  3. void receive not work with RelayActuator.ino ?
5 Posts 3 Posters 523 Views 3 Watching
  • Y
    Y
    yourry
    Hi all,
    I don't understand a problem,
    My receive function is not working in the sktech relayActuator.ino
    If I simply add the following code :
       Serial.print("--- Incoming Message ---");
      if (message.getType()==V_STATUS) {
    I never have anything.
    But in the node logs I do receive the information:
    Relay OFF :
    345110 TSF:MSG:READ,0-180-162,s=180,c=3,t=6,pt=0,l=1,sg=0:0
    Relay ON:
    355655 TSF:MSG:READ,0-180-162,s=180,c=3,t=6,pt=0,l=1,sg=0:1
    For information I use a gateway+W5100 in MQTT.
    An idea why the receive function is not working here ?
    Thank you all
    skywatchS 1 Reply Last reply
    • Y yourry
      Hi all,
      Relay OFF :
      Relay ON:
      Thank you all
      skywatchS
      skywatchS
      skywatch
      @yourry Don't use serial print inside the receive function.
      instead set a variable in receive and test for that in the main loop and then send serial from the main loop.
      This is probably all the problem is........ probably....... ;)
      • Y
        Y
        yourry
        Thanks for the answer, I keep the advice.
        Finally I looked for a while and the problem was with the MQTT publish syntax.
        It works perfectly, the difficulty is to find the right publish MQTT request.
        Thank you.
        • skywatchS skywatch
          @skywatch said in void receive not work with RelayActuator.ino ?:
          Why not? Receive doesn't run in interrupt context, so it should be safe to serial print from it...
          • YveauxY Yveaux
            skywatchS
            skywatchS
            skywatch
            @Yveaux I'm sure it's in the forum posts somewhere but I don't have time to look for it.
            Maybe you could do a list of what is and isn't possible in void receive to mitigate further confusions?
