  3. Parking Sensor
Parking Sensor
74 Posts 28 Posters 55.3k Views 18 Watching
    wrote on last edited by hek
    I've created a parking sensor of my NeoPixel led ring and a distance sensor.
    You can also send the parking status to your controller if you'd like.
    Components
    http://www.ebay.com/itm/371353140878?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
    http://www.ebay.com/itm/1pcs-Ultrasonic-Module-HC-SR04-Distance-Measuring-Transducer-Sensor-for-Arduino-/251546073420?hash=item3a9150794c
    https://youtu.be/ykfTKI7a-H4
    Code:
    https://codebender.cc/sketch:138368
    RJ_MakeR 1 Reply Last reply
      Video added
        Components
        Code:
        RJ_MakeR
        RJ_MakeR
        RJ_Make
        @hek That is awesome!
        RJ_Make
          Excellent!
            Video added
            Moshe LivneM
            Moshe LivneM
            Moshe Livne
            @hek Ultra cool!!!!
            • DrJeffD
              DrJeffD
              DrJeff
              @hek Cool I figured you would come up with a practicle use for that LED ring! :smile:
              • TD22057T
                TD22057T
                TD22057
                OK - that is very cool. My wife has just decided we have to have this (after she lightly crushed one of my garage cabinets of course).
                • mikeeM
                  mikeeM
                  mikee
                  Really cool project, I´m ordering today :)
                  • rvendrameR
                    rvendrameR
                    rvendrame
                    awesome!
                    ESP8266 GW + mySensors 2.3.2
                    Alexa / Google Home
                    • Sander StolkS
                      Sander StolkS
                      Sander Stolk
                      Awesome project but will the led always be on when your car is parked?
                      Or is there a timeout after the measurement to switch it of?
                      hekH 1 Reply Last reply
                      • Sander StolkS Sander Stolk
                        @Sander-Stolk
                        Ha, yes, didn't think of that little detail.
                        Guess you could add a timeout which turns off the leds after a minute when "parked".
                        • Lawrence HelmL
                          Lawrence HelmL
                          Lawrence Helm
                          @hek About to make this sensor, very cool! I had already brought a 12v traffic light before I saw this, so now ordered an LED ring, as that makes a lot more sense getting closer to the target area. But could you help out regarding the implementation of the timeout, as I'm pretty terrible at programing :)
                          C 1 Reply Last reply
                          • R
                            R
                            ramarro
                            Super :+1: :clap:
                            • T
                              the_iman
                              Great! This will be my first project with Arduino!
                              Could you, please, post the wiring schematics.
                                http://www.mysensors.org/build/parking
                                • Lawrence HelmL Lawrence Helm
                                  C
                                  C
                                  chilump
                                  @hek Great Job. Just wondering if you could point us to instructions on to add the time out feature.
                                    My rig is disassembled now.
                                    You could add timeout like this (please feedback if it works so I can check it into github):
                                     * Version 1.0 - Created by Henrik Ekblad
                                     * Parking sensor using a neopixel led ring and distance sensor (HC-SR04).
                                     * Configure the digital pins used for distance sensor and neopixels below.
                                     * NOTE! Remeber to feed leds and distance sensor serparatly from your Arduino.
                                     * It will probably not survive feeding more than a couple of LEDs. You
                                     * can also adjust intesity below to reduce the power requirements.
                                     * Sends parking status to the controller as a DOOR sensor if SEND_STATUS_TO_CONTROLLER
                                     * is defined below. You can also use this _standalone_ without any radio by
                                     * removing the SEND_STATUS_TO_CONTROLLER define.
                                    #define SEND_STATUS_TO_CONTROLLER  // Put a comment on this line for standalone mode
                                    #include <Adafruit_NeoPixel.h>
                                    #include <NewPing.h>
                                    #ifdef SEND_STATUS_TO_CONTROLLER
                                    #define NEO_PIN      4 // NeoPixels input pin
                                    #define TRIGGER_PIN  6  // Arduino pin tied to trigger pin on the ultrasonic sensor.
                                    #define ECHO_PIN     5  // Arduino pin tied to echo pin on the ultrasonic sensor.
                                    #define NUMPIXELS      24 // Number of nexpixels in ring/strip
                                    #define MAX_INTESITY   20  // Intesity of leds (in percentage). Remeber more intesity requires more power.
                                    // The maximum rated measuring range for the HC-SR04 is about 400-500cm.
                                    #define MAX_DISTANCE 100 // Max distance we want to start indicating green (in cm)
                                    #define PANIC_DISTANCE 5 // Mix distance we red warning indication should be active (in cm)
                                    #define PARKED_DISTANCE 20 // Distance when "parked signal" should be sent to controller (in cm)
                                    #define PARK_OFF_TIMEOUT 20000 // Number of milliseconds until turning off light when parked.
