  3. Scrolling Text sensor node with new V_TEXT
51 Posts 17 Posters 36.0k Views 13 Watching
  • F
    F
    fleinze
    Wow, I so want to build this!
    • B billy123
      I think i found them
      http://www.aliexpress.com/store/product/1pc-MAX7219-dot-matrix-module-microcontroller-module-4-in-one-display/1182157_32432589557.html
      AWIA
      AWIA
      AWI
      @billy123 That would be the right one. You can use most of the max7219 driven display. Sometimes these are 90 deg rotated but that can be adjusted in the library. Have fun!
      • HoffanH
        HoffanH
        Hoffan
        Will this work in Vera??
        AWIA 1 Reply Last reply
        • HoffanH Hoffan
          AWIA
          AWIA
          AWI
          @Hoffan I don't know the abilities of VERA but since this (V_TEXT) is new functionality I expect it works only in Domoticz. I hope the functionality will be extended to the other controllers soon..
          • HoffanH
            HoffanH
            Hoffan
            Thanx for the answer, I hope that too
            • D
              Dheeraj
              found this library for scrolling effect https://code.google.com/p/arudino-maxmatrix-library/.
              • D Dheeraj
                AWIA
                AWIA
                AWI
                @Dheeraj I have tried this library also but it did not suit my purpose. Only one type of display orientation is supported but it is easier to comprehend.
                • N
                  N
                  NotYetRated
                  Umm, this is awesome! Looks like I have a tinker project coming up!
                  • P
                    P
                    popunonkok
                    Looks great. Is it posible (Or do you think it will be) to sen dynamic values to the display from Domoticz? Like the temperature or soil moist procentage.
                    • P popunonkok
                      AWIA
                      AWIA
                      AWI
                      @popunonkok it is very possible. In fact this is what I'm doing. You need to work on the controller side. For domoticz you can use a lua time script which sends new text every x time. For long messages you will need to script a fifo with multiple text messages.
                      • GertSandersG
                        GertSandersG
                        GertSanders
                        Is it possible to send text to the node without a request call from the node itself?
                        The example is not clear on this point and the json example only sets the text value within Domoticz, right?
                        • GertSandersG GertSanders
                          AWIA
                          AWIA
                          AWI
                          @GertSanders Domoticz does not "push" the Text value when changed. The published sketch "asks" periodically for the Text value. What I do now is create a Switch (S_BINARY/ light) with function "New text available". This switch triggers the polling sequence.
                          • GertSandersG
                            GertSandersG
                            GertSanders
                            @GizMoCuz : It would be nice to be able to define the text of the S_INFO sensor in de UI of Domoticz, instead of only via json. I'm not capable of programming that myself, but it would make the use of text easier. I already log all incoming SMS messages into my SMS connected sensor in V_TEXT and have it this way a nice view on what nodes are sending to my SMS passthrough node or what SMS messages are received into my MySensors network. I know Domoticz has it's own SMS interface, but my node is capable of switching on stuff based on directly received SMS commands, and with V_TEXT I can now follow what is happening without needing a serial connection to the node. I should be clear that I'm a big fan of Domoticz :-)
                            • J
                              J
                              Jager
                              You can send messages as done here? http://forum.mysensors.org/topic/1957/lcd-clock-and-text-sensor-node-with-new-v_text
                              • J Jager
                                AWIA
                                AWIA
                                AWI
                                @Jager If your controller supports it you can. In Domoticz the text value is not pushed so you need to make a request for it.
                                • HoffanH
                                  HoffanH
                                  Hoffan
                                  What am i missing, Because i get this when i try to compile it
                                  Arduino:1.6.5 (Mac OS X), Kort:"Arduino Nano, ATmega328"
                                  ScrollingText:55: error: 'V_TEXT' was not declared in this scope
                                  ScrollingText.ino: In function 'void setup()':
                                  ScrollingText:166: error: 'S_INFO' was not declared in this scope
                                  ScrollingText:170: error: 'V_TEXT' was not declared in this scope
                                  ScrollingText.ino: In function 'void loop()':
                                  ScrollingText:191: error: 'V_TEXT' was not declared in this scope
                                  ScrollingText.ino: In function 'void incomingMessage(const MyMessage&)':
                                  ScrollingText:210: error: 'V_TEXT' was not declared in this scope
                                  • HoffanH Hoffan
                                    AWIA
                                    AWIA
                                    AWI
                                    @Hoffan V_TEXT is still in the development branch...
