  3. ESP8266 gateway and sensor node not talking - noobie
megadht11esp8266
37 Posts 6 Posters 21.5k Views 4 Watching
  • pwatt01P
    pwatt01P
    pwatt01
    Hello all,
    I just had all of my parts arrive and are builing my contoller and first sensor (DHT11 on MEGA clone). After flashing both (using the development build), they both seem to be working according to the serial monitor, but i cannot seem to make them talk to each other!
    Can anyone help me out? I am using the examples on both the gateway and node.
    Here is the output from the gateway after pressing reset:
    0‚~?–4“Ò¶£ÿOAaû0;0;3;0;9;Starting...
    scandone
    f 0, ....scandone
    .add 0
    aid 4
    pm open phy_2,type:2 0 0
    cnt
    connected with <ssid>, channel 1
    ip:192.168.1.200,mask:255.255.255.0,gw:192.168.1.254
    .IP: 192.168.1.200
    this is from the sensor node:
    Starting...
    find parent
    send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
    find parent
    read: 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    find parent
    find parent
    find parent
    sensor started, id=255, parent=255, distance=255
    T:21.00
    find parent
    H:36.00
    find parent
    and here is the log from domotitz
    2015-10-29 07:11:37.529 Domoticz V2.3347 (c)2012-2015 GizMoCuz
    2015-10-29 07:11:37.529 Build Hash: b835f24, Date: 2015-10-15 03:16:03
    2015-10-29 07:11:37.554 Sunrise: 05:48:00 SunSet:19:10:00
    2015-10-29 07:11:37.554 EventSystem: reset all events...
    2015-10-29 07:11:37.561 Active notification subsystems: (0/10)
    2015-10-29 07:11:37.657 Webserver started on port: 8080
    2015-10-29 07:11:37.662 Started shared server on: ::
    2015-10-29 07:11:37.720 Incoming connection from: 127.0.0.1
    2015-10-29 07:11:39.666 EventSystem: reset all events...
    2015-10-29 07:11:39.667 EventSystem: reset all device statuses...
    2015-10-29 07:11:39.667 EventSystem: Started
    2015-10-29 07:11:41.672 MySensors: connected to: 192.168.1.200:5003
    2015-10-29 07:11:41.672 MySensors: Gateway Ready...
    2015-10-29 07:11:42.366 Login successfull : user 'admin'
    • pwatt01P
      pwatt01P
      pwatt01
      OK.. i think after looking a bit more they are talking.. however there are a few issues and they are not understanding each other or somehitng. I remember reading before that there is a way to flash the device back to stock/wipe the EEPROM. DOes anyone know the link to that?
        What does the gateway log say when you restart the sensor?
        • pwatt01P
          pwatt01P
          pwatt01
          Nothing. Or no change at least. The shots above are still the only messages that I am getting, apart from the ESP8266 rebooting by itself occasionaly, and the sensor node tends to repeat itself as new readings come in
            Mersing
            I've setup a ESP8266 Gateway with RF24 Radio.
            I've got a RF24 Node with DS18B20.
            I'ved used Esp8266Gateway.ino / DallasTemperatureSensor.ino out of the box.
            Everything is working fine. Node and GW are communicating.
            I'm now trying to run this setup with RF69. I'm facing the same issue as described in the initial post.
            Pin mapping
            RF69 <-> ESP8266
            DIO0 <-> GPIO4
            SCK <-> GPIO14
            MOSI <-> GPIO13
            MISO <-> GPIO12
            CS <-> GPIO15
            From RFM69.h
            define RF69_SPI_CS               SS
            #elif defined(ARDUINO_ARCH_ESP8266)
              // TODO !! Untested code! Entering unknown territory...
              #define RF69_IRQ_PIN          4
              #define RF69_IRQ_NUM          0
            By default, from RFM69.h, RF69_IRQ_PIN is 2.
            However to properly boot GPIO15 must be LOW and GPIO2 must be HIGH.
