  3. Home Assistant
  4. Home Assistant - How to recognize MySensors nodes
home assistant
64 Posts 7 Posters 55.1k Views 3 Watching
  • D
    drock1985
    Thanks @hek , had to ask :)
    Would it be possible to get a Home-Assistant dedicated sub-forum please?
    My Projects
    2 Door Chime Sensor
    Washing Machine Monitor
    • D drock1985
      I've been trying to get MQTT working using the Dev branch here (http://forum.mysensors.org/topic/2352/guide-setting-up-and-testing-mqtt-client-gateway/) and have my configuration.yaml file looking like this for my W5100MQTT broker:
      #MySensors MQTT Test
      mqtt 1:
        broker: 192.168.86.198
        port: 1883
      #  client_id: home-assistant-1
        keepalive: 60
      #  username: USERNAME
      #  password: PASSWORD
      The Serial output from Arduino shows that I connected successfully
      0;0;3;0;9;Starting gateway (RNNGA-, 1.6.0-beta)
      0;0;3;0;9;Radio init successful.
      IP: 192.168.86.112
      0;0;3;0;9;MQTT connected
      0;0;3;0;9;Init complete, id=0, parent=0, distance=0
      But, Home-Assistant isn't registering the broker, and I have this error in the Dev section:
      15-12-15 15:32:17 homeassistant.components.mqtt: Missing required configuration items in mqtt: broker
      15-12-15 15:32:17 homeassistant.bootstrap: component mqtt failed to initialize
      Does anyone have any ideas? @humblehacker @martinhjelmare @hek ?
      martinhjelmareM
      martinhjelmareM
      martinhjelmare
      @drock1985
      What do you set MY_IP_GATEWAY_ADDRESS to on the arduino side?
        You got it.
        http://forum.mysensors.org/category/28/home-assistant
        • D
          drock1985
          wrote on last edited by drock1985
          #42
          Thanks @hek very appreciated.
          EDIT: Sort of ran into an issue with the Dev MQTTW5100Gateway sketch.... Thought the output I was getting above was good, but in reality the Arduino IDE wasn't giving an error. I decided to run the gateway in my RPI and view the data through SSH via screen. It initializes and shows the same data as the Arduino IDE, but then seconds later it dies and gives an error about screen terminating. Happens every time.
          Going to try the ESP8266MQTTGateway: I'm got a hunch.
          My Projects
          2 Door Chime Sensor
          • D drock1985
            mqtt 1:
              port: 1883
              keepalive: 60
            IP: 192.168.86.112
            H
            H
            humblehacker
            wrote on last edited by humblehacker
            #43
            mqtt 1:
              port: 1883
              keepalive: 60
            Does the IP address you defined in the config.yaml point to your Mosquitto Broker or the Arduino-Ethernet Shield? If it points to the Arduino afaik the point of the MQTTCLIENT Gateway is that it can be run as a client if you've already got a Mosquitto broker. Otherwise you would either need to remove mosquitto or forward it to a different port than the default 1883. If this was the case then HASS would be looking for a broker where none exists which is why it is missing configuration items...
            D 1 Reply Last reply
            • H
              H
              humblehacker
              For the time being, I'm thinking of taking a different approach with my toggle switch... I'm thinking of simply defining the button output as a binary sensor which can then toggle between two predefined scenes. At least in my case, input only needs to go in one direction so there's no need to receive any data from the controller....
              • H humblehacker
                martinhjelmareM
                martinhjelmareM
                martinhjelmare
                @humblehacker
                FYI, my fifo_queue pull request has been merged with dev branch at pymysensors, so I'm hoping to be able to implement switch support for the mysensors component in homeassistant very soon.
                H 1 Reply Last reply
                  @humblehacker
                  H
                  H
                  humblehacker
                  @martinhjelmare said:
                  @humblehacker
                  Thats great news! That should be a huge help with my plans for building an RGB Lighting controller based on the rotary_led_dimmer sketch! If I can ever figure out how to implement a simple toggle switch first...
                  • H humblehacker
                    mqtt 1:
                      port: 1883
                      keepalive: 60
                    drock1985
                    @humblehacker said:
                    k
                    mqtt 1:
                      port: 1883
                      keepalive: 60
                    @humblehacker
                    The configuration.yaml file I have pointed back to the local IP address, since Mosquitto and Home-Assistant are running on the same Pi.
                    So, you are saying that it should really be pointed back to the MQTT Gateway then? Still confusing to me.
