  3. RFM69 sleep mode
RFM69 sleep mode
25 Posts 9 Posters 18.2k Views 7 Watching
  • FrancoisF
    FrancoisF
    Francois
    @hek to get down to 3uA I have to use the following line.
    How do I do this in the current library. If I use the LowPower library I get an error when compile
      Tried gw.sleep(8000); ?
      • FrancoisF
        FrancoisF
        Francois
        @hek with sleep(8000) I still get 3.75mA.
          Strange that you get different values depending on radio. That points to problem with radio sleep and not the Arduino itself.
          So if create a RF69 sketch that just sleeps in loop. What happens if you disconnect radio (after init)? Do you you get ~3.75uA?
          • FrancoisF
            FrancoisF
            Francois
            @hek sorry how will I disconnect the radio?
              Ahh.. good question if (you're running Moteino with them soldered on).
              • FrancoisF
                FrancoisF
                Francois
                @hek yes the radio is solder on
                  wrote on last edited by hek
                  I can't find myself doing anything different from the LowPower library in in MyAtMega328.cpp - sleep(). Need someone else's eyes on it.
                  • FrancoisF
                    FrancoisF
                    Francois
                    @hek I see that you have powerDown in the MyHwATMega328.cpp how do I use that function?
                    void powerDown(period_t period) {
                    	ADCSRA &= ~(1 << ADEN);
                    	if (period != SLEEP_FOREVER)
                    		wdt_enable(period);
                    		WDTCSR |= (1 << WDIE);
                    	#if defined __AVR_ATmega328P__
                    		do {
                    			set_sleep_mode(SLEEP_MODE_PWR_DOWN);
                    			cli();
                    			sleep_enable();
                    			sleep_bod_disable();
                    			sei();
                    			sleep_cpu();
                    			sleep_disable();
                    			sei();
                    		} while (0);
                    		do {
                    			cli();
                    			sleep_enable();
                    			sei();
                    			sleep_cpu();
                    			sleep_disable();
                    			sei();
                    		} while (0);
                    	ADCSRA |= (1 << ADEN);
                      You use it by calling gw.sleep() which initiates powerDown.
                      https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/MySensor.cpp#L820
                      • FrancoisF
                        FrancoisF
                        Francois
                        @hek Hi I got a new shipment of Arduino mini pro and after I did the low power hack on this Arduino I now are getting 30uA current usage. Thank again for all you support and for this great MySensor community that you started :). Now I can go full steam ahead in building more sensor for my house.
                        • FrancoisF Francois
                          So, just to be clear, is this an accurate summary: the full package (Arduino mni pro plus radio) sleeps at 30uA if using the RFW69 but sleeps at 3uA if using the NRF24L01+?
                          Also, does it make any difference whether it's RFM69W, RFM69CW, or RFM69HW? Do they all draw the same amount of current while sleeping?
                          P 1 Reply Last reply
                            P
                            P
                            peres
                            Hi, I know this is an old thread, but it is stil a valid subject to me.
                            I have had success with arduino pro mini v2 and RFM69W in sleep, but not the high power version RFM69HW.
                            Arduino+RFM69W sleeps at 5.2micro Amp.
                            Arduino+RFM69HW sleeps at 420micro Amp.
                            I have written about it in arduino forum.
                            I would be glad if someone has a solution for this.
                            • P peres
                              manutremo
                              wrote on last edited by manutremo
                              Hi @peres,
                              My RFM69HW current during sleep is less than 1 uA aprox, which is consistent with what is shown in the datasheet. Interestingly, this is the result when powering the device with a battery; when powering the device from the PC USB serial, it's around 6 uA - still close enough as it's measured with a "normal" multimeter.
                              I'Which version of mysensors are you using? I've moved to 2.2.0-beta (due to me needing other functionalities not availabel in 2.1.1, namely ATC which btw works fabulously) and found that support for nrf69 is - although not yet 100% completed - significantly improved. Maybe worth a try to see if that fixes your sleep consumption?
                              Remember adding
                              #define MY_RFM69_NEW_DRIVER
                              to enable the new driver.
                              Let us know how it goes :)
                              • N
                                N
                                napo7
                                I have the same question, but a little bit different ;)
                                I use a RFM69 with the Mysensors 2.2.0 beta.
                                I don't sleep my node with the provided function, since I don't want to sleep for some time, but until a Pin Change Interrupt is triggered (via pin A0 or A1). So, I can't use the sleep() function.
                                I do put my node to sleep with avr core functions (setting registers, calling power_all_disable() and sleep_cpu()...) but I suppose the radio is never put on sleep !
                                Is there a function I can call to sleep the radio, and if yes, is there another function I should call before sending, to awake the radio ?
                                Thanks !
                                  @napo7
                                  Here the list of the core functions (radio independant):
                                  https://ci.mysensors.org/job/Verifiers/job/MySensors/branch/development/Doxygen_HTML/group__MyTransportgrp.html#gab39d3b81f005e00117269d79c7b2ee4c
                                  should be transportDisable/transportReInitialise
                                  Else the radio specific functions (a layer above driver) are in the MyTransportRFM69.cpp
                                  • N
                                    N
                                    napo7
                                    Thanks !
                                    • F
                                      F
                                      Fabien
                                      @napo7 : you can use sleep with interrupts :
                                      https://www.mysensors.org/download/sensor_api_20#sleeping
                                      • F Fabien
                                        @Fabien MySensors sleep only supports hardware interrupts. napo7 is using pin change on analog pins which needs to be done in software.
                                        • N
                                          N
                                          napo7
                                          That's not a software interrupt. In facts, the atmega supports interrupt on all pins, and also waking-up the device from any pin change, but the sleep function only support "external interrupts" which can only be triggered on pin 2 and 3.