            Connecting IRQ to GPIO2, RF69 pull its IRQ to LOW, making GPIO2 LOW and ESP8266 not booting.
            Then I'll use GPIO4.
            I'm using the same config file for GW and Node (e.g same NWETWORKID, ENCRYPTKEY, FREQUENCY).
            On the Node Side : DallasTemperatureSensor.ino
            #define isRFM69HW true // Enable High Power
            MyTransportRFM69 transport( RFM69_FREQUENCY, RFM69_NETWORKID, RF69_SPI_CS, RF69_IRQ_PIN, isRFM69HW, RF69_IRQ_NUM );
            MySensor gw( transport );
            gw.begin( NULL, 8 );
            On the GW Side : Esp8266Gateway.ino
            MyTransportRFM69 transport(RFM69_FREQUENCY, RFM69_NETWORKID, RF69_SPI_CS, RF69_IRQ_PIN, isRFM69HW, RF69_IRQ_NUM);
            OUTPUT
            GW Side
            ESP8266 MySensors Gateway
            Connecting to WRT54G
            .......Connected!
            IP: 192.168.1.25
            Node
            send: 8-8-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=fail:1.5
            send: 8-8-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:0
            sensor started, id=8, parent=0, distance=1
            send: 8-8-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,st=fail:Temperature Sensor
            send: 8-8-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=fail:1.1
            send: 8-8-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=fail:
            send: 8-8-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=fail:21.5
            find parent
            send: 8-8-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
            No more log output from the Gateway.
            Any clue ?
              Mersing
              I received addition log on the GW:
              .......Connected!
              IP: 192.168.1.25
              0;0;3;0;9;Inclusion started by button.
              0;0;3;0;5;1
              0;0;3;0;5;0
              "Inclusion started by button." are coming randomly (not triggered by node reboot ).
                Guys, would be great if you used the development branch instead.
                Really need more testers of that code... also and any fixes for ESP8266/RF69 would be done in the dev-branch.
                  Mersing
                  I'm now testing with 1.6, on GW and Node.
                  I'm trying to get familiar with the 1.6 changes.
                  On the node how can I setup the NODE ID ? ( it seems that gw.begin( NULL, 5) can't be used anymore).
                  On the Node side, I'm using DallasTemperatureSensor.ino.
                  Should I add presentation() call from Setup () ?
                  void setup()   {
                    sensors.begin();
                    presentation();
                  I've setup the communication with RF24, as a first test.
                  From the GW
                  0;0;3;0;9;read: 5-5-0 s=255,c=0,t=17,pt=0,l=10,sg=0:1.6.0-beta
                  0;0;3;0;9;read: 5-5-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                  0;0;3;0;9;read: 5-5-0 s=255,c=3,t=11,pt=0,l=18,sg=0:Temperature Senso
                  0;0;3;0;9;read: 5-5-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
                  0;0;3;0;9;read: 5-5-0 s=0,c=0,t=6,pt=0,l=0,sg=0:
                  0;0;3;0;9;read: 5-5-0 s=0,c=1,t=0,pt=7,l=5,sg=0:23.6
                  0;0;3;0;9;read: 5-5-0 s=0,c=1,t=0,pt=7,l=5,sg=0:23.7
                  Everything is working fine. (Seems the Node ID is coming from previous 1.5 upload, I've setup it to 5)
                  I've then replaced the radio by RF69 ones.
                  Below the changes in GatewayESP8266.ino
                  #define MY_RADIO_RFM69
                  #define MY_RF69_IRQ_PIN 4
                  Node ouput
                  Starting...
                  send: 5-5-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=fail:1.6.0-beta
                  send: 5-5-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:0
                  send: 5-5-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,st=fail:Temperature Sensor
                  send: 5-5-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=fail:1.1
                  sensor started, id=5, parent=0, distance=1
                  find parent
                  send: 5-5-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
                  send: 5-5-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=fail:
                  send: 5-5-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=fail:22.5
                  send: 5-5-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=fail:22.6
                  GW Output
                  scandone
                  f 0, ....scandone
                  .add 0
                  aid 7
                  cnt
                  connected with WRT54G, channel 6
                  dhcp client start...
