  3. 💬 jModule
💬 jModule
mysensorscontest2016
84 Posts 28 Posters 46.3k Views 24 Watching
  • julissesJ julisses
    @ted
    I do not care about the power. I use USB wall charger to power my nodes. I can recommend this model (it is almost the size of jModule after removing the case):
    http://www.aliexpress.com/item/1pc-High-Quality-5V-1A-EU-Plug-AC-Travel-USB-Wall-Charger-for-iPod-for-iPhone/32581266560.html?spm=2114.30010308.3.299.EEQVE8&ws_ab_test=searchweb201556_6,searchweb201602_5_10017_10005_10006_10034_10021_507_10022_9026_10020_10018_10019,searchweb201603_2&btsid=7f600ac6-6e52-41b9-9da5-5c4379d7a639
    m26872M
    m26872M
    m26872
    @julisses Would you mind posting a photo of what that supply looks like inside? Preferably to this thread: http://forum.mysensors.org/topic/2477/are-chinese-power-supply-chargers-that-dangerous-to-use
    julissesJ 1 Reply Last reply
    • m26872M m26872
      julissesJ
      julissesJ
      julisses
      @m26872
      Unsolder USB connector and instead of the connector use wires to connect the jModule.
      • sundberg84S
        sundberg84S
        #35
        @julisses - Be carefull...
        More info here: http://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers/ and as @m26872 said: http://forum.mysensors.org/topic/2477/are-chinese-power-supply-chargers-that-dangerous-to-use
        I have a couple of those cheap power supplies running some nodes and they tend to give up after some time as well...
        If you look after them thats fine... but im not to comfident with those cheap usb power supplies any more.
        Just a tip - as I said, have some working fine but be careful.
        • Cliff KarlssonC
          Cliff KarlssonC
          Cliff Karlsson
          Do you have a link for the angular pin-header? I noticed after soldering everything and could not get the arduino/jModule together that the angular pinheaders have the plastic in the other way. I tried with a new and just turned the pinheaders in the other way, but then the exposed pins got too short, same result when prying of every pin and turning them around manually.
          • cvanandelC
            cvanandelC
            cvanandel
            I had the same problem, I straightened out a set of angular headers, then soldered them into the board, and bend them at the place I needed.
            Not the best solution, but I had to many standard angular pins to go and buy more.
              http://www.ebay.com/itm/10pcs-90-Degree-Bent-Right-Angle-Pin-Header-Breakable-40pin-Single-Strip-2-54mm-/231215719944?hash=item35d587e608:g:cHwAAOSw3ydV2ZCV
                Nice work!
                Is there some kind of female plug that could be used instead? It's nicely compact--except for the male pins sticking out.
                  Regardless, I just now ordered some. Thanks!
                    OK, I "get it" now. The male pins that are sticking out are entirely optional.
                    • alexsh1A
                      alexsh1A
                      alexsh1
                      Did anyone do any power consumption tests on these? I cannot get it below 1.5mA. I think I need to mod my Pro Mini and remove the LED and the regulator.
                      • alexsh1A alexsh1
                        ted
                        @alexsh1
                        The regulator on the board (AMS1117) consumes several mA at idle. You may need to find an alternative that has uA level quiescent current. I modified the board to use a XC6206 serial LDO (1uA standby current, see my previous post). I have the board manufactured by dirtypcb and have made sensors. Will test the battery life soon.
                        alexsh1A C 2 Replies Last reply
                        • T ted
                          @alexsh1
                          alexsh1A
                          alexsh1A
                          alexsh1
                          #44
                          @ted thanks for your prompt reply. I do not have AMS1117 as I'm running Arduino Pro Mini 3.3V. I figured out it was the Mini itself. I had to remove the onboard regulator and the LED and right now my consumption is 6uA.
                          I'm moving away from 5V boards as I think these will be phased out eventually.
                          Good point on AMS1117 - this is not a battery friendly regulator
                          • T ted
                            I modified the design to use a XC6206 serial LDO (1uA standby current). I placed an order with dirtypcb. You can find the design here: http://dirtypcbs.com/view.php?share=19651&accesskey=2e5e31a83bf6fe21510c3bc438e12df7
                            Will update when I get the board on hand.
                            Hello @ted, thank you for the link on dirtyPCB, I just ordered some boards. Do you have any feedback related to battery life when running at 5V ?
                            • AWIA AWI
                              @Qu3Uk I can confirm (from measuring a sample) that the large pad is not connected to anything.
                              However :smirk: it is hard to beat the price of an AMS1117 and the AMS1117 SOT-223 package also has smaller thermal resistance compared to the LE33ACZ TO-92 package (all for what its worth ;-) )
                              Thank you very much for the link, I was about to buy less units for a higher price for another board, then I remembered about seeing a link with very cheap price on this thread :)
                              • cimba007C
                                cimba007C
                                cimba007
                                Doh .. I just blindly orded this board but after checking the eagle layout .. could it be that your power wiring is messed up? The AMS1117 is chained behind the ProMini LDO which I guess is very weak. Would it be much better to put the raw-input on the jModule, power the NRF24 with the AMS1117 output and the pro mini?
                                • zilogZ
                                  zilogZ
                                  zilog
                                  Are the boards uploaded to DirtyPCBs good and tested? I'd very much like to order a bunch of these but I am confused by the comments about missing pads. :? Can someone please confirm?
                                  Nca78N 1 Reply Last reply
                                  • zilogZ zilog
                                    wrote on last edited by Nca78
                                    #49
                                    What missing pads are your talking about ?
                                    I used the panelized version modified by @ted to use XC6206 regulator and it's running fine (though without regulator at the moment as I have not received them yet, I use CR2032). And if you use a 0.6mm PCB thickness it's really easy to cut with regular cissors.
                                    • T ted
                                      @alexsh1
                                      C
                                      C
                                      cabat
                                      @ted Hello! Can you share the Eagle file of your version of pcb? I mean this one: http://dirtypcbs.com/view.php?share=19651&accesskey=2e5e31a83bf6fe21510c3bc438e12df7
                                      • K
                                        K
                                        kted
                                        How about a version with the SDA & SCL pins also routed to the header?
                                        Sensors like the Si7021 are using the I2C interface
                                        • K kted
                                          I agree with you and I'm going to make a slightly different version of the board, to have both those pins available and to keep antenna away from the pro mini board.