                                    • HoffanH
                                      HoffanH
                                      Hoffan
                                      Okey, That can explain, Byt when i use the Dev Branch
                                      I get this Errors
                                      ScrollingText:52: error: 'MyTransportNRF24' does not name a type
                                      ScrollingText:53: error: 'MySensor' does not name a type
                                      ScrollingText:163: error: 'gw' was not declared in this scope
                                      ScrollingText:177: error: 'gw' was not declared in this scope
                                      • HoffanH Hoffan
                                        I get this Errors
                                        AWIA
                                        AWIA
                                        AWI
                                        @Hoffan you best read the instructions for the development branch. The syntax changed a little. I'm typing on a phone right now. Best to search yourself
                                          wrote on last edited by hek
                                          #24
                                          How to convert a sketch to 1.6 is described here (until it has been posted somewhere more sticky..) :
                                          https://docs.google.com/document/d/1NKq5uuNdnxF5jWnum7VT32mbKLjuvqlx2A5D1qQ-H3Q/edit#heading=h.t5sdmpn6jz2i
                                          Basically a few search/replace... The above sketch would look something like this (untested)
                                           PROJECT: MySensors / Scrolling Text display
                                           PROGRAMMER: AWI
                                           DATE: september 12, 2015/ last update: september 12, 2015
                                           FILE: AWI_scroll_MAX.ino
                                           LICENSE: Public domain
                                           Hardware: tbd ..Ceech - ATmega328p board w/ NRF24l01
                                              and MySensors 1.5 ()
                                          Special:
                                              Need to use MySensors development edition
                                          SUMMARY:
                                              3 S_xx devices for scrolling text
                                              - Displays a scrolling text from a "V_TEXT" variable
                                              - additional dimmer sensor for controlling display brightness
                                              - 'Alarm' switch. If "On", overrides the text display to display ALARM message
                                              - You can also input messages from the Serial monitor (testing)
                                              Uses excellent MD_MAX72XX library
                                           Remarks:
                                              Fixed node-id
                                          // Use the MD_MAX72XX library to scroll text on the display with the use of the callback function
                                          // to control what is scrolled on the display text.
                                          // You need to set the used display in the library MD_MAX72XX.h
                                          // User can enter text on the serial monitor and this will display as a
                                          // Speed for the display is controlled by a pot on SPEED_IN analog in.
                                          #include <MD_MAX72xx.h>                     // multipurpose library for MAX72xx diaplay driver  https://parola.codeplex.com/
                                          #include <MySensor.h>                       // Mysensor network
                                          #include <Time.h>                           //http://playground.arduino.cc/Code/Time
                                          #define USE_POT_CONTROL 0                   // enable Scroll speed  potentiometer
                                          #define PRINT_CALLBACK  0
                                          // Macro to simplify serial print
                                          #define PRINT(s, v) { Serial.print(F(s)); Serial.print(v); }
                                          // Define the number of devices we have in the chain and the hardware interface
                                          // need to be adapted to your setup
                                          const int MAX_DEVICES = 8 ;                 // number of 8x8 displays
                                          const int CLK_PIN = 7 ;                     // SPI like clock
                                          const int DATA_PIN = 8 ;                    // SPI like data
                                          const int CS_PIN = 6 ;                      // SPI like select
                                          // Parola is able to use SPI hardware interface, not testted in combination with MySensors
                                          // MD_MAX72XX mx = MD_MAX72XX(CS_PIN, MAX_DEVICES);
                                          // now use Arbitrary pins
                                          MD_MAX72XX mx = MD_MAX72XX(DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES); // instantiate one display chain
                                          // Scrolling parameters, you can attach normal potentiometer to A5, Vcc, Gnd
                                          #if USE_POT_CONTROL
                                          const int SPEED_IN = A5 ;
                                          const int SCROLL_DELAY = 20 ;               // in milliseconds
                                          #endif // USE_POT_CONTROL
                                          const int CHAR_SPACING = 1 ;                // pixels between characters
                                          // MySensors constants & variables
                                          const byte nodeId = 51 ;                    // MySensors fixed node id
                                          const byte messageCHILD = 8 ;               // Text from ControllerLCD
                                          const byte brightnessChild = 9 ;            // Brightness of display
                                          const byte alarmChild = 10 ;                // Display Alarm text (overrides normal text)
                                          boolean timeReceived = false ;              // Flag to indicate time received
                                          // Display constants & variables
                                          byte textBrightness = 1 ;                   // brightness of display (between 0 - MAX_INTENSITY (0xF)
                                          byte textOnOff = true ;                     // textOnOff = ! shutdown
                                          boolean textAlarm = false ;                 // Alarm (switch S_BINARY)
                                          // Global message buffers shared by MySensors and Scrolling functions
                                          const int BUF_SIZE = 25 ;                   // max payload for MySensors(NRF24l01)
                                          char curMessage[BUF_SIZE];                  // current displayed message
                                          char newMessage[BUF_SIZE];                  // next message to be displayed if available
                                          bool newMessageAvailable = false ;          // new message available flag
                                          uint16_t    scrollDelay;                    // in milliseconds
                                          // *** Definition and initialisation
                                          // define the MySensor network (1.5)
                                          // Initialize messages for sensor network
                                          MyMessage textMsg(messageCHILD, V_TEXT);    // message for Sending Text to Controller
                                          /* MD_MAX72XX functions: can be found in the documentation for the library,
                                           * no need to customtize callback & scroll routines (unless you want to...)
