply Last reply
    • mr_redM mr_red
      @toyman @Omemanti
      see also :
      It should be
      ileneken3I
      ileneken3I
      ileneken3
      @mr_red
      I can add some of my own "documentation" on this issue. I only recently was able to program an Ebyte E73 module, and it was a long struggle. I used the NRF DK, and had help from a Nordic engineer.
      • The recommended way to connect to the external device is:
      Using the P20 and P1 headers, connect:
      P20 VDD -> 3.3v on EBYTE 2G4M04S1B module
      P20 SWDIO -> SWDIO on EBYTE 2G4M04S1B module
      P20 SWDCLK -> SWDCLK on EBYTE 2G4M04S1B module
      P20 VTG -> P1 VDD
      P1 GND -> GND on EBYTE 2G4M04S1B module
      To unlock the chip, execute:
      nrfjprog -f nrf52 --recover
      They also recommend using nrfjprog to program the device, because nRFgo Studio is deprecated. But I used the Studio and it worked fine. I gave Studio the .hex produced by the Arduino IDE using "Sketch" -> "Export compiled Binary".
      As mentioned in the previous post, it is unlikely to unlock the board with anything but the NRF DK or a genuine J-Link. (Maybe a good fake J-Link).
      Mistakes others may be able to learn from:
      • Soldering the module onto a custom board can be hard. If you miss a little solder on SWDCLK or SWDIO, there is no hope. Check continuity on every pin you need!
      • Make sure you don't order a NRF52810 module - only NRF52832 . You can program them, but Mysensors is not compatible. It's easy to hit the wrong link on AliExpress as they look identical.
      • The NRF DK seems to deliver only 2.8V to the device. I first thought there was a problem, and tried to connect external power sources. But it seems to work powered from the DK.
      mr_redM 1 Reply Last reply
      • nagelcN nagelc
        @magkudjee
        MySensors will support 2 interrupts using sleep. I do not think it will support 3.
        Use this format for the sleep call:
        sleep(interrupt1, mode1, interrupt2, mode2, ms=0);
        In your case: sleep(BUTTON1_PIN, CHANGE, BUTTON2_PIN, CHANGE, 0);
        I don't know how to handle the 3rd interrupt.
        Check the MySensors API document here: https://www.mysensors.org/download/sensor_api_20#sleeping
        magkudjee
        @nagelc
        thank you
        • ileneken3I ileneken3
          @mr_red
          P20 VTG -> P1 VDD
          mr_redM
          mr_redM
          mr_red
          @ileneken3
          It is a struggle indeed. I wanted to stay "low cost" with clone stlink and clone jlink.
          As this is in preparation for a local hackspace workshop the entry level should be as low as possible.
          And I suceeded to get this running for under 10€. (only one Jlink needed to unlock the modules once)
          I am using platform.io and arduino, which use openocd internally. No need for nrfgo or an second programm and take the hex somewhere else.
          Highly recommend platform.io for this! Flashing & Serial output are superfast, nice IDE and my dev-cycle speed up by an order of magnitude.
          Question:
          I am using an second device for USB-Serial convertion to get some print-msg out of the nrf52832.
          Is there any way to do this over the programmer?
          You can define the RX/TX pins in the nrf52832 to the pins you want.
          Hardware Workaround by Neverdie: Connector Board -openhardware.io
          • mr_redM mr_red
            @ileneken3
            Question:
            Toyman
            @mr_red said in nRF5 action!:
            Not in Arduino. In KEIL you can use RTT (pretty cool stuff, debug via SWD)
            But if you just want to decrease a number of programmers, you can use Black Magic Probe, made from BluePill ($2 at Ali). It is 2-in-1 SWD and USB-UART converter on one PCB
            • alowhumA
              alowhumA
              alowhum
              @ileneken3 @mr_red Thanks for this! Glad to hear I wasn't going crazy, but that others have had the same issue.
