  3. Wall mounted 'mood light'
23 Posts 10 Posters 20.6k Views 15 Watching
    mickaelr30
    wrote on last edited by mickaelr30
    hello,
    i've problem with the sketch :+1 :
    sketch_dec08a.ino: In function 'void setup()':
    sketch_dec08a:89: error: 'S_INFO' was not declared in this scope
         gw.present(RGB_TextColorChild, S_INFO, "RGB Wall textcolor 0");
    sketch_dec08a.ino: In function 'void incomingMessage(const MyMessage&)':
    sketch_dec08a:308: error: 'V_TEXT' was not declared in this scope
                     gw.request(RGB_TextColorChild, V_TEXT);
    sketch_dec08a:313: error: 'V_TEXT' was not declared in this scope
                 if (message.type == V_TEXT) {                   // if get color from text child
    exit status 1
      S_INFO inly exist in the dev branch.
      That also means you have to convert the 1.5 sketch. Convert instructions here:
      https://docs.google.com/document/d/1NKq5uuNdnxF5jWnum7VT32mbKLjuvqlx2A5D1qQ-H3Q/edit#
      • A
        Adam McCartney
        @mickaelr30 , did you ever get this working with 1.5?
        i've got the upgrade instructions, but struggling to reverse it so it works with my current setup. Don't think i'm quite ready to upgrade all my nodes to dev quite yet.
        AWIA 1 Reply Last reply
        • A Adam McCartney
          AWIA
          AWIA
          AWI
          @Adam-McCartney add these lines in the header and you will have it working with the production version...
          // V_TEXT & V_INFO when not using the DEVELOPMENT version
          const byte V_TEXT = 47 ;					// values taken from development edition MyMessage.h
          const byte S_INFO = 36 ;
          • A
            Adam McCartney
            awesome, thanks!
            I'm more of a butcher than a surgeon. I can quite happily take things apart, but fixing things usually goes right over my head!!
              Mehdi HAMIDA
              I really love this project.
              May I can include it in all of my sensors (doorbell, thermostat, alarm,...).
              Really sounds great, thanks
                Mehdi HAMIDA
                Is there a way to get your wiring schema ?
                • M Mehdi HAMIDA
                  AWIA
                  AWIA
                  AWI
                  @Mehdi-HAMIDA There is nothing to it. A standard MySensors node (5v) with the strip connected to D5 and a button between ground and D4.
                  const int stripPin = 5 ;                                    // pin where 2812 LED strip is connected
                  const int buttonPin = 4 ;                                   // push button
                  • AWIA AWI
                    Mehdi HAMIDA
                    @AWI OK, just ordered the PCB
                    thx
                    • mfalkviddM
                      @AWI: Won't this part of your sketch create sort of an endless loop?
                              case RGB_TextColorChild:                            // Text color from controller
                        AWIA
                        AWIA
                        AWI
                        @mfalkvidd Good observation. Probably the the result of an 'efficient' copy/paste :flushed:
                        The line
                        I there with no reason, can be deleted...
                        • Tore André RosanderT
                          Tore André Rosander
                          Im building the same light, but i use 12v LED strips controlled with mosfets. Is it possible to use the same scetch?
                          • Tore André RosanderT Tore André Rosander
                            AWIA
                            AWIA
                            AWI
                            @Tore-André-Rosander If you use standard 12v strips it won't work as such. The ws2812/11 chips in the strip used make it possible to address the individual led's.
                            Tore André RosanderT 1 Reply Last reply
                            • AWIA AWI
                              Tore André Rosander
                              wrote on last edited by Tore André Rosander
                              #22
                              @AWI Is this code for version 1.5?
                              Im trying to compile it for the dev (v2) but i get a lot of errors.
                              Mostly alot of code that "was not declared in this scope".
                              EDIT: Just found your link to the "Conversion guide", will have look at it!
                              • mfalkviddM
                                A version for MySensors 2 is available at https://forum.mysensors.org/topic/4934/wall-mounted-mood-light-v2
                                12.5k