                    My Projects
                    2 Door Chime Sensor
                    • H
                      H
                      humblehacker
                      Never mind then... As long as your using Mosquitto as your broker and the MQTT CLIENT Gateway (from the development branch) rather than the default MQTT Gateway sketch from- http://www.mysensors.org/build/mqtt_gateway then none of my earlier comments should apply... Basically I was saying that the default MYSensors MQTT Gateway is set up to function as a broker and would therefore conflict with any Mosquitto server running on the same port. The MQTT CLIENT Gateway (emphasis on CLIENT) from the development branch isnt set up as a broker so it shouldnt conflict with a Mosquitto installation.
                      • martinhjelmareM
                        martinhjelmareM
                        martinhjelmare
                        It's still important to be wary about which ip address you assign where, so I think it was a good point.
                        • D
                          drock1985
                          Well, I have Mosquitto and the Dev ClientMQTTESP gateway working, and is communicating fine. Now just trying to figure out the proper entry to add an item as.
                          My Projects
                          2 Door Chime Sensor
                          • D
                            drock1985
                            Ok, just got it all setup and working great now. Time to see how relays will work......
                            My Projects
                            2 Door Chime Sensor
                            • D
                              drock1985
                              Hey @martinhjelmare , I see HA was updated today; did your commits get added?
                              My Projects
                              2 Door Chime Sensor
                              • D drock1985
                                martinhjelmareM
                                martinhjelmareM
                                martinhjelmare
                                @drock1985
                                Hi!
                                No, I've submitted a pull request, but I need to fix some things, and maybe change some of it. But hopefully it wont take too long.
                                • MufasaM
                                  MufasaM
                                  Mufasa
                                  I have been trying to set up a switch in home assistant but I have had no luck in getting it to show up in the dashboard. I am using @martinhjelmare mysensors-component-switch branch of home assistant and the following sketch. Does anyone have any idea why this is happening? ```
                                   * Version 1.0 - Henrik Ekblad
                                   * Example sketch showing how to control physical relays.
                                   * This example will remember relay state after power failure.
                                   * http://www.mysensors.org/build/relay
                                  #include <MySigningNone.h>
                                  #include <MyTransportNRF24.h>
                                  #include <MyTransportRFM69.h>
                                  #include <MyHwATMega328.h>
                                  MyTransportNRF24 radio(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
                                  //MyTransportRFM69 radio;
                                  // Message signing driver (none default)
                                  //MySigningNone signer;
                                  // Select AtMega328 hardware profile
                                  MyHwATMega328 hw;
                                  MySensor gw(radio, hw);
                                  MyMessage lightMsg(RELAY_1, S_LIGHT);
                                    gw.sendSketchInfo("Relay", "1.0");
                                    // Fetch relay status
                                      gw.present(sensor, S_LIGHT);
                                      pinMode(pin, OUTPUT);
                                      digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
                                    gw.send(lightMsg.set("0"));
                                    if (message.type==V_LIGHT) {
                                       // Change relay state
                                       // Store state in eeprom
                                  • MufasaM Mufasa
                                    MyHwATMega328 hw;
                                    martinhjelmareM
                                    martinhjelmareM
                                    martinhjelmare
                                    @Mufasa
                                    Hi!
                                    First of all my branch is still under development, and right now I think there is a bug, which could make it unable to install. I'll have more time to fix things next week.
                                    How does your home assistant config for mysensors look like?
                                    Have you looked at the logs of home assistant after start?
                                    • MufasaM
                                      MufasaM
                                      Mufasa
                                      @martinhjelmare
                                      Hey Martin, this is my config for the mysensors component
                                      mysensors:
                                        gateways:
                                          port: '/dev/ttyUSB0'
                                          persistance_file: '/home/pi/.homeassistant/mysensors.json'
                                        debug: true
                                        persistance: true
                                        version: '1.5'
                                      sensor:
                                        platform: mysensors
                                      switch:
                                        platform: mysensors
                                      Here is the log after start
                                      (hass-test)pi@raspberrypi:~/.homeassistant $ hass
                                      Config directory: /home/pi/.homeassistant
                                      WARNING:homeassistant.bootstrap:Colorlog package not found, console coloring disabled
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_off, domain=homea
                                      ssistant>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_on, domain=homeas
                                      sistant>
                                      INFO:homeassistant.bootstrap:Home Assistant core initialized
                                      INFO:homeassistant.loader:Loaded switch from homeassistant.components.switch
                                      INFO:homeassistant.loader:Loaded discovery from homeassistant.components.discovery
                                      INFO:homeassistant.loader:Loaded conversation from homeassistant.components.conversation
                                      INFO:homeassistant.loader:Loaded sensor from homeassistant.components.sensor
                                      INFO:homeassistant.loader:Loaded history from homeassistant.components.history
                                      INFO:homeassistant.loader:Loaded recorder from homeassistant.components.recorder
                                      INFO:homeassistant.loader:Loaded http from homeassistant.components.http
                                      INFO:homeassistant.loader:Loaded logbook from homeassistant.components.logbook
                                      INFO:homeassistant.loader:Loaded sun from homeassistant.components.sun
                                      INFO:homeassistant.loader:Loaded mysensors from homeassistant.components.mysensors
                                      INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend
