  3. Home Assistant
  4. Home Assistant - How to recognize MySensors nodes
home assistant
64 Posts 7 Posters 55.1k Views 3 Watching
  • D
    drock1985
    I've been trying to get MQTT working using the Dev branch here (http://forum.mysensors.org/topic/2352/guide-setting-up-and-testing-mqtt-client-gateway/) and have my configuration.yaml file looking like this for my W5100MQTT broker:
    #MySensors MQTT Test
    mqtt 1:
      broker: 192.168.86.198
      port: 1883
    #  client_id: home-assistant-1
      keepalive: 60
    #  username: USERNAME
    #  password: PASSWORD
    The Serial output from Arduino shows that I connected successfully
    0;0;3;0;9;Starting gateway (RNNGA-, 1.6.0-beta)
    0;0;3;0;9;Radio init successful.
    IP: 192.168.86.112
    0;0;3;0;9;MQTT connected
    0;0;3;0;9;Init complete, id=0, parent=0, distance=0
    But, Home-Assistant isn't registering the broker, and I have this error in the Dev section:
    15-12-15 15:32:17 homeassistant.components.mqtt: Missing required configuration items in mqtt: broker
    15-12-15 15:32:17 homeassistant.bootstrap: component mqtt failed to initialize
    Does anyone have any ideas? @humblehacker @martinhjelmare @hek ?
    My Projects
    2 Door Chime Sensor
    Washing Machine Monitor
    martinhjelmareM H 2 Replies Last reply
      Sorry, havent tried HomeAssistant myself.
      • D
        drock1985
        Thanks @hek , had to ask :)
        Would it be possible to get a Home-Assistant dedicated sub-forum please?
        My Projects
        2 Door Chime Sensor
        • D drock1985
          mqtt 1:
            port: 1883
            keepalive: 60
          IP: 192.168.86.112
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @drock1985
          What do you set MY_IP_GATEWAY_ADDRESS to on the arduino side?
            You got it.
            http://forum.mysensors.org/category/28/home-assistant
            • D
              drock1985
              wrote on last edited by drock1985
              #42
              Thanks @hek very appreciated.
              EDIT: Sort of ran into an issue with the Dev MQTTW5100Gateway sketch.... Thought the output I was getting above was good, but in reality the Arduino IDE wasn't giving an error. I decided to run the gateway in my RPI and view the data through SSH via screen. It initializes and shows the same data as the Arduino IDE, but then seconds later it dies and gives an error about screen terminating. Happens every time.
              Going to try the ESP8266MQTTGateway: I'm got a hunch.
              My Projects
              2 Door Chime Sensor
              • D drock1985
                mqtt 1:
                  port: 1883
                  keepalive: 60
                IP: 192.168.86.112
                H
                H
                humblehacker
                wrote on last edited by humblehacker
                #43
                mqtt 1:
                  port: 1883
                  keepalive: 60
                Does the IP address you defined in the config.yaml point to your Mosquitto Broker or the Arduino-Ethernet Shield? If it points to the Arduino afaik the point of the MQTTCLIENT Gateway is that it can be run as a client if you've already got a Mosquitto broker. Otherwise you would either need to remove mosquitto or forward it to a different port than the default 1883. If this was the case then HASS would be looking for a broker where none exists which is why it is missing configuration items...
                D 1 Reply Last reply
                • H
                  H
                  humblehacker
                  For the time being, I'm thinking of taking a different approach with my toggle switch... I'm thinking of simply defining the button output as a binary sensor which can then toggle between two predefined scenes. At least in my case, input only needs to go in one direction so there's no need to receive any data from the controller....
                  • H humblehacker
                    martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    @humblehacker
                    FYI, my fifo_queue pull request has been merged with dev branch at pymysensors, so I'm hoping to be able to implement switch support for the mysensors component in homeassistant very soon.
                    H 1 Reply Last reply
                      @humblehacker
                      H
                      H
                      humblehacker
                      @martinhjelmare said:
                      @humblehacker
                      Thats great news! That should be a huge help with my plans for building an RGB Lighting controller based on the rotary_led_dimmer sketch! If I can ever figure out how to implement a simple toggle switch first...
