  3. 💬 jModule
💬 jModule
mysensorscontest2016
84 Posts 28 Posters 45.3k Views 24 Watching
  • cvanandelC
    cvanandelC
    cvanandel
    @AWI
    I just checked the board is now available under shared projects.
    • F
      F
      Floca
      wrote on last edited by Floca
      Hi, really nice project.
      Are there any possibilitys to create a 5x5 PCB with perforation, so that more jmodules fits on it? That would be great when ordering from dirtypcb's, because you have more pieces from just one Slice.
      I have no skills with eagle or something, so i can't do it by myself :(.
      Regards.
      julissesJ 1 Reply Last reply
      • F Floca
        Regards.
        julissesJ
        julissesJ
        julisses
        wrote on last edited by julisses
        @Floca
        Hi, my be this film will help you: How To - Duplicate Your PCB Layout Design in Eagle.
        • D
          dakipro
          Hi, I've receive first order, and for some reason i got pin 8 connected to the ground on all 3 pcbs I ordered. Not a big deal since I do not use pin8, but I didn't see pin8 connected to ground on either of Eagle files.
          Did anyone got same or similar thing?
          DwaltD 1 Reply Last reply
          • D dakipro
            DwaltD
            DwaltD
            Dwalt
            @dakipro
            I got three boards from OshPark and pin 8 is connected to ground on all three.
            • cvanandelC
              cvanandelC
              cvanandel
              @Dwalt
              Pin 8 on the Module is Ground, and Pin 7 is VCC, these Pins do not get connected to the Mini Pro
              But they come out the side on the angle connector as IO
              • DwaltD
                DwaltD
                Dwalt
                Ahh, I see now. The side facing pins are mapped as follows:
                • D
                  dakipro
                  Ok, right, I see now... My bad (as usual :disappointed: ) World is great again :)
                  • A
                    aproxx
                    Any chance you will be creating a 'panelized' version of this board? With these small sizes 4 boards can be fitted on a 5 by 5cm board, while still keeping the same price. I'd be happy to order a few if that's available!
                    cvanandelC T 2 Replies Last reply
                    • A aproxx
                      cvanandelC
                      cvanandelC
                      cvanandel
                      @aproxx
                      I have not, nor do not claim to have designed this module, the module was designed by julisses.
                      All credit for this board goes to julisses.
                      The only thing i did was to send his .brd file to OSH Park, so there was a local company we could order the board from.
                      So if there are any changes required to the board, please contact julisses.
                      Sorry if there was a misunderstanding.
                      • cvanandelC cvanandel
                        I have uploaded the .brd file to OSH Park pcb manufacturing company.
                        you can sign up with them, and search for jModule.
                        and order the board for $3.20 for 3 boards
                        Hope this helps somebody.
                        Regards
                        cvanandel
                        B
                        B
                        bassmint
                        @cvanandel said:
                        jModule
                        can you supply osh park link. can't find it.
                        Q B AWIA 3 Replies Last reply
                        • B bassmint
                          @cvanandel said:
                          jModule
                          Q
                          Q
                          Qu3Uk
                          wrote on last edited by Qu3Uk
                          #23
                          Am I right in thinking you can use any voltage regulator with this as long as the three pins are correct. Looking at the pinout on the AMS1117 I don't think that tab is an output and not got anything to open the design files with to confirm if its connected to anything. I've got plenty of LE33ACZ which I'm hoping to use.
                          OSH Park link HERE
                          Noticed there search box doesn't come up on certain browsers as well.
                          cvanandelC 1 Reply Last reply
                          • Q Qu3Uk
                            OSH Park link HERE
                            cvanandelC
                            cvanandelC
                            cvanandel
                            @Qu3Uk
                            I do not think that pad goes anywhere either, here is the Eagle layout picture.
                            Regards
                            • B bassmint
                              @cvanandel said:
                              jModule
                              B
                              B
                              bassmint
                              @bassmint thanks for the link. just ordered some.
                              here it is for any others who can't find it
                              https://oshpark.com/shared_projects/62Dzi9s7
                              • B bassmint
                                @cvanandel said:
                                jModule
                                AWIA
                                AWIA
                                AWI
                                @Qu3Uk I can confirm (from measuring a sample) that the large pad is not connected to anything.
                                However :smirk: it is hard to beat the price of an AMS1117 and the AMS1117 SOT-223 package also has smaller thermal resistance compared to the LE33ACZ TO-92 package (all for what its worth ;-) )
                                Q Nca78N 2 Replies Last reply
                                • AWIA AWI
                                  Q
                                  Q
                                  Qu3Uk
                                  @AWI Wow they are cheap - Perhaps we should get them added to the MYS Store - I need to use up the ones I've got before shipping more stuff half way around the world :D
                                  • A aproxx
                                    tjay4x4
                                    I'm just order it, on Dirtyboard not tested yet. Maybe this what you need?
                                    http://dirtypcbs.com/view.php?share=18851&accesskey=01fcfdedf25cb9105e13f2d50d9ea385
                                    • alexsh1A
                                      alexsh1A
                                      alexsh1
                                      Nice one!
                                      I really would like to see the version of it for nrf24l01+ SMD
                                      • T
                                        ted
                                        Very nice. The only downside I can think of is that AMS1117 is power hungry. Is there a pin compatible regulator with uA level standby current?
                                        • T ted
                                          julissesJ
                                          julissesJ
                                          julisses
                                          @ted
                                          I do not care about the power. I use USB wall charger to power my nodes. I can recommend this model (it is almost the size of jModule after removing the case):
                                          http://www.aliexpress.com/item/1pc-High-Quality-5V-1A-EU-Plug-AC-Travel-USB-Wall-Charger-for-iPod-for-iPhone/32581266560.html?spm=2114.30010308.3.299.EEQVE8&ws_ab_test=searchweb201556_6,searchweb201602_5_10017_10005_10006_10034_10021_507_10022_9026_10020_10018_10019,searchweb201603_2&btsid=7f600ac6-6e52-41b9-9da5-5c4379d7a639
                                          T m26872M 2 Replies Last reply