              • O
                O
                Omemanti
                A quick Google pointed me to https://github.com/AndruPol/nrf52832-recover/blob/master/README.md
                I do have a STM32F103C8T6 laying around. But ATM no time to play with it.
                Maybe that's the €3 solution for unlocking.
                • O Omemanti
                  Toyman
                  @omemanti said in [nRF5 action!]Maybe that's the €3 solution for unlocking.
                  BMP is enough to unlock. BluePill costs ca. €2 and it's easily convertable to BMP
                  • mr_redM
                    mr_redM
                    mr_red
                    @Omemanti Good find about the BMP to recover the Ebyte module. Can you point me to an aliexpress link? "stm32" "bluepill" are not the magic chinese keywords..
                    • mr_redM mr_red
                      @mr_red https://medium.com/@paramaggarwal/converting-an-stm32f103-board-to-a-black-magic-probe-c013cf2cc38c has keywords and a direct link to Ali
                      • alowhumA
                        alowhumA
                        alowhum
                        I created a BMP, both from a cheap ST-Link and an STM32, and it didn't help me break open those eByte NRF52 units.
                        • alowhumA alowhum
                          mr_redM
                          mr_redM
                          mr_red
                          @alowhum where did you get stuck? Whats your process?
                          • monteM monte
                            @smilvert I think I solved issues I mentioned. But I don't have final code yet as I am waiting for parts to arrive for my board. But I think there is no problem using WT51822 board except that you'll have to manually set PORT interrupt and also set pin SENSE register which is cannot be done with arduino function pinMode().
                            So I guess you can order PCBs if you want, I'm going to post final sketch with explanations at the end of the month.
                            W
                            W
                            waspie
                            @monte do you have final code now ? :)
                            • mr_redM mr_red
                              ileneken3I
                              ileneken3I
                              ileneken3
                              @mr_red
                              I got to the point where the stm32loader.py runs and outputs:
                              Bootloader version 22
                              Chip id: 0x410 (STM32 Medium-density)
                              Write 256 bytes at 0x8000000
                              Write 256 bytes at 0x8000100
                              [..snip..]
                              Write 256 bytes at 0x8001900
                              Write 256 bytes at 0x8001A00
                              Read 256 bytes at 0x8000000
                              Read 256 bytes at 0x8000100
                              [..snip..]
                              Read 256 bytes at 0x8001900
                              Read 256 bytes at 0x8001A00
                              Verification OK
                              After that, you're supposed to plug in to the USB directly. I get " USB device not recognized". Zadig doesn't help. It lists it as:
                              "Unknown USB Device (Device Descriptor Request Failed)"
                              Any ideas?
                                @mr_red
                                [..snip..]
                                [..snip..]
                                Verification OK
                                Any ideas?
                                Toyman
                                @ileneken3 have you returned the jumpers back?
                                • T Toyman
                                  ileneken3I
                                  ileneken3I
                                  ileneken3
                                  @toyman
                                  Unfortunately, yes, I have returned the jumpers to their original settings, and have even tried all 4 combinations.
                                  I also changed computers, changed OS's, changed cables.
                                  The board LOOKS like it was well manufactured, but I suppose a bad board is a possibility. Other than that, I can't figure out what could be wrong.
                                  • d00616D d00616
                                    sebiS
                                    sebiS
                                    sebi
                                    @d00616 said in nRF5 action!:
                                    I am having the same issue trying to write on a E73 module with read/write protections. I don't have a JLink, but a ST Link-V2 and OpenOCD.
                                    Do you know how to remove the protections on the E73 with such tools? Thanks.
                                    • N
                                      N
                                      novicit
                                      @sebi,
                                      A couple weeks ago I began exploring deploying E73 modules and had to remove protections. I was successful and now have a working E73 ethernet gateway. Only had ST Link-V2, so I used a "blue pill" I had in inventory to load it with Black Magic Probe. This cleared the protections.
