  3. 110v-230v AC to Mysensors PCB board
269 Posts 63 Posters 345.6k Views 68 Watching
  • scalzS scalz
    @ServiceXp : are you talking about my relay board? if yes, I will check what I can do in the end of the week and post my project in a new topic (I think I have to rearrange the board to fit the step down).
    RJ_MakeR
    RJ_MakeR
    RJ_Make
    @scalz Sorry, No I was referring to the OP.
    RJ_Make
    • rvendrameR
      rvendrameR
      rvendrame
      @ServiceXp , I'm also looking for a way to power a node from the available-standard two wire switch. It should be possible to steal some milliamps from there, but I don't know even from where to start researching it.
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      • A
        aproxx
        Hi All,
        I'm not sure if I understand the 2-wire thing completely, but in my house (which is kind of standard I guess in Europe) I have 3 wires going from the electricity cabinet, to the light switch and then to the light bulb. These cables are Phase, Neutral and Ground.
        As I don't want to rewire my entire grid, I decided to build these boards so I can reuse the current wiring. I ended up with the following "schematic" if I can call my paintskills like that.
        The enclosure at the bottom of the drawing would be placed behind the current light switch, while the enclosure at the top of the drawing would be placed right above the light bulb. This requires little to no modification of my current wiring.
        @ServiceXP, I'll update the title to include the 110v information.
        • J
          J
          Jan Gatzke
          wrote on last edited by Jan Gatzke
          Why don't you place the relay behind the switch, too? This way you could save half of the nodes.
          I have just ordered some of those power supply modules. Very interesting, cheapest similar ones I found before were about 14 €.
            shabba
            This is what I have done for a light bulb in the pantry with a motion sensor. Its a mess as it is a proof of concept.
            I have a 5 separate "modules" as such. Arduino Pro Mini, Motion Sensor, Radio, 5V AC/DC transformer and a 5V Relay. So clearly it is too big and a bit of a mess! So I am really interested in your PCB @aproxx! Do let us know how it works for you.
            AWIA 1 Reply Last reply
            • S shabba
              AWIA
              AWIA
              AWI
              @shabba It looks like you are trying to build something to "pop your corn" on the shelf :smile:
                @shabba
                That picture makes me a bit worried... :sweat: Please don't let any kids near it.
                • C
                  C
                  ceech
                  wrote on last edited by ceech
                  #24
                  There is something similar I'm working on. Although mine is more like a solid state relay. And it can be used as an AC dimmer. But has the same concept with AC-DC converter. I used one from Vigortronix. It has a 3.3V output.
                  Here it is controlled with Bluetooth serial connection
                  This is how the board looks like
                  If anyone wants it, let me know.
                  @aproxx I like your form factor. Great find with that AC-DC converter.
                  • Roberto BrunialtiR
                    Roberto BrunialtiR
                    Roberto Brunialti
                    Those are even much smaller (3.3v , 25x38x17 mm , 3w) and have similar price. I've got one (still to experiment with)
                    https://it.rs-online.com/web/p/alimentatori-switching-integrati-smps/8431988/?searchTerm=8431988&relevancy-data=636F3D3126696E3D4931384E525353746F636B4E756D6265724D504E266C753D656E266D6D3D6D61746368616C6C26706D3D5E5C647B367D247C5E5C647B377D247C5E5C647B31307D2426706F3D313426736E3D592673743D52535F53544F434B5F4E554D4245522677633D4E4F4E45267573743D3834333139383826
                      Too bad these Ac Dc are so expensive and little big. But good quality for sure.
                      @ceech : looks like a pretty board. I am interested in your files please. It could be useful..:wink:
                      C 1 Reply Last reply
                      • scalzS scalz
                        C
                        C
                        ceech
                        @scalz Here you go:
                        https://github.com/ceech/AC-dimmer
                        Enjoy.
                          thank you!
                            shabba
                            @aproxx Where could one get that board and what is required to populate it? I would like perhaps half a dozen or so for a few things I'm doing and to replace the mess in the picture I posted above :-)
                            • sundberg84S
                              sundberg84S
                              This is really interesting.
                              If this PCB succeeds i will order maybe 10-15 of them. They need to be so small it can be mounted inside/behind the wallswitch and i also want to combine it with some sort of motion detector fittet in the wallswitch as well...
                              Cool really looking forward to this... keep up the good work!
                              • A
                                aproxx
                                @Jan-Gatzke You are absolutely right. No idea on why I've never thought about that!
                                I have now redesigned the board to fit a relay as well. Size is still limited to 45 by 45mm, so it should be quite easy to place them behind a light switch.
                                I hope to receive my PCB boards next week, after which I'll add all components to the board and start testing it. If all goes well, I'll be submitting the new design with relay to dirtyPCBs to have those printed too.
                                Just a sneak peak of the new board:
                                Top:
                                Bottom:
                                In the following days I'll start designing a 3d-printable casing to fit the board.
                                As soon as I have confirmed that the board with relay is working fine, I'll submit the PCB design here together with the 3d printable casing. Due to slow shipping and limited spare time I expect this to happen in about 4 to 7 weeks.
                                • sundberg84S
                                  sundberg84S
                                  #32
                                  YES - this is really what im looking for!! :)
                                  Well done @aproxx - i will follow this closely.
                                  If you have the space - the pcb could have a input/hole for an external sensor to pin 3 (if unused or another one). so you can add say external motion sensor or temp as well.
                                  Can you list the parts so there is a possibility to start ordering those?
                                  • A
                                    aproxx
                                    @sundberg84 Thanks for the kind words!
                                    The new design (with relay) indeed has a few digital pins available. I've included the following in this design:
                                    • 4 digital in and output pins. Pin 3, 4, 5 and 6. Pin 3 is also used to switch the relay, so 3 other digital pins are available to connect other things like motion sensors and switches.
                                    • 1 Analog input pin. Pin A0.
                                    • 2 5v pins.
                                    • 2 Ground pins.
                                    • A few extra empty pins which aren't connected to anything, but can be used to add some custom things if needed.
                                    Bill of materials is available below, together with Gerber files, and DIP file (as I'm using Diptrace to design my PCBs).
                                    Please keep in mind that this is only my second time designing PCBs, so if you'd like to be 100% sure it works I would recommend to wait until I've tested the board and confirmed that everything is working fine.
                                    But feedback is always welcome!
                                    Mysensors v2.1 UNTESTED.rar
                                    J 1 Reply Last reply
                                    • A aproxx
                                      • 2 5v pins.
                                      • 2 Ground pins.
                                      J
                                      J
                                      Jan Gatzke
                                      #34
                                      @aproxx Looks great so far. I am missing a diode and snubber components around the relay. Or are those just not visible? Didn't have a look at the files, yet. In another thread someone posted a diy solid state relay with triacs. This would be a little bit smaller than the relay and would less likely fail. I would add a fuse in front of the power supply, too.
                                      I will definitly have a look at Diptrace. I like those 3D previews. :)
                                      • A
                                        aproxx
                                        @Jan Gatzke There is a diode in place, but it just isn't visible in that current 3D design. I've used following schematic (minus the LED) to connect the relay to pin 3 of the Arduino :
                                        What do you mean by "less likely to fail" about these relays? I've been using them for a while now, but never had any issues with these. Or do you think that they might show this problem when using them for a long time?
                                        • J
                                          J
                                          Jan Gatzke
                                          Yes, relays are mechanical parts. Cheap ones are likely to fail over time. The missing snubber protection in your circuit will kill them, too when connecting inductive loads.
