  3. Help combining 2 Sketches
6 Posts 3 Posters 2.2k Views 4 Watching
  • UnciU Offline
    UnciU Offline
    Unci
    Hi everybody,
    sry for my bad english at the beginning!
    I'm very noobie in arduino & my sensors.
    I try to combining a DHT11 & a MQ135 on a arduino nano with a NRF24I01+.
    I think the connection should be ok.
    My problem is the sketch! I surely made a mistake, but i dont know where! I took the HumiditySensor Example and the code from here:
    arduino/AirQuality-MQ135.ino
     * Version 1.0 - Henrik EKblad
     * This sketch provides an example how to implement a humidity/temperature
     * sensor using DHT11/DHT-22
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define HUMIDITY_SENSOR_DIGITAL_PIN 8
    #define CHILD_ID_AIQ 3
    #define AIQ_SENSOR_ANALOG_PIN 0
    #define MQ135_DEFAULTPPM 399 //default ppm of CO2 for calibration
    #define MQ135_DEFAULTRO 68550 //default Ro for MQ135_DEFAULTPPM ppm of CO2
    #define MQ135_SCALINGFACTOR 116.6020682 //CO2 gas value
    #define MQ135_EXPONENT -2.769034857 //CO2 gas value
    #define MQ135_MAXRSRO 2.428 //for CO2
    #define MQ135_MINRSRO 0.358 //for CO2
    float mq135_ro = 10000.0;    // this has to be tuned 10K Ohm
    int val = 0;                 // variable to store the value coming from the sensor
    float valAIQ =0.0;
    float lastAIQ =0.0;
    DHT dht;
    MyMessage msg(CHILD_ID_AIQ, V_LEVEL);
    float lastTemp;
    float lastHum;
    boolean metric = true;
      gw.begin();
      gw.sendSketchInfo("Humidity", "1.0");
      gw.begin();
      gw.sendSketchInfo("AIQ Sensor MQ135", "1.0");
      gw.present(CHILD_ID_AIQ, S_AIR_QUALITY);
     * get the calibrated ro based upon read resistance, and a know ppm
    long mq135_getro(long resvalue, double ppm) {
    return (long)(resvalue * exp( log(MQ135_SCALINGFACTOR/ppm) / MQ135_EXPONENT ));
     * get the ppm concentration
    double mq135_getppm(long resvalue, long ro) {
    double ret = 0;
    double validinterval = 0;
    validinterval = resvalue/(double)ro;
    if(validinterval<MQ135_MAXRSRO && validinterval>MQ135_MINRSRO) {
    ret = (double)MQ135_SCALINGFACTOR * pow( ((double)resvalue/ro), MQ135_EXPONENT);
    return ret;
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
      uint16_t valr = analogRead(AIQ_SENSOR_ANALOG_PIN);// Get AIQ value
      Serial.println(val);
      uint16_t val =  ((float)22000*(1023-valr)/valr);
      //during clean air calibration, read the Ro value and replace MQ135_DEFAULTRO value with it, you can even deactivate following function call.
      mq135_ro = mq135_getro(val, MQ135_DEFAULTPPM);
      //convert to ppm (using default ro)
      valAIQ = mq135_getppm(val, MQ135_DEFAULTRO);
      Serial.print ( "Val / Ro / value:");
      Serial.print ( val);
      Serial.print ( " / ");
      Serial.print ( mq135_ro);
      Serial.print ( valAIQ);
      if (valAIQ != lastAIQ) {
          gw.send(msg.set(MQ135_DEFAULTPPM+(int)ceil(valAIQ)));
          lastAIQ = ceil(valAIQ);
      // Power down the radio.  Note that the radio will get powered back up
      // on the next write() call.
      gw.sleep(SLEEP_TIME); //sleep for: sleepTime
    /*****************************  MQGetPercentage **********************************
    Input:   rs_ro_ratio - Rs divided by Ro
             pcurve      - pointer to the curve of the target gas
    Output:  ppm of the target gas
    Remarks: By using the slope and a point of the line. The x(logarithmic value of ppm)
             of the line could be derived if y(rs_ro_ratio) is provided. As it is a
             logarithmic coordinate, power of 10 is used to convert the result to non-logarithmic
             value.