                                      INFO:homeassistant.loader:Loaded api from homeassistant.components.api
                                      INFO:homeassistant.loader:Loaded updater from homeassistant.components.updater
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recorder>
                                      INFO:homeassistant.loader:Loaded switch.mysensors from homeassistant.components.switch.mysensors
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_off, domain=switc
                                      h>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_on, domain=switch
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=switch>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=discovery>
                                      /home/pi/.homeassistant/lib/fuzzywuzzy/fuzz.py:33: UserWarning: Using slow pure-python SequenceMa
                                      tcher. Install python-Levenshtein to remove this warning
                                        warnings.warn('Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove thi
                                      s warning')
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=process, domain=conver
                                      sation>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=conversation>
                                      INFO:homeassistant.loader:Loaded sensor.mysensors from homeassistant.components.sensor.mysensors
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sensor>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=http>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=history>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logbook>
                                      INFO:urllib3.connectionpool:Starting new HTTP connection (1): maps.googleapis.com
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_hori
                                      zon; friendly_name=Sun, next_rising=03:32:34 08-01-2016, next_setting=15:36:03 07-01-2016, elevat
                                      ion=47.84 @ 14:58:04 07-01-2016>, entity_id=sun.sun>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sun>
                                      INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.sensors, di
                                      scovered=>
                                      INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.switches, d
                                      iscovered=>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mysensors>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=api>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=frontend>
                                      INFO:urllib3.connectionpool:Starting new HTTPS connection (1): pypi.python.org
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state updater.updater=0.
                                      10.1; friendly_name=Update Available @ 14:58:06 07-01-2016>, entity_id=updater.updater>
                                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=updater>
                                      INFO:homeassistant.core:Starting Home Assistant (15 threads)
                                      INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
                                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=stop, domain=homeassis
                                      tant>
                                      INFO:mysensors.mysensors:Trying to connect to /dev/ttyUSB0
                                      INFO:homeassistant.core:Timer:starting
                                      INFO:homeassistant.components.mysensors:update persistence: node 1
                                      INFO:homeassistant.components.http:Starting web interface at http://0.0.0.0:8123
                                      INFO:netdisco.service:Scanning
                                      INFO:mysensors.mysensors:/dev/ttyUSB0 is open...
                                      INFO:mysensors.mysensors:Connected to /dev/ttyUSB0
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, distance=0
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=0,t=18,pt=0,l=5,sg=0:1.5.1
                                      INFO:homeassistant.components.mysensors:update sensor_update: node 1
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-1-1 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=11,pt=0,l=5,sg=0:Relay
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=3,c=1,t=3,pt=0,l=1,sg=0:0
                                      INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.1.1
                                      ion=47.76 @ 14:58:04 07-01-2016>, old_state=<state sun.sun=above_horizon; friendly_name=Sun, next
                                      _rising=03:32:34 08-01-2016, next_setting=15:36:03 07-01-2016, elevation=47.84 @ 14:58:04 07-01-2
                                      martinhjelmareM 2 Replies Last reply
                                      • MufasaM Mufasa
                                        @martinhjelmare
                                        mysensors:
                                          gateways:
                                          debug: true
                                          persistance: true
                                          version: '1.5'
                                        sensor:
                                          platform: mysensors
                                        switch:
                                          platform: mysensors
                                        ssistant>
                                        sistant>
                                        h>
                                        s warning')
                                        sation>
                                        scovered=>
                                        iscovered=>
                                        tant>
                                        martinhjelmareM
                                        martinhjelmareM
                                        martinhjelmare
                                        #57
                                        @Mufasa
                                        The error is in your sketch. When you declare your message you should use child sensor id as first argument. Now you're using the pin number. So then you're sending the value from a child which hasn't been presented to home assistant.
                                        MyMessage msg(child-sensor-id, variable-type);
                                        • MufasaM Mufasa
                                          @martinhjelmare
                                          mysensors:
                                            gateways:
                                            debug: true
                                            persistance: true
                                            version: '1.5'
                                          sensor:
                                            platform: mysensors
                                          switch:
                                            platform: mysensors
                                          ssistant>
                                          sistant>
                                          h>
                                          s warning')
                                          sation>
                                          scovered=>
                                          iscovered=>
                                          tant>
                                          martinhjelmareM
                                          martinhjelmareM
                                          martinhjelmare
                                          @Mufasa
                                          Btw, you can remove sensor/switch platform mysensors in your config, if using the latest version of my branch.
                                          Everything else looks good in the config and the log, what I can tell.
                                          12.5k
