  3. 💬 jModule
💬 jModule
mysensorscontest2016
84 Posts 28 Posters 46.3k Views 24 Watching
  • D
    dakipro
    Ok, right, I see now... My bad (as usual :disappointed: ) World is great again :)
    • A
      aproxx
      Any chance you will be creating a 'panelized' version of this board? With these small sizes 4 boards can be fitted on a 5 by 5cm board, while still keeping the same price. I'd be happy to order a few if that's available!
      cvanandelC T 2 Replies Last reply
      • A aproxx
        cvanandelC
        cvanandelC
        cvanandel
        @aproxx
        I have not, nor do not claim to have designed this module, the module was designed by julisses.
        All credit for this board goes to julisses.
        The only thing i did was to send his .brd file to OSH Park, so there was a local company we could order the board from.
        So if there are any changes required to the board, please contact julisses.
        Sorry if there was a misunderstanding.
        • cvanandelC cvanandel
          I have uploaded the .brd file to OSH Park pcb manufacturing company.
          you can sign up with them, and search for jModule.
          and order the board for $3.20 for 3 boards
          Hope this helps somebody.
          Regards
          cvanandel
          B
          B
          bassmint
          @cvanandel said:
          jModule
          can you supply osh park link. can't find it.
          Q B AWIA 3 Replies Last reply
          • B bassmint
            @cvanandel said:
            jModule
            Q
            Q
            Qu3Uk
            wrote on last edited by Qu3Uk
            #23
            Am I right in thinking you can use any voltage regulator with this as long as the three pins are correct. Looking at the pinout on the AMS1117 I don't think that tab is an output and not got anything to open the design files with to confirm if its connected to anything. I've got plenty of LE33ACZ which I'm hoping to use.
            OSH Park link HERE
            Noticed there search box doesn't come up on certain browsers as well.
            cvanandelC 1 Reply Last reply
            • Q Qu3Uk
              OSH Park link HERE
              cvanandelC
              cvanandelC
              cvanandel
              @Qu3Uk
              I do not think that pad goes anywhere either, here is the Eagle layout picture.
              Regards
              • B bassmint
                @cvanandel said:
                jModule
                B
                B
                bassmint
                @bassmint thanks for the link. just ordered some.
                here it is for any others who can't find it
                https://oshpark.com/shared_projects/62Dzi9s7
                • B bassmint
                  @cvanandel said:
                  jModule
                  AWIA
                  AWIA
                  AWI
                  @Qu3Uk I can confirm (from measuring a sample) that the large pad is not connected to anything.
                  However :smirk: it is hard to beat the price of an AMS1117 and the AMS1117 SOT-223 package also has smaller thermal resistance compared to the LE33ACZ TO-92 package (all for what its worth ;-) )
                  Q Nca78N 2 Replies Last reply
                  • AWIA AWI
                    Q
                    Q
                    Qu3Uk
                    @AWI Wow they are cheap - Perhaps we should get them added to the MYS Store - I need to use up the ones I've got before shipping more stuff half way around the world :D
                    • A aproxx
                      tjay4x4
                      I'm just order it, on Dirtyboard not tested yet. Maybe this what you need?
                      http://dirtypcbs.com/view.php?share=18851&accesskey=01fcfdedf25cb9105e13f2d50d9ea385
                      • alexsh1A
                        alexsh1A
                        alexsh1
                        Nice one!
                        I really would like to see the version of it for nrf24l01+ SMD
                        • T
                          ted
                          Very nice. The only downside I can think of is that AMS1117 is power hungry. Is there a pin compatible regulator with uA level standby current?
                          julissesJ 1 Reply Last reply
                          • T ted
                            julissesJ
                            julissesJ
                            julisses
                            @ted
                            I do not care about the power. I use USB wall charger to power my nodes. I can recommend this model (it is almost the size of jModule after removing the case):
                            http://www.aliexpress.com/item/1pc-High-Quality-5V-1A-EU-Plug-AC-Travel-USB-Wall-Charger-for-iPod-for-iPhone/32581266560.html?spm=2114.30010308.3.299.EEQVE8&ws_ab_test=searchweb201556_6,searchweb201602_5_10017_10005_10006_10034_10021_507_10022_9026_10020_10018_10019,searchweb201603_2&btsid=7f600ac6-6e52-41b9-9da5-5c4379d7a639
                            T m26872M 2 Replies Last reply
                            • julissesJ julisses
                              @ted
                              ted
                              I modified the design to use a XC6206 serial LDO (1uA standby current). I placed an order with dirtypcb. You can find the design here: http://dirtypcbs.com/view.php?share=19651&accesskey=2e5e31a83bf6fe21510c3bc438e12df7
                              Will update when I get the board on hand.
                              Nca78N 1 Reply Last reply
                                @ted
                                m26872M
                                m26872M
                                m26872
                                @julisses Would you mind posting a photo of what that supply looks like inside? Preferably to this thread: http://forum.mysensors.org/topic/2477/are-chinese-power-supply-chargers-that-dangerous-to-use
                                • m26872M m26872
                                  julissesJ
                                  julissesJ
                                  julisses
                                  @m26872
                                  Unsolder USB connector and instead of the connector use wires to connect the jModule.
                                  • sundberg84S
                                    sundberg84S
                                    #35
                                    @julisses - Be carefull...
                                    More info here: http://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers/ and as @m26872 said: http://forum.mysensors.org/topic/2477/are-chinese-power-supply-chargers-that-dangerous-to-use
                                    I have a couple of those cheap power supplies running some nodes and they tend to give up after some time as well...
                                    If you look after them thats fine... but im not to comfident with those cheap usb power supplies any more.
                                    Just a tip - as I said, have some working fine but be careful.
                                    • Cliff KarlssonC
                                      Cliff KarlssonC
                                      Cliff Karlsson
                                      Do you have a link for the angular pin-header? I noticed after soldering everything and could not get the arduino/jModule together that the angular pinheaders have the plastic in the other way. I tried with a new and just turned the pinheaders in the other way, but then the exposed pins got too short, same result when prying of every pin and turning them around manually.
                                      • cvanandelC
                                        cvanandelC
                                        cvanandel
                                        I had the same problem, I straightened out a set of angular headers, then soldered them into the board, and bend them at the place I needed.
                                        Not the best solution, but I had to many standard angular pins to go and buy more.
                                          http://www.ebay.com/itm/10pcs-90-Degree-Bent-Right-Angle-Pin-Header-Breakable-40pin-Single-Strip-2-54mm-/231215719944?hash=item35d587e608:g:cHwAAOSw3ydV2ZCV
