  3. Office plant monitoring
223 Posts 39 Posters 228.1k Views 42 Watching
    @flopp said:
    Wait(xx) will continue to work in background? can anyone confirm this please
    Yes, wait() continue processing incoming messages and does not sleep the MCU.
    • Fat FlyF
      Fat FlyF
      Fat Fly
      Hi.
      What is the last version from this ?
        How did thinks go @Lars65 ?
        I thought a bit more about this problem and I think I have come up with a pretty neat solution:
        Throw away the chip on the moisture sensor and connect the "pitchfork" directly to the Arduino. Connect one prong to GND and one prong to an analog pin. No power pins are required.
        https://codebender.cc/sketch:177182
        The chip on the moisture sensor is basically a voltage divider. We get the same thing if we use the internal pull-up resistor on the Atmega processor.
        EDIT: This means you can buy just the "pitchforks" really cheap: http://www.aliexpress.com/item/10pcs-Soil-Hygrometer-Detection-Module-Soil-Moisture-Sensor-Probes/2051713873.html
        Fat FlyF
        Fat FlyF
        Fat Fly
        Oops! Looks like there was a serious issue with your project.
        If you are not sure what could be wrong please contact us.
        (file in sketch) Soil moisture for houseplants - multi-sensor internal pull-up.o: In function global constructors keyed to oldvoltage': Soil moisture for houseplants - multi-sensor internal pull-up.cpp:(.text._GLOBAL__I_oldvoltage+0xc): undefined reference to MySensor::MySensor(unsigned char, unsigned char)'
        (file in sketch) Soil moisture for houseplants - multi-sensor internal pull-up.o: In function setup': Soil moisture for houseplants - multi-sensor internal pull-up.cpp:(.text.setup+0x30): undefined reference to MySensor::begin(void (*)(MyMessage const&), unsigned char, unsigned char, unsigned char, rf24_pa_dbm_e, unsigned char, rf24_datarate_e)'
        Soil moisture for houseplants - multi-sensor internal pull-up.cpp:(.text.setup+0x50): undefined reference to MySensor::present(unsigned char, unsigned char, bool)' Soil moisture for houseplants - multi-sensor internal pull-up.cpp:(.text.setup+0x78): undefined reference to MySensor::present(unsigned char, unsigned char, bool)'
        This errors.
        F 1 Reply Last reply
        • Fat FlyF Fat Fly
          This errors.
          F
          F
          flopp
          @Fat-Fly
          I have used the latest version of this sketch and it worked perfect.
          If you use the latest version it must be something with your PC/Arduino IDE
          • Fat FlyF
            Fat FlyF
            Fat Fly
            I trying compile from this and these errors.
            • Fat FlyF Fat Fly
              #98
              @Fat-Fly as flopp said, there is something wrong with your environment.
              Are you using the development version of MySensors? If so, remove it and install 1.5 or convert the sketch to the development version by following the conversion guide.
              If you already have 1.5, remove it and re-install it closely following the instructions. You can try verifying any of the stock MySensors example sketches if you like.
              • Fat FlyF
                Fat FlyF
                Fat Fly
                wrote on last edited by Fat Fly
                #99
                Good morning. I try after work. I use linux. I want monitor this https://goo.gl/photos/oqnXUU8Pa5wmz8k87 . Moisture and if needed open valves and switch on pump.At the moment i have 3 goups what i can control.Left , right tomatoes and 3 raised beds in center, sweet peppers.
                • Fat FlyF Fat Fly
                  @Fat-Fly very nice greenhouse!
