  3. How to wire this?
How to wire this?
6 Posts 2 Posters 3.0k Views 1 Watching
  • M Offline
    M Offline
    msebbe
    wrote on last edited by msebbe
    Hello again! Im trying to get better at understanding schematics.. This is what I want to do on my breadboard LINK to schematic
    NPN is a TIP120 transistor.
    IR led is a simple 5mm 940nm with 2 legs.
    What does "D21 IR" mean?
    How exactly do I wire this?.. I dont understand how to wire From A0 to the TIP120 with 4.7k resistor to IR LED..
    Thank you for help!
    edit: This is a part of the schematic from Makeit.netflix.com/the-switch
    Basicly if I figure this out I want to make a Wifi button so when I press the button, the ir will start the TV and my phone will get a notification that will trigger tasker to run a scene in the android App imperihome.
    This scene would do something like Turn off some lights, Dim those lights, set this light to this colour and so on.. For Friday/Saturday nights :)
    • mfalkviddM Offline
      Could you describe how far you've gotten in your wiring so far, and what isn't working?
      "D21 IR" is the IR led.
      • M Offline
        M Offline
        msebbe
        @mfalkvidd
        I have just put my nodemcu on a breadboard, connected it to ground and vin. I have also just put the led and the transistor on the board.
        I wanted to start with just making the IR part work to turn on the TV and then continue from there. This is my first time following a schematic like this and also first time using a transistor. Im more used to the very user friendly guides from @hek where everything is visual on how to wire. This type of schematic confuse me but I want to learn :)
        So if "D21 IR" is the IR led this means..
        • 4.7K resistor from A0 to the + of the Transistor
          -3.3V to the + of IR LED and also from + of IR led to + Of transistor?
        hmm
        Thanks again :)
          Do you mean that you're used to something like this?
          I think this is exactly the same as your schematic (except that I didn't have nodemcu in my Fritzing library)
          This is the schematic view in Fritzing:
          • M Offline
            M Offline
            msebbe
            @mfalkvidd Thank you! This is really great! :)
            I will take a look at this after work tomorrow :+1:
            • M Offline
              M Offline
              msebbe
              Got delayed.. I had to order a IR reciver to find out my remote codes, didnt thought I would find them easily on the internet but nope! :)
              12.2k