                                      The instructions I followed to load the BMP are step-by-step at https://github.com/TamojitSaha/STM32f103_Black-Magic-Probe
                                      The instructions followed to clear protections with BMP also are step-by-step and worked perfect. They are at https://github.com/AndruPol/nrf52832-recover
                                      In item #4, the program arm-none-eabi-gdb.exe seems to be part of the Arduino tool chain as I found it just by doing a search in file explorer and it was already on my win10 machine. Also, in item #4, (gdb) is the prompt that the program arm-none-eabi-gdb.exe gives. In the first line, change the '/dev/ttyACM0' to your com port. Use 'quit' to exit the program. Also, use 'mon help' to see options.
                                      There are apparently a number of ways to 'recover' the E73, but this worked easily for me, and was step-by-step.
                                      • N
                                        N
                                        ncollins
                                        @NeverDie Hoping you can help me with an WTNRF51822-S4AT problem where my stop recognizing interrupt events 2ish days after the last interrupt.
                                        The buttons sleep for 24 hours, then wake up and send battery level. Even though the interrupt stops triggering, they still send battery level.
                                        Possible some kind of timer is expiring?
                                        Any help is appreciated.
                                        // General settings
                                        #define SKETCH_NAME "ThinButton"
                                        #define SENSOR_NAME SKETCH_NAME
                                        #define SKETCH_VERSION "1.4"
                                        #define MY_NODE_ID 37
                                        #define MY_BAUD_RATE 115200
                                        #define IS_NRF51
                                        #define PIR_DETECTION_PIN 3
                                        #define SHORT_WAIT 50
                                        #define DEBOUNCE_MS 1000
                                        volatile bool motion_change=false;
                                        #define MY_RADIO_NRF5_ESB
                                        #define SLEEP_MS 1000 * 60 * 60 * 24
                                        #define   CHILD_ID_VOLT 1
                                        MyMessage msgBattery(CHILD_ID_VOLT, V_VOLTAGE);
                                        #define CHILD_ID_BTN 2
                                        #define BTN_PIN PIR_DETECTION_PIN
                                        MyMessage msgBtn(CHILD_ID_BTN, V_TRIPPED);
                                          #ifndef IS_NRF51
                                        void turnOffRadio() {
                                          NRF_RADIO->TASKS_DISABLE=1;
                                        void turnOffUarte0() {
                                          #ifndef IS_NRF51
                                            NRF_UARTE0->TASKS_STOPRX = 1;
                                            NRF_UARTE0->TASKS_STOPTX = 1;
                                          #ifdef IS_NRF51
                                            NRF_UART0->TASKS_STOPRX = 1;
                                            NRF_UART0->TASKS_STOPTX = 1;
                                            NRF_UART0->TASKS_SUSPEND = 1;
                                        void turnOffAdc() {
                                          #ifndef IS_NRF51
                                              NRF_SAADC->TASKS_STOP=1;
                                        void mySleepPrepare() {  //turn-off energy drains prior to sleep
                                          turnOffHighFrequencyClock();
                                          turnOffRadio();
                                          turnOffUarte0();
                                        void activateLpComp() {
                                          NRF_LPCOMP->PSEL=4; // monitor AIN0 (i.e. pin P0.02 on nRF52832 PIR Motion Sensor v607).
