  3. Wall mounted 'mood light'
23 Posts 10 Posters 20.6k Views 15 Watching
  • TheoLT
    TheoLT
    TheoL
    Love your project and good use of the wall mount PCB. You showed me that I really need to order a couple of those I'm tired of all the phone charger cables ;-)
    I couldn't really see it well on the photo's. But did you paint the back of light as well, the MDF part I mean? If not I would do it, because MDF has the tendency to bend when painted on one side only. That's why I use plywood or solid wood for almost all of my projects. Learned it the hard way, I made a cover for my radiator once out of MDF and painted only the outside. In just a day or two the cover started to bend. Which was really not funny after spending two weekends making it.
    If you decide to paint the back side as well I'd use a white paint, that reflects the light coming from the ledstrip better. Other colors tend to absorp the light more.
    I'm also really curious about how you mounted the MDF to the wall. It looks really great.
    AWIA 1 Reply Last reply
    • G
      G
      gloob
      Could you please post your Arduino sketch, as I want to build something similar?
      Thank you.
      • TheoLT TheoL
        AWIA
        AWIA
        AWI
        @TheoL Thank you for the tips. I painted the board on all sides. I would prefer real wood but MDF is really easy to model and I had a few sq meter left. I hate the dust though. For mounting i used a hook which fits in hole.
        upload-11a9a350-c01b-442e-b3a2-3e0c76805b15
        • G gloob
          Thank you.
          AWIA
          AWIA
          AWI
          wrote on last edited by AWI
          @gloob I will post the sketch after cleaning it up. I need to add on/off/ scene button functionality.
          I allways try to make my nodes as autonomous as possible. That way i'm not fully controller dependent and it's more safe.
            mvdarend
            wrote on last edited by mvdarend
            @AWI said:
            ...and discarded some of the safety measures :blush:...
            I see you've got something soldered where the fuse should be, but for the rest I can't see what you've left out. Could you tell us which components you eventually ended up using? (or not using, whatever you prefer :))
            • M mvdarend
              AWIA
              AWIA
              AWI
              @mvdarend I have not used the SSR, the varistors and the fuse on the low voltage side...
              • AWIA
                AWIA
                AWI
                I have updated the sketch to allow for independent operation and added a few light effects. The sketch can be used for any "Neopixel" (WS2812(B)) LED strip/ stick/ circle. Uses V_RBG and/ or V_STATUS and separate actuators (or the push button with long push) to switch the Pattern and Alarm. A few examples:
                "Alarm"
                https://www.youtube.com/watch?v=52YZD2pbYnQ
                "Fireplace"
                https://www.youtube.com/watch?v=-yx5zV5yQmo
                "Candle light" and "Rainbow" mostly non blocking code. If somebody want to add please do so.
                The sketch, heavily commented. Can always be improved
                 PROJECT: MySensors / RGB light NEOPIXEL
                 PROGRAMMER: AWI
                 DATE: october 10, 2015/ last update: october 14, 2015
                 FILE: AWI_RGB.ino
                 LICENSE: Public domain
                 Hardware: Nano and MySensors 1.5, Wall light 16 WS2812B leds (neopixel)
                 Special:
                	uses Fastled library with NeoPixel (great & fast RBG/HSV universal library) 			https://github.com/FastLED/FastLED
                 SUMMARY:
                	Different patterns and brightness settings
                	Button switches on/off and cycles through all Color patterns on long press
                 Remarks:
                	Fixed node-id
                #include <FastLED.h>										// https://github.com/FastLED/FastLED
                #include <Button.h>											// https://github.com/JChristensen/Button
                const int stripPin = 5 ;									// pin where 2812 LED strip is connected
                const int buttonPin = 4 ;									// push button
                const int numPixel = 16 ;									// set to number of pixels (x top / y bottom)
                const int NODE_ID = 62 ;									// fixed MySensors node id
                const int RGB_LightChild = 0 ;								// Child Id's, standard light child on/off/ dim
                const int RGB_RGBChild = 1 ;								// RGB light child (on/off/dim/color, if controller supports V_RBG))
                const int RGB_SolidColorChild = 2 ;							// when set, node reads Color text from ColorTextChild
                const int RGB_TextColorChild = 3 ;							// Holds Text value for color (custom colors from controller)
                const int RGB_AlarmPatternChild = 4 ;						// Switches to alarm status
