  3. 💬 jModule
💬 jModule
mysensorscontest2016
84 Posts 28 Posters 46.3k Views 24 Watching
  • D dakipro
    Hi, I've receive first order, and for some reason i got pin 8 connected to the ground on all 3 pcbs I ordered. Not a big deal since I do not use pin8, but I didn't see pin8 connected to ground on either of Eagle files.
    Did anyone got same or similar thing?
    DwaltD
    DwaltD
    Dwalt
    @dakipro
    I got three boards from OshPark and pin 8 is connected to ground on all three.
    • cvanandelC
      cvanandelC
      cvanandel
      @Dwalt
      Pin 8 on the Module is Ground, and Pin 7 is VCC, these Pins do not get connected to the Mini Pro
      But they come out the side on the angle connector as IO
      • DwaltD
        DwaltD
        Dwalt
        Ahh, I see now. The side facing pins are mapped as follows:
        • D
          dakipro
          Ok, right, I see now... My bad (as usual :disappointed: ) World is great again :)
          • A
            aproxx
            Any chance you will be creating a 'panelized' version of this board? With these small sizes 4 boards can be fitted on a 5 by 5cm board, while still keeping the same price. I'd be happy to order a few if that's available!
            cvanandelC T 2 Replies Last reply
            • A aproxx
              cvanandelC
              cvanandelC
              cvanandel
              @aproxx
              I have not, nor do not claim to have designed this module, the module was designed by julisses.
              All credit for this board goes to julisses.
              The only thing i did was to send his .brd file to OSH Park, so there was a local company we could order the board from.
              So if there are any changes required to the board, please contact julisses.
              Sorry if there was a misunderstanding.
              • cvanandelC cvanandel
                I have uploaded the .brd file to OSH Park pcb manufacturing company.
                you can sign up with them, and search for jModule.
                and order the board for $3.20 for 3 boards
                Hope this helps somebody.
                Regards
                cvanandel
                B
                B
                bassmint
                @cvanandel said:
                jModule
                can you supply osh park link. can't find it.
                Q B AWIA 3 Replies Last reply
                • B bassmint
                  @cvanandel said:
                  jModule
                  Q
                  Q
                  Qu3Uk
                  wrote on last edited by Qu3Uk
                  #23
                  Am I right in thinking you can use any voltage regulator with this as long as the three pins are correct. Looking at the pinout on the AMS1117 I don't think that tab is an output and not got anything to open the design files with to confirm if its connected to anything. I've got plenty of LE33ACZ which I'm hoping to use.
                  OSH Park link HERE
                  Noticed there search box doesn't come up on certain browsers as well.
                  cvanandelC 1 Reply Last reply
                  • Q Qu3Uk
                    OSH Park link HERE
                    cvanandelC
                    cvanandelC
                    cvanandel
                    @Qu3Uk
                    I do not think that pad goes anywhere either, here is the Eagle layout picture.
                    Regards
                    • B bassmint
                      @cvanandel said:
                      jModule
                      B
                      B
                      bassmint
                      @bassmint thanks for the link. just ordered some.
                      here it is for any others who can't find it
                      https://oshpark.com/shared_projects/62Dzi9s7
                      • B bassmint
                        @cvanandel said:
                        jModule
                        AWIA
                        AWIA
                        AWI
                        @Qu3Uk I can confirm (from measuring a sample) that the large pad is not connected to anything.
                        However :smirk: it is hard to beat the price of an AMS1117 and the AMS1117 SOT-223 package also has smaller thermal resistance compared to the LE33ACZ TO-92 package (all for what its worth ;-) )
                        Q Nca78N 2 Replies Last reply
                        • AWIA AWI
                          Q
                          Q
                          Qu3Uk
                          @AWI Wow they are cheap - Perhaps we should get them added to the MYS Store - I need to use up the ones I've got before shipping more stuff half way around the world :D
                          • A aproxx
                            tjay4x4
                            I'm just order it, on Dirtyboard not tested yet. Maybe this what you need?
                            http://dirtypcbs.com/view.php?share=18851&accesskey=01fcfdedf25cb9105e13f2d50d9ea385
                            • alexsh1A
                              alexsh1A
                              alexsh1
                              Nice one!
                              I really would like to see the version of it for nrf24l01+ SMD
                              • T
                                ted
                                Very nice. The only downside I can think of is that AMS1117 is power hungry. Is there a pin compatible regulator with uA level standby current?
                                julissesJ 1 Reply Last reply
                                • T ted
                                  julissesJ
                                  julissesJ
                                  julisses
                                  @ted
                                  I do not care about the power. I use USB wall charger to power my nodes. I can recommend this model (it is almost the size of jModule after removing the case):
                                  http://www.aliexpress.com/item/1pc-High-Quality-5V-1A-EU-Plug-AC-Travel-USB-Wall-Charger-for-iPod-for-iPhone/32581266560.html?spm=2114.30010308.3.299.EEQVE8&ws_ab_test=searchweb201556_6,searchweb201602_5_10017_10005_10006_10034_10021_507_10022_9026_10020_10018_10019,searchweb201603_2&btsid=7f600ac6-6e52-41b9-9da5-5c4379d7a639
                                  T m26872M 2 Replies Last reply
                                  • julissesJ julisses
                                    @ted
                                    ted
                                    I modified the design to use a XC6206 serial LDO (1uA standby current). I placed an order with dirtypcb. You can find the design here: http://dirtypcbs.com/view.php?share=19651&accesskey=2e5e31a83bf6fe21510c3bc438e12df7
                                    Will update when I get the board on hand.
                                    Nca78N 1 Reply Last reply
                                      @ted
                                      m26872M
                                      m26872M
                                      m26872
                                      @julisses Would you mind posting a photo of what that supply looks like inside? Preferably to this thread: http://forum.mysensors.org/topic/2477/are-chinese-power-supply-chargers-that-dangerous-to-use
                                      • m26872M m26872
                                        julissesJ
                                        julissesJ
                                        julisses
                                        @m26872
                                        Unsolder USB connector and instead of the connector use wires to connect the jModule.
                                        • sundberg84S
                                          sundberg84S
                                          #35
                                          @julisses - Be carefull...
                                          More info here: http://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers/ and as @m26872 said: http://forum.mysensors.org/topic/2477/are-chinese-power-supply-chargers-that-dangerous-to-use
                                          I have a couple of those cheap power supplies running some nodes and they tend to give up after some time as well...
                                          If you look after them thats fine... but im not to comfident with those cheap usb power supplies any more.
                                          Just a tip - as I said, have some working fine but be careful.