                                          while (!(NRF_LPCOMP->PSEL==4)) {} //wait until confirmed
                                          NRF_LPCOMP->ANADETECT=0;  //detect CROSS events on PIR detection pin
                                          while (NRF_LPCOMP->ANADETECT!=0) {} //wait until confirmed
                                          NRF_LPCOMP->INTENSET=B1000;  //Enable interrupt for CROSS event
                                          while (!(((NRF_LPCOMP->INTENSET)&B1000)==B1000)) {} //wait until confirmed
                                          NVIC_EnableIRQ(LPCOMP_IRQn);
                                            while (((NRF_LPCOMP->INTENCLR)&B0100)==B0100) {} //wait until confirmed
                                          while (((NRF_LPCOMP->INTENSET)&B1000)!=B0100) {} //wait until confirmed
                                        // setup
                                          hwInit();
                                          hwPinMode(PIR_DETECTION_PIN,INPUT);
                                          disableNfc();  //remove unnecessary energy drains
                                          turnOffAdc();  //remove unnecessary energy drains
                                          activateLpComp();
                                        void mySleep(uint32_t ms) {
                                           mySleepPrepare();  //Take steps to reduce drains on battery current prior to sleeping
                                           sleep(ms);
                                        // presentation
                                          present(CHILD_ID_VOLT, S_MULTIMETER, SENSOR_NAME);
                                          wait(SHORT_WAIT);
                                          present(CHILD_ID_BTN, S_MOTION, SENSOR_NAME);
                                          wait(SHORT_WAIT);
                                        unsigned long lastTripped = millis();
                                        // loop
                                          mySleep(SLEEP_MS);
                                          if(motion_change){
                                            unsigned long ms = millis();
                                            long timeDiff = ms - lastTripped;
                                            if(timeDiff < 0 || timeDiff > 1000){
                                              send(msgBtn.set((uint8_t) 1));
                                            NRF_LPCOMP->EVENTS_CROSS=0;
                                            send(msgBattery.set(getInternalVoltage(),3));
                                        float getInternalVoltage(){
                                          return ((float)hwCPUVoltage())/1000.0;
                                        #if __CORTEX_M == 0x04
                                                event = 0;        \
                                                (void)event
                                        // This must be in one line
                                        extern "C" { void LPCOMP_IRQHandler(void) {motion_change=true; NRF5_RESET_EVENT(NRF_LPCOMP->EVENTS_CROSS); NRF_LPCOMP->EVENTS_CROSS=0; MY_HW_RTC->CC[0]=(MY_HW_RTC->COUNTER+2);}}
                                        NeverDieN W 2 Replies Last reply
                                        • N ncollins
                                          // General settings
                                          #define IS_NRF51
                                            #ifndef IS_NRF51
                                            #ifndef IS_NRF51
                                            #ifdef IS_NRF51
                                          void turnOffAdc() {
                                            #ifndef IS_NRF51
                                            turnOffRadio();
                                            turnOffUarte0();
                                          // setup
                                            hwInit();
                                            activateLpComp();
                                             sleep(ms);
                                          // presentation
                                            wait(SHORT_WAIT);
                                            wait(SHORT_WAIT);
                                          // loop
                                            mySleep(SLEEP_MS);
                                            if(motion_change){
                                                  event = 0;        \
                                                  (void)event
                                          #1778
                                          @ncollins
                                          It has been a while. I may be switching to PIC: https://forum.mysensors.org/topic/10666/anyone-ever-look-into-ezbl-aka-easy-booloader-on-a-pic
                                          The impression I get is that you just write the new hex file into flash, flip a switch in software, and bang, you switchover to the new firmware without skipping a beat. No need to even reboot.
                                          I think anything with the best general solution for OTA updates is a better path than doing OTA firmware bootloader one-offs for each MCU. From what I've gathered, it seems PIC may be the only one with the generalized bootloader support that I'm looking for. I haven't tried PIC before, but I'll be receiving a PIC board on Tuesday to test out this new theory. I'm gravitating toward LoRa anyway, so for that I can't leverage anything from NRF5x anyway. LoRa is the closest thing to bulletproof wireless communications that I've found so far. It just works, with fantastic range and coverage while still fitting within FCC requirements.
                                          PICs tend to consume less energy than both atmega's and nRF5x's while sleeping, so there may be some positive trade-offs to be had there as well.
                                          I'll miss the tight integration possible with an nRF5x. Maybe someday there will be PICs with integrated LoRa radios? MicroChip makes both separately, so it could conceivably happen. They've already done it with SAM: https://pic-microcontroller.com/microchip-new-ultra-low-power-lora-sip/
                                          N 1 Reply Last reply