                      • H humblehacker
                        mqtt 1:
                          port: 1883
                          keepalive: 60
                        drock1985
                        @humblehacker said:
                        k
                        mqtt 1:
                          port: 1883
                          keepalive: 60
                        @humblehacker
                        The configuration.yaml file I have pointed back to the local IP address, since Mosquitto and Home-Assistant are running on the same Pi.
                        So, you are saying that it should really be pointed back to the MQTT Gateway then? Still confusing to me.
                        My Projects
                        2 Door Chime Sensor
                        • H
                          H
                          humblehacker
                          Never mind then... As long as your using Mosquitto as your broker and the MQTT CLIENT Gateway (from the development branch) rather than the default MQTT Gateway sketch from- http://www.mysensors.org/build/mqtt_gateway then none of my earlier comments should apply... Basically I was saying that the default MYSensors MQTT Gateway is set up to function as a broker and would therefore conflict with any Mosquitto server running on the same port. The MQTT CLIENT Gateway (emphasis on CLIENT) from the development branch isnt set up as a broker so it shouldnt conflict with a Mosquitto installation.
                          • martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            It's still important to be wary about which ip address you assign where, so I think it was a good point.
                            • D
                              drock1985
                              Well, I have Mosquitto and the Dev ClientMQTTESP gateway working, and is communicating fine. Now just trying to figure out the proper entry to add an item as.
                              My Projects
                              2 Door Chime Sensor
                              • D
                                drock1985
                                Ok, just got it all setup and working great now. Time to see how relays will work......
                                My Projects
                                2 Door Chime Sensor
                                • D
                                  drock1985
                                  Hey @martinhjelmare , I see HA was updated today; did your commits get added?
                                  My Projects
                                  2 Door Chime Sensor
                                  • D drock1985
                                    martinhjelmareM
                                    martinhjelmareM
                                    martinhjelmare
                                    @drock1985
                                    Hi!
                                    No, I've submitted a pull request, but I need to fix some things, and maybe change some of it. But hopefully it wont take too long.
                                    • MufasaM
                                      MufasaM
                                      Mufasa
                                      I have been trying to set up a switch in home assistant but I have had no luck in getting it to show up in the dashboard. I am using @martinhjelmare mysensors-component-switch branch of home assistant and the following sketch. Does anyone have any idea why this is happening? ```
                                       * Version 1.0 - Henrik Ekblad
                                       * Example sketch showing how to control physical relays.
                                       * This example will remember relay state after power failure.
                                       * http://www.mysensors.org/build/relay
                                      #include <MySigningNone.h>
                                      #include <MyTransportNRF24.h>
                                      #include <MyTransportRFM69.h>
                                      #include <MyHwATMega328.h>
                                      MyTransportNRF24 radio(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
                                      //MyTransportRFM69 radio;
                                      // Message signing driver (none default)
                                      //MySigningNone signer;
                                      // Select AtMega328 hardware profile
                                      MyHwATMega328 hw;
                                      MySensor gw(radio, hw);
                                      MyMessage lightMsg(RELAY_1, S_LIGHT);
                                        gw.sendSketchInfo("Relay", "1.0");
                                        // Fetch relay status
                                          gw.present(sensor, S_LIGHT);
                                          pinMode(pin, OUTPUT);
                                          digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
                                        gw.send(lightMsg.set("0"));
                                        if (message.type==V_LIGHT) {
                                           // Change relay state
                                           // Store state in eeprom
                                      • MufasaM Mufasa
                                        MyHwATMega328 hw;
                                        martinhjelmareM
                                        martinhjelmareM
                                        martinhjelmare
                                        @Mufasa
                                        Hi!
                                        First of all my branch is still under development, and right now I think there is a bug, which could make it unable to install. I'll have more time to fix things next week.
                                        How does your home assistant config for mysensors look like?
                                        Have you looked at the logs of home assistant after start?
