  3. 💬 Wall Socket Insertable Node
rfm69atsha204amysensorsrelaypower supply
77 Posts 21 Posters 32.8k Views 27 Watching
  • O Offline
    O Offline
    openhardware.io
    https://www.openhardware.io/view/101/Wall-Socket-Insertable-Node
    • kalinaK Offline
      kalinaK Offline
      kalina
      As for q3. Perhaps in this case it is better to use a bipolar transistor (like BC847). MOSFET is more sensitive to voltage spikes during operation with inductive loads that can damage it.
      K 1 Reply Last reply
      • kalinaK kalina
        K Offline
        K Offline
        Koresh
        wrote on last edited by Koresh
        Hm... How about protection diode D5?
        kalinaK 1 Reply Last reply
        • K Koresh
          kalinaK Offline
          kalinaK Offline
          kalina
          @Koresh
          In my opinion, the diode can't guarantee 100% security for MOSFET, you can also look here- https://www.google.com.ua/search?q=connect+relay+to+microcontroller&espv=2&biw=960&bih=472&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwje0OGVj_DMAhWCOSwKHQOFAOoQsAQIGQ
          • K Offline
            K Offline
            Koresh
            @kalina said:
            @Koresh
            OK. I will check this configuration carefully, and add snabber or change this circuit part if it will be needed.
            • Cliff KarlssonC Offline
              Cliff Karlsson
              when can we buy your pcb's ?
                K Offline
                K Offline
                Koresh
                @Cliff-Karlsson Custom transformers samples have been produced. I hope to receive completed devices samples in two weeks.
                • H Offline
                  H Offline
                  hugows
                  bump! did you receive those?
                  • K Offline
                    K Offline
                    Koresh
                    Unfortunately everything that could go wrong went wrong.
                    So sample transformers are ready, sample boards are ready too. But I am expecting package with all my new boards and components only next week and hope to start testing soon.
                    • S Offline
                      skatun
                      Hi, will it also measure voltage or just current? Because to calculate power you need voltage as well? Is it possible to add dht22 and one wire temperature sensor to it as well, then it could replace all the temperature controllers for heating cables.
                      • S skatun
                        K Offline
                        K Offline
                        Koresh
                        Hello. RFM69 module has built-in temperature sensor. If you look on the board carefully you will find a lot if arduino pins. You can use it for any sensors if it is critical for you.
                        What controllers are you referencing to?
                        About voltage... I think you know voltage in your sockets without any sensors with enough accuracy :smiley:
                        Boards and components are under customs clearance now... Expecting :)
                        S 1 Reply Last reply
                        • K Koresh
                          skatun
                          @Koresh
                          Check out this interesting topic on accursy for power measurement:
                          Greg
                          Do you have data on the inbuilt temperature sensor?
                          • S skatun
                            @Koresh
                            Greg
                            K Offline
                            K Offline
                            Koresh
                            @skatun said:
                            @Koresh
                            Greg
                            Frankly speaking I had added current sensor last night before test board production and I had no goal to measure power very accurate. The main goal of this sensor is ability to check fact of load (forget iron for example :)). Of course I can improve it in further versions, but it is not the main feature now.
                            I tested this temperature sensor and it works fine. I'am not sure mysensors library supports it. If it doesn't support it I will try to add this ability after hardware testing.
                            • K Koresh
                              @skatun said:
                              @Koresh
                              Greg
                              skatun
                              @Koresh Ok, I am looking forward to hear how your board turns out. So what I am looking for is something to replace this temperature controller. I was thinking about using esp8266 wifi chip instead of the radio, since power is not a big issue since its connected to the power line. Then people like my parents can use it with IFTTT and do not have to add a gateway. I was also thinking about adding a connector for a nextion display, just in case you want to display the temperature, use it as input to set temperature etc. It should also have a better temperature and humidity chip then the one inbuilt I think. Screw terminal to connect floor temperature sensor. Measure power accurately. Well if you would like to cooperate on version2 of your board let me know. I would like to make 20 units or so for now.
                              • K Offline
                                K Offline
                                Koresh
                                I'm having first success with this board. Power supply works!
                                Y 1 Reply Last reply
                                • K Koresh
                                  Y Offline
                                  Y Offline
                                  @Koresh great work! You can still make July 30th :bowtie: no pressure :neckbeard:
                                  • K Offline
                                    K Offline
                                    Koresh
                                    And some photos after soldering of the main components and slight washing.
                                    Relay trick :)
                                    • Sander TeunissenS Offline
                                      Sander Teunissen
                                      Hi Koresh. Interesting project ! Are you planning to sell some assembled parts too ?
                                        Sander Teunissen
                                        I just bumped into these too:
                                        https://www.openhardware.io/view/102/Wall-Switch-Insertable-Node#tabs-instructions
                                        So interesting ! will these be sold too ?
                                        • Sander TeunissenS Sander Teunissen
                                          K Offline
                                          K Offline
                                          Koresh
                                          @Sander-Teunissen
                                          I will make a small presentation of new boards tomorrow in Breda. Of course I will try to start mass production asap :) You can check estimated prices of all boards in button size radionode thread.
                                          12.1k