                  • Fat FlyF
                    Fat FlyF
                    Fat Fly
                    #101
                    Greenhouse
                    I want to monitor soil moisture and switch on irrigation valves and pump. Windows open arduino but why not mysensors+domoticz. I can't and not want every morning go to open greenhouse windows. let this make computer :)
                    https://www.youtube.com/watch?v=CnRbiiqhH2I
                    • Fat FlyF
                      Fat FlyF
                      Fat Fly
                      #102
                      mfalkviddM F 2 Replies Last reply
                      • Fat FlyF Fat Fly
                        [[topic:post-is-deleted]]
                        @Fat-Fly replace
                        const int SENSOR_ANALOG_PINS[] = { 0 };
                        with
                        const int SENSOR_ANALOG_PINS[] = { A0 };
                        Connect like this, except use D8 instead of A1 (the connection displayed is for a newer version of the sketch, which supports alternating polarity)
                        Fat FlyF 1 Reply Last reply
                        • L
                          L
                          LastSamurai
                          @mfalkvidd So after running my sensor for 3 days with the "fork" connected I had a pretty big loss of voltage. So (as you suggested) I ran it for ~2 days without the fork connected (just the pro mini + radio) and the loss has gone down to ~0 (it keeps alternating between 2806 and 2799mV).
                          So its obviously the fork itself that is the problem. I connected it directly to A0 and A1 and my code is above.
                          Any idea where the error might be? I will try some other cables later because thats the only idea I have...
                          @LastSamurai said:
                          @mfalkvidd That sounds great! Are you using a pro mini too?
                          I am using a 3V pro mini with power led and regulator removed and the nrf + sensor (on A0 and A1) connected and in about 1 day it dropped from 2945mV to 2907mV. Its running of of 2aa batteries and its on a breadboard for now (for testing).
                          I am using your (slightly modified) code from above. Any idea why my power usage is so much higher?
                          Here is my code:
                          Based on https://github.com/mfalkvidd/arduino-plantmoisture
                          This sketch uses the soilmoisture "forks" only that are found on ebay. They are connected between 2 analog pins where one gets pulled low and the other one measures.
                          The pins are switched every time to avoid corrosion. Between readings the sensos sleeps to preserve batterylife.
                          21.06.2016 V1.0 Base sketch
                          #define CHILD_ID_MOISTURE 0
                          #define CHILD_ID_BATTERY 1
                          #define SLEEP_TIME 1800000 // Sleep time between reads (in milliseconds) - 30 minutes
                          #define THRESHOLD 1.1 // Only make a new reading with reverse polarity if the change is larger than 10%.
                          #define STABILIZATION_TIME 1000 // Let the sensor stabilize before reading
                          #define BATTERY_FULL 3143 // 2xAA usually give 3.143V when full
                          #define BATTERY_ZERO 1900 // 2.34V limit for 328p at 8MHz. 1.9V, limit for nrf24l01 without step-up. 2.8V limit for Atmega328 with default BOD settings.
                          const int SENSOR_ANALOG_PINS[] = {A0, A1}; // Sensor is connected to these two pins. Avoid A3 if using ATSHA204. A6 and A7 cannot be used because they don't have pullups.
                          MyMessage msg(CHILD_ID_MOISTURE, V_HUM);
                          long oldvoltage = 0;
                          byte direction = 0;
                          int oldMoistureLevel = -1;
                            gw.begin();
                            gw.sendSketchInfo("Plant moisture w bat", "1.0 21062016");
                            gw.present(CHILD_ID_MOISTURE, S_HUM);
                            delay(250);
                            gw.present(CHILD_ID_BATTERY, S_CUSTOM);
                            Serial.println("Setting up pins...");
                            // init sensor pins
                            pinMode(SENSOR_ANALOG_PINS[0], OUTPUT);
                            pinMode(SENSOR_ANALOG_PINS[1], OUTPUT);
                            digitalWrite(SENSOR_ANALOG_PINS[0], LOW);
                            digitalWrite(SENSOR_ANALOG_PINS[1], LOW);
                            int moistureLevel = readMoisture();
                            // Send rolling average of 2 samples to get rid of the "ripple" produced by different resistance in the internal pull-up resistors
                            // See http://forum.mysensors.org/topic/2147/office-plant-monitoring/55 for more information
                            if (oldMoistureLevel == -1) { // First reading, save current value as old
                            if (moistureLevel > (oldMoistureLevel * THRESHOLD) || moistureLevel < (oldMoistureLevel / THRESHOLD)) {
                              // The change was large, so it was probably not caused by the difference in internal pull-ups.