                                        • MufasaM
                                          MufasaM
                                          Mufasa
                                          @martinhjelmare
                                          Hey Martin, this is my config for the mysensors component
                                          mysensors:
                                            gateways:
                                              port: '/dev/ttyUSB0'
                                              persistance_file: '/home/pi/.homeassistant/mysensors.json'
                                            debug: true
                                            persistance: true
                                            version: '1.5'
                                          sensor:
                                            platform: mysensors
                                          switch:
                                            platform: mysensors
                                          Here is the log after start
                                          (hass-test)pi@raspberrypi:~/.homeassistant $ hass
                                          Config directory: /home/pi/.homeassistant
                                          WARNING:homeassistant.bootstrap:Colorlog package not found, console coloring disabled
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_off, domain=homea
                                          ssistant>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_on, domain=homeas
                                          sistant>
                                          INFO:homeassistant.bootstrap:Home Assistant core initialized
                                          INFO:homeassistant.loader:Loaded switch from homeassistant.components.switch
                                          INFO:homeassistant.loader:Loaded discovery from homeassistant.components.discovery
                                          INFO:homeassistant.loader:Loaded conversation from homeassistant.components.conversation
                                          INFO:homeassistant.loader:Loaded sensor from homeassistant.components.sensor
                                          INFO:homeassistant.loader:Loaded history from homeassistant.components.history
                                          INFO:homeassistant.loader:Loaded recorder from homeassistant.components.recorder
                                          INFO:homeassistant.loader:Loaded http from homeassistant.components.http
                                          INFO:homeassistant.loader:Loaded logbook from homeassistant.components.logbook
                                          INFO:homeassistant.loader:Loaded sun from homeassistant.components.sun
                                          INFO:homeassistant.loader:Loaded mysensors from homeassistant.components.mysensors
                                          INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend
                                          INFO:homeassistant.loader:Loaded api from homeassistant.components.api
                                          INFO:homeassistant.loader:Loaded updater from homeassistant.components.updater
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recorder>
                                          INFO:homeassistant.loader:Loaded switch.mysensors from homeassistant.components.switch.mysensors
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_off, domain=switc
                                          h>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_on, domain=switch
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=switch>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=discovery>
                                          /home/pi/.homeassistant/lib/fuzzywuzzy/fuzz.py:33: UserWarning: Using slow pure-python SequenceMa
                                          tcher. Install python-Levenshtein to remove this warning
                                            warnings.warn('Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove thi
                                          s warning')
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=process, domain=conver
                                          sation>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=conversation>
                                          INFO:homeassistant.loader:Loaded sensor.mysensors from homeassistant.components.sensor.mysensors
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sensor>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=http>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=history>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logbook>
                                          INFO:urllib3.connectionpool:Starting new HTTP connection (1): maps.googleapis.com
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_hori
                                          zon; friendly_name=Sun, next_rising=03:32:34 08-01-2016, next_setting=15:36:03 07-01-2016, elevat
                                          ion=47.84 @ 14:58:04 07-01-2016>, entity_id=sun.sun>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sun>
                                          INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.sensors, di
                                          scovered=>
                                          INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.switches, d
                                          iscovered=>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mysensors>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=api>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=frontend>
                                          INFO:urllib3.connectionpool:Starting new HTTPS connection (1): pypi.python.org
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state updater.updater=0.
                                          10.1; friendly_name=Update Available @ 14:58:06 07-01-2016>, entity_id=updater.updater>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=updater>
                                          INFO:homeassistant.core:Starting Home Assistant (15 threads)
                                          INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=stop, domain=homeassis
                                          tant>
                                          INFO:mysensors.mysensors:Trying to connect to /dev/ttyUSB0
                                          INFO:homeassistant.core:Timer:starting
                                          INFO:homeassistant.components.mysensors:update persistence: node 1
                                          INFO:homeassistant.components.http:Starting web interface at http://0.0.0.0:8123
                                          INFO:netdisco.service:Scanning
                                          INFO:mysensors.mysensors:/dev/ttyUSB0 is open...
                                          INFO:mysensors.mysensors:Connected to /dev/ttyUSB0
                                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, distance=0
                                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=0,t=18,pt=0,l=5,sg=0:1.5.1
                                          INFO:homeassistant.components.mysensors:update sensor_update: node 1
                                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-1-1 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
                                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=11,pt=0,l=5,sg=0:Relay
                                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
                                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=3,c=1,t=3,pt=0,l=1,sg=0:0
                                          INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.1.1
                                          ion=47.76 @ 14:58:04 07-01-2016>, old_state=<state sun.sun=above_horizon; friendly_name=Sun, next
                                          _rising=03:32:34 08-01-2016, next_setting=15:36:03 07-01-2016, elevation=47.84 @ 14:58:04 07-01-2
                                          martinhjelmareM 2 Replies Last reply
                                          12.5k