                const int RGB_NextPatternChild = 5 ;						// Move to next pattern when set
                CRGB leds[numPixel];
                // Kelving colors: Light & daylight (in Fastled reference only)
                /// 1900 Kelvin Candle=0xFF9329 /* 1900 K, 255, 147, 41 */,
                /// 2600 Kelvin Tungsten40W=0xFFC58F /* 2600 K, 255, 197, 143 */,
                /// 2850 Kelvin Tungsten100W=0xFFD6AA /* 2850 K, 255, 214, 170 */,
                /// 3200 Kelvin	Halogen=0xFFF1E0 /* 3200 K, 255, 241, 224 */,
                /// 5200 Kelvin CarbonArc=0xFFFAF4 /* 5200 K, 255, 250, 244 */,
                /// 5400 Kelvin HighNoonSun=0xFFFFFB /* 5400 K, 255, 255, 251 */,
                /// 6000 Kelvin DirectSunlight=0xFFFFFF /* 6000 K, 255, 255, 255 */,
                /// 7000 Kelvin OvercastSky=0xC9E2FF /* 7000 K, 201, 226, 255 */,
                /// 20000 Kelvin ClearBlueSky=0x409CFF /* 20000 K, 64, 156, 255 */
                char controllerRGBvalue[] = "FFDEAD";		 				// Controller sent RGB value, default
                uint16_t curBrightness, actualBrightness, controllerRGBbrightness = 0x7F ;	// Brightness globals
                unsigned long updateBrightnessDelay, lastBrightnessUpdate ; // Brightness timers
                int RGBonoff ;												// OnOff flag
                enum { pSolid, pOff, pAlarm, pFire, pFire2, pCandle, pRainbow}  ;	// Pattern globals (stored in int for convenience)
                const int lastPatternIdx = pRainbow + 1 ;					// use last pattern for patterncount
                int curPattern ;											// current pattern
                unsigned long updatePatternDelay, lastPatternUpdate ;		// Pattern timers
                unsigned long idleTimer = millis() ;						// return to idle timer
                int idleTime = 10000 ;										// return to idle after 10 secs
                // initialize MySensors (MySensors 1.5 style)
                MyTransportNRF24 transport(9, 10); 							// Ceech board, 3.3v (7,8)  (pin default 9,10)
                MySensor gw(transport);
                MyMessage lightRGBMsg(RGB_LightChild,  V_RGB);				// standard messages, light
                MyMessage lightdimmerMsG(RGB_LightChild ,V_DIMMER);
                MyMessage lightOnOffMessage(RGB_LightChild, V_STATUS);
                Button myBtn(buttonPin, true, true, 20);					//Declare the button (pin, pull_up, invert, debounce_ms)
                // Simple state machine for button state
                enum {sIdle, sBrightness, sPattern} ;						 // simple state machine for button press
                int State ;
                	FastLED.addLeds<NEOPIXEL, stripPin >(leds, numPixel) ;	// initialize led strip .setCorrection(TypicalLEDStrip);
                	gw.begin(incomingMessage, NODE_ID, false);				// initialize MySensors
                	gw.sendSketchInfo("AWI RGB Wall 0", "1.0");
                	gw.present(RGB_RGBChild, S_RGB_LIGHT, "RGB Wall RGB 0");// present to controller
                	gw.present(RGB_LightChild, S_LIGHT, "RGB Wall Light 0");
                    gw.present(RGB_SolidColorChild, S_LIGHT, "RGB Set Solid color (text) 0");
                	gw.present(RGB_TextColorChild, S_INFO, "RGB Wall textcolor 0");
                	gw.present(RGB_AlarmPatternChild, S_BINARY, "RGB Wall Alarm 0");
                	gw.present(RGB_NextPatternChild, S_BINARY, "RGB Wall Pattern 0");
                	// initialize strip with color and show (strip expects long, so convert from String)
                	for(int i = 0 ; i < 6 ; i++) {							// get color value from EEPROM (6 char)
                		controllerRGBvalue[i] = gw.loadState(i) ;
                	setLightPattern(pSolid, NULL) ;							// default controller Solid
                	FastLED.show();
                	State = sIdle ;											// Initial state
                	//randomSeed(analogRead(0));
                // read button and act accordingly
                // short press: on/off
                // longer press: set patterns with following short press
                // long press: set brightness increase
                	gw.process();											// wait for incoming messages
                	myBtn.read();               							//Read the button (only read)
                	unsigned long now = millis(); 							// loop timer reference
                	switch (State) {
                		case sIdle:											// default state, browse through patterns
                			if (myBtn.wasReleased()){						// light on/ off in idle
                				RGBonoff = !RGBonoff ;						// invert light state
                				setLightPattern((RGBonoff == 1)?pOff:pSolid, 100);
                				gw.send(lightOnOffMessage.set(RGBonoff));	// and update controller
                			} else if (myBtn.pressedFor(500)){				// move to Pattern update state with long press
                				idleTimer = now ;							// return to idle after ...