                                          uint8_t scrollDataSource(uint8_t dev, MD_MAX72XX::transformType_t t)
                                          // Callback function for data that is required for scrolling into the display
                                            static char       *p = curMessage;
                                            static uint8_t    state = 0;
                                            static uint8_t    curLen, showLen;
                                            static uint8_t    cBuf[8];
                                            uint8_t colData;
                                            // finite state machine to control what we do on the callback
                                            switch(state)
                                              case 0: // Load the next character from the font table
                                                showLen = mx.getChar(*p++, sizeof(cBuf)/sizeof(cBuf[0]), cBuf);
                                                curLen = 0;
                                                state++;
                                                // if we reached end of message, reset the message pointer
                                                if (*p == '\0')
                                                  p = curMessage;         // reset the pointer to start of message
                                                  if (newMessageAvailable)    // there is a new message waiting
                                                    strcpy(curMessage, newMessage);   // copy it in
                                                    newMessageAvailable = false;
                                                // !! deliberately fall through to next state to start displaying
                                              case 1: // display the next part of the character
                                                colData = cBuf[curLen++];
                                                if (curLen == showLen)                // end of character insert interchar space
                                                  showLen = CHAR_SPACING;
                                                  curLen = 0;
                                                  state = 2;
                                              case 2: // display inter-character spacing (blank column)
                                                colData = 0;
                                                curLen++;
                                                  state = 0;
                                              default:
                                                state = 0;
                                            return(colData);
                                          // Callback (not used here)
                                          void scrollDataSink(uint8_t dev, MD_MAX72XX::transformType_t t, uint8_t col){
                                          // Callback function for data that is being scrolled off the display
                                          #if PRINT_CALLBACK
                                              Serial.print("\n cb ");
                                              Serial.print(dev);
                                              Serial.print(' ');
                                              Serial.print(t);
                                              Serial.print(' ');
                                              Serial.println(col);
                                          // non-blocking text display to be used in loop (call frequently)
                                          void scrollText(void){
                                              static uint32_t prevTime = 0;
                                              if (millis()-prevTime >= scrollDelay){                  // Is it time to scroll the text?
