  3. Home Assistant
  4. Home Assistant - How to recognize MySensors nodes
home assistant
64 Posts 7 Posters 55.1k Views 3 Watching
  • D drock1985
    Hi @martinhjelmare
    I decided to try this on a simplier sketch that I have, but still no luck. I added this line gw.send(lightMsgW.set("1")); to the end of void setup(). The sensor shows up at the top of the States screen in HA, but doesn't let me actually control it, and it doesn't show up in Switches or Lights.
    Here is the sketch that I am using.
     * Version 1.0 - 6-December-2015, Derrick Rockwell
     *This sketch uses two 30 bulb, 3mm LED holiday light strings. These
     *can usually be found in most dollar stores/hardware stores and are
     *battery powered. This sketch uses digital pins 3 and 4 to power two
     *a string of lights each. Ex, one can control white lights the other
     *could control multi-colour lights.
    #define SN "HolidayLEDDeskLights"
    #define SV "1.0"
    #define MLED_PIN 3      // Pin Multi-Coloured LED's will attached to
    #define WLED_PIN 5      // Pin White-Coloured LED's will attached to
    #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
    #define CHILD_ID0 3
    #define CHILD_ID1 5
    static int currentLevelM = 0;  // Current dim level...
    static int currentLevelW = 0;  // Current dim level...
    MyMessage dimmerMsgM(MLED_PIN, V_DIMMER);
    MyMessage lightMsgM(MLED_PIN, V_LIGHT);
    MyMessage dimmerMsgW(WLED_PIN, V_DIMMER);
    MyMessage lightMsgW(WLED_PIN, V_LIGHT);
     * Dimmable LED initialization method
      Serial.println( SN );
      Serial.println( SV );
      gw.begin( incomingMessage );
      // Register the LED Dimmable Light with the gateway
      gw.present( MLED_PIN, S_DIMMER );
      gw.present( WLED_PIN, S_DIMMER );
      gw.sendSketchInfo(SN, SV);
      // Pull the gateway's current dim level - restore light level upon sendor node power-up
      gw.request( MLED_PIN, V_DIMMER );
      gw.request( WLED_PIN, V_DIMMER );
     *  Dimmable LED main processing loop
    //For Multi Coloured Lights
    if (message.type == V_LIGHT || message.type == V_DIMMER) {
          // if (message.sensor <= 2)
              //0: All Dimmers
              //1: LED 1
              //2: LED 2
              if ((message.sensor == CHILD_ID0) || (message.sensor == 0)){
                fadeToLevel ( requestedLevel, MLED_PIN, &currentLevelM );
                gw.send(lightMsgM.set(requestedLevel > 0 ? 1 : 0));
                gw.send(dimmerMsgM.set(requestedLevel) );
              if ((message.sensor == CHILD_ID1) || (message.sensor == 0)){
                fadeToLevel( requestedLevel, WLED_PIN, &currentLevelW );
                gw.send(lightMsgW.set(requestedLevel > 0 ? 1 : 0));
                gw.send(dimmerMsgW.set(requestedLevel) );
     *  This method provides a graceful fade up/down effect
     // For Multi Coloured Lights
    void fadeToLevel( int toLevel, int pin, int *currentLevel ) {
      int delta = ( toLevel - (*currentLevel) ) < 0 ? -1 : 1;
      while ( (*currentLevel) != toLevel ) {
        (*currentLevel) += delta;
        analogWrite( pin, (int)((*currentLevel) / 100. * 255) );
        delay( FADE_DELAY );
    H
    H
    humblehacker
    @drock1985
    It looks like we're trying to do similar things with HA and MYS... I've been working on a rotary encoder switch for colored lights (eg Limitlessled/HUE etc...) and had been trying to program it through MQTT. However, I just now noticed the LEDDIMMERwithROTARYENCODER sketch in the MySensors examples so I thought I might try using MYS instead of MQTT. Of course that leads right back to the lack of support for MYS Switches in HASS... Perhaps there's a solution for both of our problems if we use an MQTT Gateway instead? I've worked with MQTT and NodeRED before and it was pretty straight forward, but then again I've been having a much harder time understanding the way its implemented in HASS... So I might need to work with it some more before I can be of any help testing the MQTT MYS Gateway with HA...
    • H humblehacker
      @drock1985
      martinhjelmareM
      martinhjelmareM
      martinhjelmare
      @humblehacker
      Hi!
      I also want to try the MQTT gateway together with HA. MQTT support is well supported in HA, and looking at the MQTT protocol in mysensors dev branch it looks promising. I have just got some ethernet modules and more nanos, so as soon as I find some time, I'll get started. We can post our progress somewhere here whoever gets it going first.
      • D
        drock1985
        wrote on last edited by drock1985
        #36
        @humblehacker @martinhjelmare
        Sounds like an interesting idea to me. I have never used a MQTT gateway before, so i'm going in a little blind. I think I have the server so far (mosquitto) running on the same RPI as my HA install; so now looking into the next step.
        One thing though, would this replace my current serial gateway, or be an addition to it?
        My Projects
        2 Door Chime Sensor
        Washing Machine Monitor
        • D
          drock1985
          I've been trying to get MQTT working using the Dev branch here (http://forum.mysensors.org/topic/2352/guide-setting-up-and-testing-mqtt-client-gateway/) and have my configuration.yaml file looking like this for my W5100MQTT broker:
          #MySensors MQTT Test
          mqtt 1:
            broker: 192.168.86.198
            port: 1883
          #  client_id: home-assistant-1
            keepalive: 60
          #  username: USERNAME
          #  password: PASSWORD
          The Serial output from Arduino shows that I connected successfully
          0;0;3;0;9;Starting gateway (RNNGA-, 1.6.0-beta)
          0;0;3;0;9;Radio init successful.