                				State = sPattern ;
                			break ;
                		case sPattern:										// entered after long press
                			if (myBtn.pressedFor(2000)){					// when press even longer move to Brightness update
                				State = sBrightness ;
                			} else if (myBtn.wasPressed()){
                				setLightPattern((curPattern + 1) % lastPatternIdx, 500 ); // increase pattern and wrap
                				idleTimer = now ;
                			} else if ( now > idleTime + idleTimer  ){		// return to idle after ...
                				State = sIdle ;
                			break ;
                		case sBrightness:									// entered after looong press
                			if (myBtn.wasPressed()){							// if pressed again increase brightness
                				setLightBrightness((curBrightness+1) % 0xFF, 0) ; // increase brightness and wrap (0..0xFF)
                				idleTimer = now ;
                				State = sIdle ;
                			break ;
                		default :
                			State = sIdle ;
                			break ;
                	updateLightBrightness();								// update Brightness if time
                	updateLightPattern();									// update Pattern if time
                // Sets the light brightness, takes value and time (ms) as input
                void setLightBrightness(int newBrightness, unsigned long updateTime){
                	// global: curBrightness, actualBrightness, updateBrightnessDelay
                	updateBrightnessDelay = updateTime / 0xFF ;				// delay = time / max steps
                	actualBrightness = curBrightness ;						// assume curBrightness is actual
                	curBrightness = newBrightness ;							// set curBrightness to new value, rest is done in update
                // Update the light brightness if time
                void updateLightBrightness(){
                	// global: curBrightness, actualBrightness, updateBrightnessDelay, lastBrightnessUpdate ;
                	unsigned long now = millis() ;
                	if (now > lastBrightnessUpdate + updateBrightnessDelay){// check if time for update
                		if ( actualBrightness > curBrightness) {
                			FastLED.setBrightness( actualBrightness-- );
                			FastLED.show();
                		} else if ( actualBrightness < curBrightness){
                			FastLED.setBrightness( actualBrightness++ );
                			FastLED.show();
                		lastBrightnessUpdate = now ;
                // **** Pattern routines *****
                // Sets and initializes the light pattern if nescessary
                void setLightPattern( int newPattern, unsigned long updateDelay){
                	// global: curPattern, updatePatternDelay
                	curPattern = newPattern ;
                	updatePatternDelay = updateDelay ;						// delay for next pattern update, can be changed in pattern
                	switch(curPattern){
                		case pSolid:										//  solid is controller value in all pixels
                			for(int i = 0 ; i < numPixel ; i++) leds[i] = strtol( controllerRGBvalue, NULL, 16);
                			FastLED.show();
                			break ;
                		case pOff:											//  off state all pixels off
                			for(int i = 0 ; i < numPixel ; i++) leds[i] = 0 ;
                			FastLED.show();
                			break ;
                		default :
                			break ;
                // Update the light pattern when time for it
                void updateLightPattern(){
                	// global: curPattern, updatePatternDelay, lastPatternUpdate
                	if (now > lastPatternUpdate + updatePatternDelay){		// check if time for update
                		switch (curPattern) {
                			case pAlarm:									// flash light
                				patternAlarm();
                				break ;
                			case pFire:										// wild fire
                				patternFire();
                				break ;
                			case pFire2:									// cosy fire
                				patternFire2();
                				break ;
                			case pCandle:									// flame
                				patternCandle();
                				break ;
                			case pRainbow:									// rotating rainbow
                				patternRainbow();
                				break ;
                			case pSolid:									// do nothing fall through
                			case pOff:
                			default	:										// def
                				break ;
                		lastPatternUpdate = now ;
                // Define the different patterns
                // Alarm - intermittent white and red color, full intensity, intermittent top & bottom half
                void patternAlarm() {