                  .ip:192.168.1.25,mask:255.255.255.0,gw:192.168.1.1
                  .IP: 192.168.1.25
                  sl
                  f -240, ....scandone
                  usl
                  sul 7 0
                  reconnect
                  rm 0
                  pm close 7 0 0/3399505
                  f 0, ....scandone
                  .add 0
                  aid 7
                  cnt
                  ..ip:192.168.1.25,mask:255.255.255.0,gw:192.168.1.1
                  .Connected!
                  IP: 192.168.1.25
                  Nothing more on the GW side.
                  Any idea ? Where (lib) can I start troubleshooting ?
                  Regards.
                    Set static id with:
                    #define MY_NODE_ID xx
                    My guess is something goes wrong here:
                    https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/drivers/RFM69/RFM69.cpp#L47
                      Mersing
                      I had a look at RFM69.cpp, bool RFM69::initialize function.
                      It a bit far away from my current skill to debug.
                      I've tried to display registers to check if they have been properly initialized.
                        Serial.println( "bool RFM69::initialize" );
                        Serial.println( "Read Registers" );
                        Serial.print( "RegOpMode Read 0x01 : " );
                        Serial.println( readReg( 0x01) );
                        Serial.print( "RegDataModul Read 0x02 : " );
                        Serial.println( readReg( 0x02) );
                        Serial.print( "RegVersion Read 0x10 : " );
                        Serial.println( readReg( 0x10) );
                        Serial.print( "RegRssiValue Read 0x24) : " );
                        Serial.println( readReg( 0x24) );
                        Serial.println( "" );
                      Output is
                      Read Registers
                      RegOpMode Read 0x01 : 4
                      RegDataModul Read 0x02 : 0
                      RegVersion Read 0x10 : 36
                      RegRssiValue Read 0x24) : 56
                      scandone
                      f 0, ....scandone
                      .add 0
                      aid 7
                      cnt
                      Seems the registers are OK. However I can't go a step further.
                      I'm please to help for testing any new enhancement.
                      Regards,
                      Mersing.
                        Hmm... I should really order a few RFM69 radios myself.
                        I only have a couple of Moteions. Doesn't help much if I would help out debugging ESP8266 with RFM69.
                          Mersing
                          You could maybe hack / re-use the radio from the Motino :smiley:
                            Na... just have to wait for the china slow boat. Should be here before christmas :zzz:
                            • F
                              F
                              Fabien
                              I have same bug : http://forum.mysensors.org/topic/2538/esp8266-and-rfm69w-loop-reboot
                                Are you getting the same error in dev branch?
                                • F
                                  F
                                  Fabien
                                  With the last git developpement it works. except when a node start presentation, gateway reboot. And sometimes it reboots randomless.
                                  node is a sensebender with MySensors 1.6 and gateway with 1.6 too.
