  3. 💬 jModule
💬 jModule
mysensorscontest2016
84 Posts 28 Posters 46.3k Views 24 Watching
  • B bassmint
    @cvanandel said:
    jModule
    can you supply osh park link. can't find it.
    AWIA
    AWIA
    AWI
    @Qu3Uk I can confirm (from measuring a sample) that the large pad is not connected to anything.
    However :smirk: it is hard to beat the price of an AMS1117 and the AMS1117 SOT-223 package also has smaller thermal resistance compared to the LE33ACZ TO-92 package (all for what its worth ;-) )
    Q Nca78N 2 Replies Last reply
    • AWIA AWI
      Q
      Q
      Qu3Uk
      @AWI Wow they are cheap - Perhaps we should get them added to the MYS Store - I need to use up the ones I've got before shipping more stuff half way around the world :D
      • A aproxx
        Any chance you will be creating a 'panelized' version of this board? With these small sizes 4 boards can be fitted on a 5 by 5cm board, while still keeping the same price. I'd be happy to order a few if that's available!
        tjay4x4
        I'm just order it, on Dirtyboard not tested yet. Maybe this what you need?
        http://dirtypcbs.com/view.php?share=18851&accesskey=01fcfdedf25cb9105e13f2d50d9ea385
        • alexsh1A
          alexsh1A
          alexsh1
          Nice one!
          I really would like to see the version of it for nrf24l01+ SMD
          • T
            ted
            Very nice. The only downside I can think of is that AMS1117 is power hungry. Is there a pin compatible regulator with uA level standby current?
            julissesJ 1 Reply Last reply
            • T ted
              julissesJ
              julissesJ
              julisses
              @ted
              I do not care about the power. I use USB wall charger to power my nodes. I can recommend this model (it is almost the size of jModule after removing the case):
              http://www.aliexpress.com/item/1pc-High-Quality-5V-1A-EU-Plug-AC-Travel-USB-Wall-Charger-for-iPod-for-iPhone/32581266560.html?spm=2114.30010308.3.299.EEQVE8&ws_ab_test=searchweb201556_6,searchweb201602_5_10017_10005_10006_10034_10021_507_10022_9026_10020_10018_10019,searchweb201603_2&btsid=7f600ac6-6e52-41b9-9da5-5c4379d7a639
              T m26872M 2 Replies Last reply
              • julissesJ julisses
                @ted
                ted
                I modified the design to use a XC6206 serial LDO (1uA standby current). I placed an order with dirtypcb. You can find the design here: http://dirtypcbs.com/view.php?share=19651&accesskey=2e5e31a83bf6fe21510c3bc438e12df7
                Will update when I get the board on hand.
                Nca78N 1 Reply Last reply
                  @ted
                  m26872M
                  m26872M
                  m26872
                  @julisses Would you mind posting a photo of what that supply looks like inside? Preferably to this thread: http://forum.mysensors.org/topic/2477/are-chinese-power-supply-chargers-that-dangerous-to-use
                  • m26872M m26872
                    julissesJ
                    julissesJ
                    julisses
                    @m26872
                    Unsolder USB connector and instead of the connector use wires to connect the jModule.
                    • sundberg84S
                      sundberg84S
                      #35
                      @julisses - Be carefull...
                      More info here: http://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers/ and as @m26872 said: http://forum.mysensors.org/topic/2477/are-chinese-power-supply-chargers-that-dangerous-to-use
                      I have a couple of those cheap power supplies running some nodes and they tend to give up after some time as well...
                      If you look after them thats fine... but im not to comfident with those cheap usb power supplies any more.
                      Just a tip - as I said, have some working fine but be careful.
                      • Cliff KarlssonC
                        Cliff KarlssonC
                        Cliff Karlsson
                        Do you have a link for the angular pin-header? I noticed after soldering everything and could not get the arduino/jModule together that the angular pinheaders have the plastic in the other way. I tried with a new and just turned the pinheaders in the other way, but then the exposed pins got too short, same result when prying of every pin and turning them around manually.
                        • cvanandelC
                          cvanandelC
                          cvanandel
                          I had the same problem, I straightened out a set of angular headers, then soldered them into the board, and bend them at the place I needed.
                          Not the best solution, but I had to many standard angular pins to go and buy more.
                            http://www.ebay.com/itm/10pcs-90-Degree-Bent-Right-Angle-Pin-Header-Breakable-40pin-Single-Strip-2-54mm-/231215719944?hash=item35d587e608:g:cHwAAOSw3ydV2ZCV
                              Nice work!
                              Is there some kind of female plug that could be used instead? It's nicely compact--except for the male pins sticking out.
                                Regardless, I just now ordered some. Thanks!
                                  OK, I "get it" now. The male pins that are sticking out are entirely optional.
                                  • alexsh1A
                                    alexsh1A
                                    alexsh1
                                    Did anyone do any power consumption tests on these? I cannot get it below 1.5mA. I think I need to mod my Pro Mini and remove the LED and the regulator.
                                    • alexsh1A alexsh1
                                      ted
                                      @alexsh1
                                      The regulator on the board (AMS1117) consumes several mA at idle. You may need to find an alternative that has uA level quiescent current. I modified the board to use a XC6206 serial LDO (1uA standby current, see my previous post). I have the board manufactured by dirtypcb and have made sensors. Will test the battery life soon.
                                      alexsh1A C 2 Replies Last reply
                                      • T ted
                                        @alexsh1
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        #44
                                        @ted thanks for your prompt reply. I do not have AMS1117 as I'm running Arduino Pro Mini 3.3V. I figured out it was the Mini itself. I had to remove the onboard regulator and the LED and right now my consumption is 6uA.
                                        I'm moving away from 5V boards as I think these will be phased out eventually.
                                        Good point on AMS1117 - this is not a battery friendly regulator
                                        • T ted
                                          Hello @ted, thank you for the link on dirtyPCB, I just ordered some boards. Do you have any feedback related to battery life when running at 5V ?