                    static boolean topBot ;							// indicates direction for next entry
                	const CRGB colorTop = CRGB(0xFF, 0, 0 );				// red color
                	const CRGB colorBottom = CRGB(0xFF, 0xFF, 0xFF );		// white color
                	FastLED.setBrightness(0xFF);							// set the strip brightness
                	for(int i=0; i <= (numPixel / 2 - 1) ; i++) {					// for half of strip size
                		leds[i] = topBot?colorTop:colorBottom ;
                		leds[i+ (numPixel/2)] = topBot?colorBottom:colorTop ;
                	topBot = !topBot ;										// switch direction
                	FastLED.show();
                // Simulate fire with red color, varying number of leds intensity & tempo
                void patternFire() {
                    byte numberLeds = random(0,numPixel);					// start number and end of led's for flickering
                    byte lum = random(100,255);								// set brightness
                    CRGB color = CRGB(200, 50+random(1,180),0 );			// get red color with varying green
                    for(int i=0; i <= numberLeds; i++) {
                      leds[i] = color ;
                      FastLED.setBrightness(lum);							// set the strip brightness
                      FastLED.show();
                      gw.wait(random(0,10));
                    updatePatternDelay = 100 ;
                // Simulate fire with red color and varying intensity & tempo
                void patternFire2() {
                    CRGB color = CRGB(200, random(100,150),0);				// get red color with varying green
                    for (byte p=0; p < numPixel; p++) {
                      leds[p] = color;
                    FastLED.setBrightness(random(50,255));
                    FastLED.show();
                    updatePatternDelay = random(20,300);					// variable delay
                // Simulate candle based on fire with red color, varying number of leds intensity & tempo
                void patternCandle() {
                    byte lum = random(60, 80);								// set brightness
                    CRGB color = CRGB(200, 50+random(40,100),0 );			// get red color with varying green
                      leds[i] = color ;
                      FastLED.show();
                      gw.wait(random(5,10));
                void patternRainbow() {
                	static uint16_t hue ;								// starting color
                	FastLED.clear();
                	// for(hue=10; hue<255*3; hue++) {
                	hue = (hue+1) % 0xFF ;									// incerease hue and wrap
                	fill_rainbow( leds, numPixel , hue /*static hue value */, 5);// set a rainbow from hue to last in stepsize 5
                	FastLED.show();
                // Incoming messages from MySensors
                	int ID = message.sensor;
                	Serial.print("Sensor: ");
                	Serial.println(ID);
                	switch (ID){
                		case RGB_LightChild:								// same behaviour as RGB child/ fall through
                		case RGB_RGBChild:									// if controller can handle V_RGB
                			if (message.type == V_RGB) {					// check for RGB type
                				strcpy(controllerRGBvalue, message.getString());// get the payload
                				setLightPattern(pSolid, NULL);				// and set solid pattern
                			} else if (message.type == V_DIMMER) {			// if DIMMER type, adjust brightness
                				controllerRGBbrightness = map(message.getLong(), 0, 100, 0, 255);
                				setLightBrightness(controllerRGBbrightness, 2000) ;
                			} else if (message.type == V_STATUS) {			// if on/off type, toggle brightness
                				RGBonoff = message.getInt();
                				setLightBrightness((RGBonoff == 1)?controllerRGBbrightness:0, 2000);
                			break ;
                		case RGB_SolidColorChild:							// request color from controller
                			if (message.type == V_STATUS) {					// if get color from text child
                				gw.request(RGB_TextColorChild, V_TEXT);
                				setLightPattern(pSolid, NULL);					// and set solid pattern (if not alre)
                			break ;
                		case RGB_TextColorChild:							// Text color from controller
                			if (message.type == V_TEXT) {					// if get color from text child
                				for(int i = 0 ; i < 6 ; i++) {				// save color value to EEPROM (6 char)
                					gw.saveState(i, controllerRGBvalue[i]) ;}// Save to EEPROM
                			break ;
                		case RGB_AlarmPatternChild:							// set Alarm pattern
                				if (message.getInt() == 1){
                					setLightPattern(pAlarm, 500);			// set slow alarm pattern