                                                  mx.transform(MD_MAX72XX::TSL);                      // scroll along - the callback will load all the data
                                                  prevTime = millis();                                // starting point for next time
                                          // sets the scroll delay (read from potentiometer if enabled)
                                          uint16_t getScrollDelay(void){
                                          #if USE_POT_CONTROL
                                              uint16_t t = analogRead(SPEED_IN);
                                              t = map(t, 0, 1023, 25, 250);
                                              return(t);
                                              return(SCROLL_DELAY);
                                          void setup(){
                                              // set up the display first
                                              mx.begin();                                             // initialize display chain
                                              mx.setShiftDataInCallback(scrollDataSource);            // define function to get the scrolldata (returned as int8)
                                              //mx.setShiftDataOutCallback(scrollDataSink);           // not used
                                              mx.control(MD_MAX72XX::INTENSITY, 0x01);
                                          #if USE_POT_CONTROL                                         // initialize speed potentiometer if enabled
                                              pinMode(SPEED_IN, INPUT);
                                              scrollDelay = SCROLL_DELAY;
                                              strcpy(curMessage, "I \x03 MySensors ");                // first message on display
                                              newMessage[0] = '\0';                                   // new message initialized to empty
                                              // Setup MySensors
                                             //Serial in Sensor network = 115200
                                              //Send the sensor node sketch version information to the gateway
                                              sendSketchInfo("AWI Scroll MAX 51", "1.1");
                                              present(messageCHILD, S_INFO, "Text line Scroll");   // new S_type 20150905 (not know by domoticz)
                                              present(alarmChild, S_BINARY, "Alarm display");      // to display alarm text
                                              present(brightnessChild, S_DIMMER, "Text brightness"); // new S_type 20150905 (not know by domoticz)
                                              //send(textMsg.set("-"));                            // initialize the V_TEXT at controller for sensor to none (trick for Domoticz)
                                              request(messageCHILD, V_TEXT, 0);                    // request value from controller
                                              // Initializations
                                              requestTime();                            // get the time from controller (handled by receiveTime)
                                          // loop only uses non-blocking functions
                                              static unsigned long lastUpdate ;                       // Static hold the last update time
                                              unsigned long now = millis();
                                              scrollDelay = getScrollDelay();                         // update scroll delay from potentiometer
                                              readSerial();
                                              // Check for new conditions & ask for new information from controller every 10 seconds
                                              if (now-lastUpdate > 10000){
                                                  if (textAlarm){                                     // if alarmstatus: override all text and set max intensity
                                                      strcpy(curMessage, "   ALARM   ");
                                                      mx.control(MD_MAX72XX::INTENSITY, MAX_INTENSITY);   // set current brightness
                                                      mx.control(MD_MAX72XX::SHUTDOWN, false) ;
                                                  } else {                                            // standard (non Alarm actions)
                                                      mx.control(MD_MAX72XX::INTENSITY, textBrightness);  // set current brightness
                                                      mx.control(MD_MAX72XX::SHUTDOWN, textOnOff) ;
                                                      request(messageCHILD, V_TEXT, 0);                // request new value from controller
                                                  lastUpdate = now;
                                              scrollText();
                                              setTime(controllerTime);                                // time from controller
                                              timeReceived = true;
                                          // This is called when a message is received
                                              Serial.print("Message: "); Serial.print(message.sensor); Serial.print(", Message: "); Serial.println(message.getString());
                                              if (message.sensor == messageCHILD){
                                                  if (message.type==V_TEXT) {                     // Text content
                                                  strcpy(newMessage, message.getString());        // copy it in
                                                      newMessageAvailable = true ;
                                              } else if (message.sensor == alarmChild) {
                                                  if (message.type==V_STATUS) {                   // True/ false content
                                                      textAlarm = message.getBool()?true:false ;  // set alarmflag
                                                      Serial.print("TextAlarm: ");
                                                      Serial.println(textAlarm);
                                              } else if (message.sensor == brightnessChild){
                                                  if (message.type==V_PERCENTAGE) {               // Level 0..100  content
                                                      textBrightness = map(message.getInt(),0, 100, 0, MAX_INTENSITY ) ;  // map to brightnesslevel
                                                      Serial.print("TextBrightness: ");
                                                      Serial.println(textBrightness);
                                                  } else if (message.type==V_STATUS) {            // Display on/off
                                                      textOnOff = message.getBool()?false:true ;      // set shutdown/ !on/off
                                                      Serial.print("Text on/off: ");
                                                      Serial.println(textOnOff);
                                          // Testing purposes: input routine character buffer. Reads serial characters in buffer newMessage.
                                          // sets flag newMessageAvailable to true if completed
                                          void readSerial(void)
                                            static uint8_t    putIndex = 0;
                                            while (Serial.available())
                                              newMessage[putIndex] = (char)Serial.read();
                                              if ((newMessage[putIndex] == '\n') || (putIndex >= BUF_SIZE-3)) // end of message character or full buffer
                                                // put in a message separator and end the string
                                                newMessage[putIndex++] = ' ';
                                                newMessage[putIndex] = '\0';
                                                // restart the index for next filling spree and flag we have a message waiting
                                                putIndex = 0;
                                                newMessageAvailable = true;
                                                // Just save the next char in next location
                                                newMessage[putIndex++];