          IP: 192.168.86.112
          0;0;3;0;9;MQTT connected
          0;0;3;0;9;Init complete, id=0, parent=0, distance=0
          But, Home-Assistant isn't registering the broker, and I have this error in the Dev section:
          15-12-15 15:32:17 homeassistant.components.mqtt: Missing required configuration items in mqtt: broker
          15-12-15 15:32:17 homeassistant.bootstrap: component mqtt failed to initialize
          Does anyone have any ideas? @humblehacker @martinhjelmare @hek ?
          My Projects
          2 Door Chime Sensor
          martinhjelmareM H 2 Replies Last reply
            Sorry, havent tried HomeAssistant myself.
            • D
              drock1985
              Thanks @hek , had to ask :)
              Would it be possible to get a Home-Assistant dedicated sub-forum please?
              My Projects
              2 Door Chime Sensor
              • D drock1985
                mqtt 1:
                  port: 1883
                  keepalive: 60
                IP: 192.168.86.112
                martinhjelmareM
                martinhjelmareM
                martinhjelmare
                @drock1985
                What do you set MY_IP_GATEWAY_ADDRESS to on the arduino side?
                  You got it.
                  http://forum.mysensors.org/category/28/home-assistant
                  • D
                    drock1985
                    #42
                    Thanks @hek very appreciated.
                    EDIT: Sort of ran into an issue with the Dev MQTTW5100Gateway sketch.... Thought the output I was getting above was good, but in reality the Arduino IDE wasn't giving an error. I decided to run the gateway in my RPI and view the data through SSH via screen. It initializes and shows the same data as the Arduino IDE, but then seconds later it dies and gives an error about screen terminating. Happens every time.
                    Going to try the ESP8266MQTTGateway: I'm got a hunch.
                    My Projects
                    2 Door Chime Sensor
                    • D drock1985
                      mqtt 1:
                        port: 1883
                        keepalive: 60
                      IP: 192.168.86.112
                      H
                      H
                      humblehacker
                      wrote on last edited by humblehacker
                      #43
                      mqtt 1:
                        port: 1883
                        keepalive: 60
                      Does the IP address you defined in the config.yaml point to your Mosquitto Broker or the Arduino-Ethernet Shield? If it points to the Arduino afaik the point of the MQTTCLIENT Gateway is that it can be run as a client if you've already got a Mosquitto broker. Otherwise you would either need to remove mosquitto or forward it to a different port than the default 1883. If this was the case then HASS would be looking for a broker where none exists which is why it is missing configuration items...
                      D 1 Reply Last reply
                      • H
                        H
                        humblehacker
                        For the time being, I'm thinking of taking a different approach with my toggle switch... I'm thinking of simply defining the button output as a binary sensor which can then toggle between two predefined scenes. At least in my case, input only needs to go in one direction so there's no need to receive any data from the controller....
                        • H humblehacker
                          martinhjelmareM
                          martinhjelmareM
                          martinhjelmare
                          @humblehacker
                          FYI, my fifo_queue pull request has been merged with dev branch at pymysensors, so I'm hoping to be able to implement switch support for the mysensors component in homeassistant very soon.
                          H 1 Reply Last reply
                            @humblehacker
                            H
                            H
                            humblehacker
                            @martinhjelmare said:
                            @humblehacker
                            Thats great news! That should be a huge help with my plans for building an RGB Lighting controller based on the rotary_led_dimmer sketch! If I can ever figure out how to implement a simple toggle switch first...
                            • H humblehacker
                              mqtt 1:
                                port: 1883
                                keepalive: 60
                              drock1985
                              @humblehacker said:
                              k
                              mqtt 1:
                                port: 1883
                                keepalive: 60
                              @humblehacker
                              The configuration.yaml file I have pointed back to the local IP address, since Mosquitto and Home-Assistant are running on the same Pi.
                              So, you are saying that it should really be pointed back to the MQTT Gateway then? Still confusing to me.
                              My Projects
                              2 Door Chime Sensor
                              • H
                                H
                                humblehacker
                                Never mind then... As long as your using Mosquitto as your broker and the MQTT CLIENT Gateway (from the development branch) rather than the default MQTT Gateway sketch from- http://www.mysensors.org/build/mqtt_gateway then none of my earlier comments should apply... Basically I was saying that the default MYSensors MQTT Gateway is set up to function as a broker and would therefore conflict with any Mosquitto server running on the same port. The MQTT CLIENT Gateway (emphasis on CLIENT) from the development branch isnt set up as a broker so it shouldnt conflict with a Mosquitto installation.
                                • martinhjelmareM
                                  martinhjelmareM
                                  martinhjelmare
                                  It's still important to be wary about which ip address you assign where, so I think it was a good point.
                                  • D
                                    drock1985
                                    Well, I have Mosquitto and the Dev ClientMQTTESP gateway working, and is communicating fine. Now just trying to figure out the proper entry to add an item as.
                                    My Projects
                                    2 Door Chime Sensor
                                    • D
                                      drock1985
                                      Ok, just got it all setup and working great now. Time to see how relays will work......
                                      My Projects
                                      2 Door Chime Sensor
                                      • D
                                        drock1985
                                        Hey @martinhjelmare , I see HA was updated today; did your commits get added?
                                        My Projects
                                        2 Door Chime Sensor
                                        • D drock1985
                                          martinhjelmareM
                                          martinhjelmareM
                                          martinhjelmare
                                          @drock1985
                                          Hi!
                                          No, I've submitted a pull request, but I need to fix some things, and maybe change some of it. But hopefully it wont take too long.
                                          12.5k