                					FastLED.setBrightness(curBrightness);
                			break ;
                		case RGB_NextPatternChild:							// next pattern
                				if (message.getInt() == 1 ) {
                			break ;
                    FastLED.show();
                	dispRGBstat();
                // debug
                // display the status of all RGB: controller, requested, real
                void dispRGBstat(void){
                    Serial.print(" Color: "); Serial.print(controllerRGBvalue);
                    Serial.print(" Brightness: "); Serial.println(controllerRGBbrightness);
                  mickaelr30
                  wrote on last edited by mickaelr30
                  hello,
                  i've problem with the sketch :+1 :
                  sketch_dec08a.ino: In function 'void setup()':
                  sketch_dec08a:89: error: 'S_INFO' was not declared in this scope
                  sketch_dec08a.ino: In function 'void incomingMessage(const MyMessage&)':
                  sketch_dec08a:308: error: 'V_TEXT' was not declared in this scope
                  sketch_dec08a:313: error: 'V_TEXT' was not declared in this scope
                  exit status 1
                    S_INFO inly exist in the dev branch.
                    That also means you have to convert the 1.5 sketch. Convert instructions here:
                    https://docs.google.com/document/d/1NKq5uuNdnxF5jWnum7VT32mbKLjuvqlx2A5D1qQ-H3Q/edit#
                    • A
                      Adam McCartney
                      @mickaelr30 , did you ever get this working with 1.5?
                      i've got the upgrade instructions, but struggling to reverse it so it works with my current setup. Don't think i'm quite ready to upgrade all my nodes to dev quite yet.
                      • A Adam McCartney
                        AWIA
                        AWIA
                        AWI
                        @Adam-McCartney add these lines in the header and you will have it working with the production version...
                        // V_TEXT & V_INFO when not using the DEVELOPMENT version
                        const byte V_TEXT = 47 ;					// values taken from development edition MyMessage.h
                        const byte S_INFO = 36 ;
                        • A
                          Adam McCartney
                          awesome, thanks!
                          I'm more of a butcher than a surgeon. I can quite happily take things apart, but fixing things usually goes right over my head!!
                            Mehdi HAMIDA
                            I really love this project.
                            May I can include it in all of my sensors (doorbell, thermostat, alarm,...).
                            Really sounds great, thanks
                              Mehdi HAMIDA
                              Is there a way to get your wiring schema ?
                              • M Mehdi HAMIDA
                                AWIA
                                AWIA
                                AWI
                                @Mehdi-HAMIDA There is nothing to it. A standard MySensors node (5v) with the strip connected to D5 and a button between ground and D4.
                                • AWIA AWI
                                  Mehdi HAMIDA
                                  @AWI OK, just ordered the PCB
                                  thx
                                  • mfalkviddM
                                    @AWI: Won't this part of your sketch create sort of an endless loop?
                                      AWIA
                                      AWIA
                                      AWI
                                      @mfalkvidd Good observation. Probably the the result of an 'efficient' copy/paste :flushed:
                                      The line
                                      I there with no reason, can be deleted...
                                      • Tore André RosanderT
                                        Tore André Rosander
                                        Im building the same light, but i use 12v LED strips controlled with mosfets. Is it possible to use the same scetch?
                                        • Tore André RosanderT Tore André Rosander
                                          AWIA
                                          AWIA
                                          AWI
                                          @Tore-André-Rosander If you use standard 12v strips it won't work as such. The ws2812/11 chips in the strip used make it possible to address the individual led's.
                                          Tore André RosanderT 1 Reply Last reply
                                          12.5k