                                  Important : You have to define MY_RF69_IRQ_NUM = MY_RF26_IRQ_PIN on ESP8266
                                  #define MY_RF69_IRQ_PIN 15
                                  #define MY_RF69_SPI_CS 2
                                  #define MY_RF69_IRQ_NUM 15
                                  Result is
                                  connected with PandoraBox_1BB657, channel 1
                                  .ip:192.168.2.165,mask:255.255.255.0,gw:192.168.2.1
                                  .IP: 192.168.2.165
                                  0;0;3;0;9;Init complete, id=0, parent=0, distance=0
                                  chg_B:-120
                                  Soft WDT reset
                                  ctx: cont
                                  sp: 3ffef9a0 end: 3ffefc60 offset: 01b0
                                  >>>stack>>>
                                  3ffefb50:  00000001 3ffefd00 3ffeff68 00000001
                                  3ffefb60:  00000024 3ffefd00 3ffeff68 402022f2
                                  3ffefb70:  3ffe8496 00000000 3ffefd00 40202378
                                  3ffefb80:  3ffe8496 00000000 3ffefd00 40202563
                                  3ffefb90:  3ffefd1e 00000001 3ffefd00 40202a43
                                  3ffefba0:  3fffdc20 00000000 3ffeec28 3ffefcd8
                                  3ffefbb0:  3fffdc20 3ffefd1d 3ffefd00 40202e0c
                                  3ffefbc0:  40209c8d 00000000 3ffeec28 40203ed1
                                  3ffefbd0:  00000000 00000002 3ffefe58 402039d0
                                  3ffefbe0:  00000000 3ffefd00 3ffeff68 40202338
                                  3ffefbf0:  40101500 402059d6 3ffeff50 3ffefc20
                                  3ffefc00:  3ffefc10 00000004 3ffefcf9 40202358
                                  3ffefc10:  3fffdc20 00000000 00000000 3ffeec30
                                  3ffefc20:  3fffdc20 00000000 3ffeec28 3ffeec30
                                  3ffefc30:  3fffdc20 00000000 3ffeec28 40203aee
                                  3ffefc40:  00000000 00000000 3ffeec28 402041a0
                                  3ffefc50:  00000000 00000000 3ffeec40 40100114
                                  <<<stack<<<
                                  �!�L�<1���0;0;3;0;9;Starting gateway (RRNGE-, 1.6.0-beta)
                                  0;0;3;0;9;Radio init successful.
                                  scandone
                                  state: 0 -> 2 (b0)
                                  .state: 2 -> 3 (0)
                                  state: 3 -> 5 (10)
                                  add 0
                                  aid 3
                                  cnt
                                  chg_B:-60
                                  .IP: 192.168.2.165
                                  chg_B:-120
                                  0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.6
                                  0;0;3;0;9;read: 1-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0:51
                                  0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.4
                                  And something strange, I only recieve Humidity one time. (sensebender defaut sketch with FORCE_TRANSMIT_INTERVAL 0 )
                                  • F
                                    F
                                    Fabien
                                    wrote on last edited by Fabien
                                    @hek you are right it works fine with
                                    #define TIME_OUT 500
                                    in https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/drivers/RFM69/RFM69.cpp#L47
                                    0�~?�4�!�{�OAa�0;0;3;0;9;Starting gateway (RRNGE-, 1.6.0-beta)
                                    scandone
                                    state: 0 -> 2 (b0)
                                    .state: 2 -> 3 (0)
                                    state: 3 -> 5 (10)
                                    add 0
                                    aid 3
                                    cnt
                                    chg_B:-60
                                    .IP: 192.168.2.165
                                    chg_B:-120
                                    0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.8
                                    0;0;3;0;9;read: 1-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0:54
                                    0;0;3;0;9;read: 1-1-0 s=255,c=0,t=17,pt=0,l=10,sg=0:1.6.0-beta
                                    0;0;3;0;9;read: 1-1-0 s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFFFF0300
                                    0;0;3;0;9;read: 1-1-0 s=255,c=3,t=11,pt=0,l=17,sg=0:Sensebender Micro
                                    0;0;3;0;9;read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.4
                                    0;0;3;0;9;read: 1-1-0 s=2,c=0,t=7,pt=0,l=0,sg=0:
                                    0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.7
                                    0;0;3;0;9;read: 1-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0:50
                                    0;0;3;0;9;Client 0 connected
                                    0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.5
                                    I don't try with other timeout values.
                                      Ok, great. We need to increase timeout then.
                                      • F
                                        F
                                        Fabien
                                        @hek Yes and perhaps a feature to set MY_RF69_IRQ_NUM = MY_RF26_IRQ_PIN when using ESP8266. Do You want to test other timeout values ? Is it critical ?
                                          @Fabien said:
                                          MY_RF26_IRQ_PIN
                                          I cannot find this defined anywhere...