                              // Measure again, this time with reversed polarity.
                            // send value and reset level
                            gw.send(msg.set((moistureLevel + oldMoistureLevel) / 2.0 / 10.23, 1));
                            long voltage = readVcc();
                            if (oldvoltage != voltage) { // Only send battery information if voltage has changed, to conserve battery.
                              gw.send(voltage_msg.set(voltage / 1000.0, 3)); // redVcc returns millivolts. Set wants volts and how many decimals (3 in our case)
                              gw.sendBatteryLevel(round((voltage - BATTERY_ZERO) * 100.0 / (BATTERY_FULL - BATTERY_ZERO)));
                              oldvoltage = voltage;
                            // sleep to conserve energy
                            gw.sleep(SLEEP_TIME);
                            Reads the current moisture level from the sensor.
                            Alternates the polarity to reduce corrosion
                          int readMoisture() {
                            pinMode(SENSOR_ANALOG_PINS[direction], INPUT_PULLUP); // Power on the sensor by activating the internal pullup
                            analogRead(SENSOR_ANALOG_PINS[direction]);// Read once to let the ADC capacitor start charging
                            gw.sleep(STABILIZATION_TIME);
                            int sensorRead = analogRead(SENSOR_ANALOG_PINS[direction]);
                            int moistureLevel = (1023 - sensorRead); // take the actual reading
                            Serial.print("Sensor read: ");
                            Serial.println(sensorRead);
                            Serial.print("Moisture level: ");
                            Serial.println(moistureLevel);
                            // Turn off the sensor to conserve battery and minimize corrosion
                            direction = (direction + 1) % 2; // Make direction alternate between 0 and 1 to reverse polarity which reduces corrosion
                            return moistureLevel;
                          long readVcc() {
                            // From http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
                            @Fat-Fly replace
                            with
                            Fat FlyF
                            Fat FlyF
                            Fat Fly
                            I correct this and try again after work. Yesterday i do not find time.
                            @mfalkvidd said:
                            @Fat-Fly replace
                            with
                            • Fat FlyF
                              Fat FlyF
                              Fat Fly
                              @mfalkvidd : Maybe change sleeping time to 60 min and STABILIZATION_TIME 1000 to 500 ms or smaller ? This place is pure lost energy. Why not to try without stablization time ?
                              • Fat FlyF Fat Fly
                                #107
                                @Fat-Fly with the current solution it looks like I will get many years of battery life. Why make the solution worse without any gain?
                                Without stabilization time you will get very unreliable results. I suggest you try and see what happens. Compare readings with and without stabilization times.
                                • Fat FlyF
                                  Fat FlyF
                                  Fat Fly
                                  I in home and try this at the moment.
                                  • Fat FlyF
                                    Fat FlyF
                                    Fat Fly
                                    I upload sketch from here and pro mini not connect to gateway. GW from this pro mini away maybe 50 cm.
                                    • Fat FlyF
                                      Fat FlyF
                                      Fat Fly
                                      end: 0-0-1-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=fail:1.5.3
                                      send: 0-0-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:1
                                      sensor started, id=0, parent=1, distance=2
                                      send: 0-0-1-0 s=255,c=3,t=11,pt=0,l=21,sg=0,st=fail:Plants moisture w bat
                                      send: 0-0-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=fail:1.2
                                      send: 0-0-1-0 s=0,c=0,t=23,pt=0,l=0,sg=0,st=fail:
                                      find parent
                                      • F
                                        F
                                        flopp
                                        wrote on last edited by flopp
                                        #111
                                        You have no connection to GW since ID=0.
                                        Looks you have a Repeater node since distance=2?
                                        • Fat FlyF
                                          Fat FlyF
                                          Fat Fly
                                          I deleted all my libaries catalog and unpack mysensors 1.4. Previous was 1.5. Too many options what i do not understand. After work i try again and to let you know from results.
