  3. 💬 Wall Socket Insertable Node
rfm69atsha204amysensorsrelaypower supply
77 Posts 21 Posters 33.9k Views 27 Watching
  • hugowsH
    hugowsH
    hugows
    bump! did you receive those?
    • KoreshK
      KoreshK
      Koresh
      Unfortunately everything that could go wrong went wrong.
      So sample transformers are ready, sample boards are ready too. But I am expecting package with all my new boards and components only next week and hope to start testing soon.
      • skatunS
        skatunS
        skatun
        Hi, will it also measure voltage or just current? Because to calculate power you need voltage as well? Is it possible to add dht22 and one wire temperature sensor to it as well, then it could replace all the temperature controllers for heating cables.
        KoreshK 1 Reply Last reply
        • skatunS skatun
          KoreshK
          KoreshK
          Koresh
          wrote on last edited by Koresh
          Hello. RFM69 module has built-in temperature sensor. If you look on the board carefully you will find a lot if arduino pins. You can use it for any sensors if it is critical for you.
          What controllers are you referencing to?
          About voltage... I think you know voltage in your sockets without any sensors with enough accuracy :smiley:
          Boards and components are under customs clearance now... Expecting :)
          skatunS 1 Reply Last reply
          • KoreshK Koresh
            skatunS
            skatunS
            skatun
            @Koresh
            Check out this interesting topic on accursy for power measurement:
            Greg
            Do you have data on the inbuilt temperature sensor?
            • skatunS skatun
              @Koresh
              Greg
              KoreshK
              KoreshK
              Koresh
              @skatun said:
              @Koresh
              Greg
              Frankly speaking I had added current sensor last night before test board production and I had no goal to measure power very accurate. The main goal of this sensor is ability to check fact of load (forget iron for example :)). Of course I can improve it in further versions, but it is not the main feature now.
              I tested this temperature sensor and it works fine. I'am not sure mysensors library supports it. If it doesn't support it I will try to add this ability after hardware testing.
              • KoreshK Koresh
                @skatun said:
                @Koresh
                Greg
                skatunS
                skatunS
                skatun
                @Koresh Ok, I am looking forward to hear how your board turns out. So what I am looking for is something to replace this temperature controller. I was thinking about using esp8266 wifi chip instead of the radio, since power is not a big issue since its connected to the power line. Then people like my parents can use it with IFTTT and do not have to add a gateway. I was also thinking about adding a connector for a nextion display, just in case you want to display the temperature, use it as input to set temperature etc. It should also have a better temperature and humidity chip then the one inbuilt I think. Screw terminal to connect floor temperature sensor. Measure power accurately. Well if you would like to cooperate on version2 of your board let me know. I would like to make 20 units or so for now.
                • KoreshK
                  KoreshK
                  Koresh
                  I'm having first success with this board. Power supply works!
                  • KoreshK Koresh
                    @Koresh great work! You can still make July 30th :bowtie: no pressure :neckbeard:
                    • KoreshK
                      KoreshK
                      Koresh
                      And some photos after soldering of the main components and slight washing.
                      Relay trick :)
                      • Sander TeunissenS
                        Sander TeunissenS
                        Sander Teunissen
                        Hi Koresh. Interesting project ! Are you planning to sell some assembled parts too ?
                        • Sander TeunissenS
                          Sander TeunissenS
                          Sander Teunissen
                          I just bumped into these too:
                          https://www.openhardware.io/view/102/Wall-Switch-Insertable-Node#tabs-instructions
                          So interesting ! will these be sold too ?
                          • Sander TeunissenS Sander Teunissen
                            KoreshK
                            KoreshK
                            Koresh
                            @Sander-Teunissen
                            I will make a small presentation of new boards tomorrow in Breda. Of course I will try to start mass production asap :) You can check estimated prices of all boards in button size radionode thread.
                            • tonnerre33T
                              tonnerre33T
                              tonnerre33
                              Hi, it's a very intersting project but what about the protections of the switching power supply ?
                              I see a varistor but neither fuse nor Thermal Cutoffs.
                              • tonnerre33T tonnerre33
                                KoreshK
                                KoreshK
                                Koresh
                                @tonnerre33 do not worry. It will be in final version + we can use temperature sensor in rfm modult to switch of the relay.
                                • sinczeS
                                  sinczeS
                                  sincze
                                  MySensors Evangelist
                                  Very nice to see this device today live in Breda ;-)
                                  • fisherF
                                    fisherF
                                    fisher
                                    Very nice project. Looking forward to buy it. It would be nice to have possibility to trigger switch via local button (as in Fibaro) and not only via radio. It's possible from software point of view but board should be modified slightly. Is it in your todo list @Koresh?
                                    • Y
                                      Y
                                      yury
                                      wrote on last edited by yury
                                      #25
                                      @fisher are you referring to touch sensor button or momentary push button?
                                      • fisherF
                                        fisherF
                                        fisher
                                        @yury yes
                                        • fisherF fisher
                                          KoreshK
                                          KoreshK
                                          Koresh
                                          #27
                                          Thanks! We thought about this feature, thanks for your reminder. I've successully added pins for button. You can see new JST connector for button on the screenshot below. I hope this solution is reliable enough
                                          I almost forgot... Now this board contains SPI flash which implements OTA upgrade ability :wink:
                                          fisherF 2 Replies Last reply