    int  MQGetPercentage(float rs_ro_ratio, float ro, float *pcurve)
      return (double)(pcurve[0] * pow(((double)rs_ro_ratio/ro), pcurve[1]));
    When I try to upload it there comes the output:
    Arduino: 1.6.9 (Windows 10), Board: "Arduino Nano, ATmega328"
    WARNUNG: Kategorie '' in der Bibliothek UIPEthernet ist ungültig und wird auf 'Uncategorized' festgelegt
    libraries\MySensors\MySensor.cpp.o: In function `MySensor::MySensor(MyTransport&, MyHw&)':
    C:\Users\Mike\Documents\Arduino\libraries\MySensors/MySensor.cpp:52: multiple definition of `MySensor::MySensor(MyTransport&, MyHw&)'
    sketch\MySensor.cpp.o:sketch/MySensor.cpp:52: first defined here
    C:\Users\Mike\Documents\Arduino\libraries\MySensors/MySensor.cpp:52: multiple definition of `MySensor::getNodeId()'
    C:\Users\Mike\Documents\Arduino\libraries\MySensors/MySensor.cpp:52: multiple definition of `MySensor::getConfig()'
    C:\Users\Mike\Documents\Arduino\libraries\MySensors/MySensor.cpp:52: multiple definition of `MySensor::sendWrite(unsigned char, MyMessage&)'
    C:\Users\Mike\Documents\Arduino\libraries\MySensors/MySensor.cpp:52: multiple definition of `MySensor::getLastMessage()'
    C:\Users\Mike\Documents\Arduino\libraries\MySensors/MySensor.cpp:52: multiple definition of `MySensor::saveState(unsigned char, unsigned char)'
    C:\Users\Mike\Documents\Arduino\libraries\MySensors/MySensor.cpp:52: multiple definition of `MySensor::loadState(unsigned char)'
    C:\Users\Mike\Documents\Arduino\libraries\MySensors/MySensor.cpp:52: multiple definition of `MySensor::wait(unsigned long)'
    C:\Users\Mike\Documents\Arduino\libraries\MySensors/MySensor.cpp:52: multiple definition of `MySensor::process()'
    C:\Users\Mike\Documents\Arduino\libraries\MySensors/MySensor.cpp:52: multiple definition of `MySensor::requestNodeId()'
    C:\Users\Mike\Documents\Arduino\libraries\MySensors/MySensor.cpp:52: multiple definition of `MySensor::findParentNode()'
    C:\Users\Mike\Documents\Arduino\libraries\MySensors/MySensor.cpp:52: multiple definition of `MySensor::sendRoute(MyMessage&)'
    C:\Users\Mike\Documents\Arduino\libraries\MySensors/MySensor.cpp:52: multiple definition of `MySensor::send(MyMessage&, bool)'
    C:\Users\Mike\Documents\Arduino\libraries\MySensors/MySensor.cpp:52: multiple definition of `MySensor::sendBatteryLevel(unsigned char, bool)'
    C:\Users\Mike\Documents\Arduino\libraries\MySensors/MySensor.cpp:52: multiple definition of `MySensor::present(unsigned char, unsigned char, char const*, bool)'
    C:\Users\Mike\Documents\Arduino\libraries\MySensors/MySensor.cpp:52: multiple definition of `MySensor::sendSketchInfo(char const*, char const*, bool)'
    C:\Users\Mike\Documents\Arduino\libraries\MySensors/MySensor.cpp:52: multiple definition of `MySensor::request(unsigned char, unsigned char, unsigned char)'
    C:\Users\Mike\Documents\Arduino\libraries\MySensors/MySensor.cpp:52: multiple definition of `MySensor::requestTime(void (*)(unsigned long))'
    C:\Users\Mike\Documents\Arduino\libraries\MySensors/MySensor.cpp:52: multiple definition of `MySensor::setupNode()'
    C:\Users\Mike\Documents\Arduino\libraries\MySensors/MySensor.cpp:52: multiple definition of `MySensor::begin(void (*)(MyMessage const&), unsigned char, bool, unsigned char)'
    C:\Users\Mike\Documents\Arduino\libraries\MySensors/MySensor.cpp:52: multiple definition of `MySensor::sleep(unsigned long)'
    C:\Users\Mike\Documents\Arduino\libraries\MySensors/MySensor.cpp:52: multiple definition of `MySensor::sleep(unsigned char, unsigned char, unsigned long)'
    Mehrere Bibliotheken wurden für "DHT.h" gefunden
     Benutzt: C:\Users\Mike\Documents\Arduino\libraries\DHT
     Nicht benutzt: C:\Users\Mike\Documents\Arduino\libraries\DHT_sensor_library
    C:\Users\Mike\Documents\Arduino\libraries\MySensors/MySensor.cpp:52: multiple definition of `MySensor::sleep(unsigned char, unsigned char, unsigned char, unsigned char, unsigned long)'
    exit status 1
    Fehler beim Kompilieren für das Board Arduino Nano.
    Dieser Bericht wäre detaillierter, wenn die Option
    "Ausführliche Ausgabe während der Kompilierung"
    in Datei -> Voreinstellungen aktiviert wäre.
    I hope somebody can help me!
    Thx Unci
    S mfalkviddM 2 Replies Last reply
    • UnciU Unci
      Hi everybody,
      float valAIQ =0.0;
      float lastAIQ =0.0;
      DHT dht;
      float lastTemp;
      float lastHum;
        gw.begin();
        gw.begin();
      double ret = 0;
      return ret;
          if (!metric) {
            lastHum = humidity;
               value.
      exit status 1
      Thx Unci
      Sparkman
      wrote on last edited by Sparkman
      @Unci said:
        gw.begin();
        gw.sendSketchInfo("Humidity & MQ315", "1.0");
      As a start, you should simplify your setup routine and only have one gw.begin. Try compiling it like that and see what you get for any remaining errors.
      Al
      • UnciU Unci
        Hi everybody,
        float valAIQ =0.0;
        float lastAIQ =0.0;
        DHT dht;
        float lastTemp;
        float lastHum;
          gw.begin();
          gw.begin();
        double ret = 0;
        return ret;
            if (!metric) {
              lastHum = humidity;
                 value.
        exit status 1
        Thx Unci
        @Unci it looks like you have copied the MySensors library into the libraries folder and into your sketch folder. MySensors should only be in the libraries folker. Delete mysensors from your sketch folder.
        • UnciU Offline
          UnciU Offline
          Unci
          Thx to your fast answers.
          @mfalkvidd thx that was the reason!
          @Sparkman thx changed it, seems to work
          Have seen some output in the serial monitor, now i just have to read more about the meaning off it ^^
          • mfalkviddM Offline
            You're very welcome. Information on bow to read the serial output is available at https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help
            • UnciU Offline
              UnciU Offline
              Unci
              Thx helped me, seems to work correct in Pimatic.
              Just have to check if the values of the MQ135 are correct.
              12.1k
