  3. 💬 jModule
💬 jModule
mysensorscontest2016
84 Posts 28 Posters 46.3k Views 24 Watching
  • F
    F
    Floca
    wrote on last edited by Floca
    Hi, really nice project.
    Are there any possibilitys to create a 5x5 PCB with perforation, so that more jmodules fits on it? That would be great when ordering from dirtypcb's, because you have more pieces from just one Slice.
    I have no skills with eagle or something, so i can't do it by myself :(.
    Regards.
    julissesJ 1 Reply Last reply
    • F Floca
      Regards.
      julissesJ
      julissesJ
      julisses
      wrote on last edited by julisses
      @Floca
      Hi, my be this film will help you: How To - Duplicate Your PCB Layout Design in Eagle.
      • D
        dakipro
        Hi, I've receive first order, and for some reason i got pin 8 connected to the ground on all 3 pcbs I ordered. Not a big deal since I do not use pin8, but I didn't see pin8 connected to ground on either of Eagle files.
        Did anyone got same or similar thing?
        DwaltD 1 Reply Last reply
        • D dakipro
          DwaltD
          DwaltD
          Dwalt
          @dakipro
          I got three boards from OshPark and pin 8 is connected to ground on all three.
          • cvanandelC
            cvanandelC
            cvanandel
            @Dwalt
            Pin 8 on the Module is Ground, and Pin 7 is VCC, these Pins do not get connected to the Mini Pro
            But they come out the side on the angle connector as IO
            • DwaltD
              DwaltD
              Dwalt
              Ahh, I see now. The side facing pins are mapped as follows:
              • D
                dakipro
                Ok, right, I see now... My bad (as usual :disappointed: ) World is great again :)
                • A
                  aproxx
                  Any chance you will be creating a 'panelized' version of this board? With these small sizes 4 boards can be fitted on a 5 by 5cm board, while still keeping the same price. I'd be happy to order a few if that's available!
                  cvanandelC T 2 Replies Last reply
                  • A aproxx
                    cvanandelC
                    cvanandelC
                    cvanandel
                    @aproxx
                    I have not, nor do not claim to have designed this module, the module was designed by julisses.
                    All credit for this board goes to julisses.
                    The only thing i did was to send his .brd file to OSH Park, so there was a local company we could order the board from.
                    So if there are any changes required to the board, please contact julisses.
                    Sorry if there was a misunderstanding.
                    • cvanandelC cvanandel
                      I have uploaded the .brd file to OSH Park pcb manufacturing company.
                      you can sign up with them, and search for jModule.
                      and order the board for $3.20 for 3 boards
                      Hope this helps somebody.
                      Regards
                      cvanandel
                      B
                      B
                      bassmint
                      @cvanandel said:
                      jModule
                      can you supply osh park link. can't find it.
                      Q B AWIA 3 Replies Last reply
                      • B bassmint
                        @cvanandel said:
                        jModule
                        Q
                        Q
                        Qu3Uk
                        wrote on last edited by Qu3Uk
                        #23
                        Am I right in thinking you can use any voltage regulator with this as long as the three pins are correct. Looking at the pinout on the AMS1117 I don't think that tab is an output and not got anything to open the design files with to confirm if its connected to anything. I've got plenty of LE33ACZ which I'm hoping to use.
                        OSH Park link HERE
                        Noticed there search box doesn't come up on certain browsers as well.
                        cvanandelC 1 Reply Last reply
                        • Q Qu3Uk
                          OSH Park link HERE
                          cvanandelC
                          cvanandelC
                          cvanandel
                          @Qu3Uk
                          I do not think that pad goes anywhere either, here is the Eagle layout picture.
                          Regards
                          • B bassmint
                            @cvanandel said:
                            jModule
                            B
                            B
                            bassmint
                            @bassmint thanks for the link. just ordered some.
                            here it is for any others who can't find it
                            https://oshpark.com/shared_projects/62Dzi9s7
                            • B bassmint
                              @cvanandel said:
                              jModule
                              AWIA
                              AWIA
                              AWI
                              @Qu3Uk I can confirm (from measuring a sample) that the large pad is not connected to anything.
                              However :smirk: it is hard to beat the price of an AMS1117 and the AMS1117 SOT-223 package also has smaller thermal resistance compared to the LE33ACZ TO-92 package (all for what its worth ;-) )
                              Q Nca78N 2 Replies Last reply
                              • AWIA AWI
                                Q
                                Q
                                Qu3Uk
                                @AWI Wow they are cheap - Perhaps we should get them added to the MYS Store - I need to use up the ones I've got before shipping more stuff half way around the world :D
                                • A aproxx
                                  tjay4x4
                                  I'm just order it, on Dirtyboard not tested yet. Maybe this what you need?
                                  http://dirtypcbs.com/view.php?share=18851&accesskey=01fcfdedf25cb9105e13f2d50d9ea385
                                  • alexsh1A
                                    alexsh1A
                                    alexsh1
                                    Nice one!
                                    I really would like to see the version of it for nrf24l01+ SMD
                                    • T
                                      ted
                                      Very nice. The only downside I can think of is that AMS1117 is power hungry. Is there a pin compatible regulator with uA level standby current?
                                      • T ted
                                        julissesJ
                                        julissesJ
                                        julisses
                                        @ted
                                        I do not care about the power. I use USB wall charger to power my nodes. I can recommend this model (it is almost the size of jModule after removing the case):
                                        http://www.aliexpress.com/item/1pc-High-Quality-5V-1A-EU-Plug-AC-Travel-USB-Wall-Charger-for-iPod-for-iPhone/32581266560.html?spm=2114.30010308.3.299.EEQVE8&ws_ab_test=searchweb201556_6,searchweb201602_5_10017_10005_10006_10034_10021_507_10022_9026_10020_10018_10019,searchweb201603_2&btsid=7f600ac6-6e52-41b9-9da5-5c4379d7a639
                                        T m26872M 2 Replies Last reply
                                        • julissesJ julisses
                                          @ted
                                          ted
                                          I modified the design to use a XC6206 serial LDO (1uA standby current). I placed an order with dirtypcb. You can find the design here: http://dirtypcbs.com/view.php?share=19651&accesskey=2e5e31a83bf6fe21510c3bc438e12df7
                                          Will update when I get the board on hand.
                                          Nca78N 1 Reply Last reply
