  3. !TSM:ID:FAIL need help
3 Posts 2 Posters 407 Views 2 Watching
  • R
    R
    robos
    Hi
    it's my first post and i need help.
    I want to use mysensors as move sensor and my problem is sender probably doesn't want exit from init mode ??
    10093 !TSM:ID:FAIL	Did not receive a node id from controller. Is your controller connected and correctly configured?
    10094 TSM:FAIL:CNT=1	Transition to Failure state, consecutive failure counter is 1
    10096 TSM:FAIL:DIS	Disable transport
    10098 TSF:TDI:TSL	Set transport to sleep
    program never goes to void loop
    I need a hint :) to sketch to work.
    Power is ok ; messages go thru gateway to mqtt
    Test sketch:
    #define MY_RADIO_RF24
    uint32_t SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
    #define MY_NODE_ID 1
    	sendSketchInfo("Motion Sensor", "1.0");// Send the sketch version information to the gateway and Controller
    	present(CHILD_ID, S_MOTION);// Register all sensors to gw (they will be created as child devices)
      Serial.println(" - =  T E S T    L O O P  = -");
    	bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;  // Read digital motion value
    Log from sender
    __  __       ____
           |___/                      2.3.2
    16 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=16,REL=255,VER=2.3.2
    26 TSM:INIT
    28 TSF:WUR:MS=0
    34 TSM:INIT:TSP OK
    36 TSM:FPAR
    38 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    944 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    949 TSF:MSG:FPAR OK,ID=0,D=1
    2048 TSM:FPAR:OK
    2049 TSM:ID
    2050 TSM:ID:REQ
    2053 TSF:MSG:SEND,255-255-0-0,s=2,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    4060 TSM:ID
    4061 TSM:ID:REQ
    4063 TSF:MSG:SEND,255-255-0-0,s=221,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    6071 TSM:ID
    6072 TSM:ID:REQ
    6074 TSF:MSG:SEND,255-255-0-0,s=184,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    8082 TSM:ID
    8083 TSM:ID:REQ
    8085 TSF:MSG:SEND,255-255-0-0,s=147,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    10093 !TSM:ID:FAIL
    10096 TSM:FAIL:DIS
    10098 TSF:TDI:TSL
    Log from gateway:
    39 MCO:BGN:INIT GW,CP=RNNGF---,FQ=240,REL=255,VER=2.3.2
    44 TSF:LRT:OK
    47 TSM:INIT
    51 TSF:WUR:MS=0
    60 TSM:INIT:TSP OK
    61 TSM:INIT:GW MODE
    66 TSM:READY:ID=0,PAR=0,DIS=0
    70 MCO:REG:NOT NEEDED
    186 GWT:TPC:CONNECTING...
    1189 MCO:BGN:STP
    1191 MCO:BGN:INIT OK,TSP=1
    1195 GWT:TPC:IP=192.168.1.88
    1200 GWT:RMQ:CONNECTING...
    1222 GWT:RMQ:OK
    1224 GWT:TPS:TOPIC=/mysens-out/0/255/0/0/18,MSG SENT
    1232 TSM:READY:NWD REQ
    1237 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    31573 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    31578 TSF:MSG:BC
    31582 TSF:MSG:FPAR REQ,ID=255
    31587 TSF:PNG:SEND,TO=0
    31591 TSF:CKU:OK
    31595 TSF:MSG:GWL OK
    32480 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    33587 TSF:MSG:READ,255-255-0,s=2,c=3,t=3,pt=0,l=0,sg=0:
    33592 GWT:TPS:TOPIC=/mysens-out/255/2/3/0/3,MSG SENT
    35598 TSF:MSG:READ,255-255-0,s=221,c=3,t=3,pt=0,l=0,sg=0:
    35603 GWT:TPS:TOPIC=/mysens-out/255/221/3/0/3,MSG SENT
    37609 TSF:MSG:READ,255-255-0,s=184,c=3,t=3,pt=0,l=0,sg=0:
    37614 GWT:TPS:TOPIC=/mysens-out/255/184/3/0/3,MSG SENT
    39620 TSF:MSG:READ,255-255-0,s=147,c=3,t=3,pt=0,l=0,sg=0:
    39625 GWT:TPS:TOPIC=/mysens-out/255/147/3/0/3,MSG SENT
    My Gateway is ESP32/NRF24 +MQTT and message to mqtt is ok (this is defferent log)
    27.12.2020, 17:21:33node: edf01ef4.eb25f /mysens-out/255/2/3/0/3 : msg.payload : string[0]""
    27.12.2020, 17:21:35node: edf01ef4.eb25f  /mysens-out/255/221/3/0/3 : msg.payload : string[0]""
    27.12.2020, 17:21:37node: edf01ef4.eb25f  /mysens-out/255/184/3/0/3 : msg.payload : string[0]""
    27.12.2020, 17:21:39node: edf01ef4.eb25f  /mysens-out/255/147/3/0/3 : msg.payload : string[0]""
    BearWithBeardB 1 Reply Last reply
    • R robos
      Hi
      Test sketch:
      Log from sender
      __  __       ____
             |___/                      2.3.2
      26 TSM:INIT
      28 TSF:WUR:MS=0
      34 TSM:INIT:TSP OK
      36 TSM:FPAR
      2048 TSM:FPAR:OK
      2049 TSM:ID
      2050 TSM:ID:REQ
      4060 TSM:ID
      4061 TSM:ID:REQ
      6071 TSM:ID
      6072 TSM:ID:REQ
      8082 TSM:ID
      8083 TSM:ID:REQ
      10093 !TSM:ID:FAIL
      10096 TSM:FAIL:DIS
      10098 TSF:TDI:TSL
      Log from gateway:
      44 TSF:LRT:OK
      47 TSM:INIT
      51 TSF:WUR:MS=0
      60 TSM:INIT:TSP OK
      61 TSM:INIT:GW MODE
      1189 MCO:BGN:STP
      1222 GWT:RMQ:OK
      31578 TSF:MSG:BC
      31591 TSF:CKU:OK
      BearWithBeardB
      BearWithBeardB
      BearWithBeard
      wrote on last edited by BearWithBeard
      Welcome @robos!
      The gateway is sending an ID request via MQTT to the controller, but doesn't get a reply.
      From the Building a MQTT Gateway guide:
      NOTE: No controller supports dynamic ID assignment through MQTT. All nodes must have MY_NODE_ID defined in the sketch to work with MQTT. If you don't set MY_NODE_ID, nodes will complain with the message "!TSM:ID:FAIL".
      If you want to keep using MQTT, you have to add #define MY_NODE_ID n before(!) #include <MySensors.h>, whereby n may be any (unused) number between 1 and 254.
      For automatic ID assignment through the controller, select a different gateway, like serial or ethernet.
      • R
        R
        robos
        #define MY_NODE_ID n before(!) #include <MySensors.h> that helped a lot !!!
        12.5k