                                    // Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest
                                    // example for more information on possible values.
                                    Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, NEO_PIN, NEO_GRB + NEO_KHZ400);
                                    NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
                                    #define CHILD_ID 1
                                    unsigned long sendInterval = 5000;  // Send park status at maximum every 5 second.
                                    unsigned long lastSend;
                                    int oldParkedStatus=-1;
                                    unsigned long blinkInterval = 100; // blink interval (milliseconds)
                                    unsigned long lastBlinkPeriod;
                                    bool blinkColor = true;
                                    // To make a fading motion on the led ring/tape we only move one pixel/distDebounce time
                                    unsigned long distDebounce = 30;
                                    unsigned long lastDebouncePeriod;
                                    int numLightPixels=0;
                                    int skipZero=0;
                                      Serial.println("Starting distance sensor");
                                      pixels.begin(); // This initializes the NeoPixel library.
                                      Serial.println("Neopixels initialized");
                                      gw.begin();
                                      gw.sendSketchInfo("Parking Sensor", "1.0");
                                      gw.present(CHILD_ID, S_DOOR, "Parking Status");
                                      unsigned long now = millis();
                                      int fullDist = sonar.ping_cm();
                                    //  Serial.println(fullDist);
                                      int displayDist = min(fullDist, MAX_DISTANCE);
                                      if (displayDist == 0 && skipZero<10) {
                                        // Try to filter zero readings
                                        skipZero++;
                                        return;
                                      // Check if it is time to alter the leds
                                      if (now-lastDebouncePeriod > distDebounce) {
                                        lastDebouncePeriod = now;
                                        // Update parked status
                                        int parked = displayDist != 0 && displayDist<PARKED_DISTANCE;
                                        if (parked != oldParkedStatus && now-lastSend > sendInterval) {
                                          if (parked)
                                            Serial.println("Car Parked");
                                            Serial.println("Car Gone");
                                          gw.send(msg.set(parked));
                                          oldParkedStatus = parked;
                                          lastSend = now;
                                        if (parked && now-lastSend > PARK_OFF_TIMEOUT) {
                                          // We've been parked for a while now. Turn off all pixels
                                          for(int i=0;i<NUMPIXELS;i++){
                                            pixels.setPixelColor(i, pixels.Color(0,0,0));
                                          if (displayDist == 0) {
                                            // No reading from sensor, assume no object found
                                            numLightPixels--;
                                            skipZero = 0;
                                            int newLightPixels = NUMPIXELS - (NUMPIXELS*(displayDist-PANIC_DISTANCE)/MAX_DISTANCE);
                                            if (newLightPixels>numLightPixels) {
                                              // Fast raise
                                              numLightPixels += max((newLightPixels - numLightPixels) / 2, 1);
                                            } else if (newLightPixels<numLightPixels) {
                                              // Slow decent
                                              numLightPixels--;
                                          if (numLightPixels>=NUMPIXELS) {
                                            // Do some intense red blinking
                                            if (now-lastBlinkPeriod > blinkInterval) {
                                              blinkColor = !blinkColor;
                                              lastBlinkPeriod = now;
                                            for(int i=0;i<numLightPixels;i++){
                                              pixels.setPixelColor(i, pixels.Color(blinkColor?255*MAX_INTESITY/100:0,0,0));
                                              int r = 255 * i/NUMPIXELS;
                                              int g = 255 - r;
                                              // pixels.Color takes RGB values, from 0,0,0 up to 255,255,255
                                              pixels.setPixelColor(i, pixels.Color(r*MAX_INTESITY/100,g*MAX_INTESITY/100,0));
                                            // Turn off the rest
                                            for(int i=numLightPixels;i<NUMPIXELS;i++){
                                        pixels.show(); // This sends the updated pixel color to the hardware.
                                    Dan S.D 1 Reply Last reply
                                    • C
                                      C
                                      chilump
                                      Definitely, thanks
                                      • Andy PepA
                                        Andy PepA
                                        Andy Pep
                                        change the code a little bit and bingo you just made a light thermin .. cool for wearables :)
                                          #define CHILD_ID 1
                                          int skipZero=0;
                                            gw.begin();
                                              skipZero++;
                                              return;
                                                if (parked)
                                                lastSend = now;
                                                  numLightPixels--;
                                                  skipZero = 0;
                                                    // Fast raise
                                                    // Slow decent
                                                    numLightPixels--;
                                                    int g = 255 - r;
                                          Dan S.D
                                          Dan S.D
                                          Dan S.
                                          @hek Received my LED ring in the mail over the weekend. Hooked it up and ran your code. Everything looks to be working great, including the timeout code. Now need to mount and test under real world conditions, i.e,. in the garage with the car. Has anyone done that yet?
                                          M TD22057T C 3 Replies Last reply
