  3. [SOLVED] Gateway without radio not working on current development branch
21 Posts 8 Posters 6.9k Views 6 Watching
  • jsiddallJ Offline
    jsiddallJ Offline
    jsiddall
    I have seen a number of posts from people who have their gateways working without radios. I need this for a remote Ethernet gateway which has local sensors but does not need to talk to any radio nodes.
    From what I have read running without a radio is as simple as commenting all the defines for the radios. Ex:
    //#define MY_RADIO_NRF24
    However, when I do this and compile I get these errors:
    sketch/GatewayW5100.ino.cpp.o: In function sendHeartbeat()': /Software/Arduino/MySensors/libraries/MySensors/core/MySensorsCore.cpp:276: undefined reference to transportGetHeartbeat()'
    collect2: error: ld returned 1 exit status
    exit status 1
    Error compiling for board Arduino/Genuino Uno.
    If I leave the radio defined but not connected it compiles fine but I get runtime errors due to the missing radio and the gateway seems to be continually restarting:
    0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0-beta)
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;!TSM:RADIO:FAIL
    0;255;3;0;9;!TSM:FAILURE
    0;255;3;0;9;TSM:PDT
    0;255;3;0;9;TSM:PDT
    Any ideas how I can get a gateway without radio working?
    • hekH Offline
      hekH Offline
      Probably some regression. We should probably introduce some new test-sketch with radio disabled to test this during CI.
      jsiddallJ 1 Reply Last reply
        jsiddallJ Offline
        jsiddallJ Offline
        jsiddall
        Thanks for the insight @hek. So not really knowing anything about GIT is there an easy way I can grab a snapshot of the development branch from some point in the past where this was working? Any ideas how recently that might have been?
        Also, should I report this as a bug somewhere?
        Any pointers would be appreciated.
        • hekH Offline
          hekH Offline
          It'll be patched soon.
          • jsiddallJ Offline
            jsiddallJ Offline
            jsiddall
            Great, thanks!
            • jsiddallJ jsiddall
              Great, thanks!
              T Offline
              T Offline
              tekka
              @jsiddall has been addressed in PR#502.
              • T tekka
                jsiddallJ Offline
                jsiddallJ Offline
                jsiddall
                @tekka: TYVM. Tested the fix and it works great, no errors.
                • S Offline
                  skatun
                  Fyi, I had same problem with serial gateway. I guess that is fixed now aswell as the ethernet gateway?
                  • S skatun
                    jsiddallJ Offline
                    jsiddallJ Offline
                    jsiddall
                    Yes, I have tested both serial and ethernet gateways and both work now.
                    • S Offline
                      skatun
                      Is there a smarter way to upgrade the development version on windows instead of download zip file-> extract it-> replace files? Also how can I find out if its outdated or not? I am going to download the new version now to see if the patch works and hence I were wondering the best way to do so:)
                      RFM69R mfalkviddM 2 Replies Last reply
                      • S skatun
                        RFM69R Offline
                        RFM69R Offline
                        RFM69
                        @skatun Can you use git, not an expert... but I think thats the way to go... :)
                        • S skatun
                          Yes. Delete the old version first. Then extract (no need to replace since the old files have been deleted)
                          Otherwise you'll most likely get compile errors.
                          S 1 Reply Last reply
                            skatun
                            @mfalkvidd
                            On windows 7 it ask me to replace files with new one, when I click yes, everything works fine. The main issue is to detect when new files are available and then do the update. These days I keep downloading the development branch around once a month to make sure I am not working on to old versions.
                            • S skatun
                              @mfalkvidd
                              @skatun yes, that method will work if you are lucky. But if a file has been renamed or something similar you will get warnings and/or errors. Better to delete the old library first.
                              • chrlyraC Offline
                                chrlyraC Offline
                                chrlyra
                                I have the same situation here, I mean, serial gateway with local sensors and no radio. But I'd like to use the 1.5 version as I'm not sure with the new one is compatible with homeassistant. Is this fix only to 2.0 branch?
                                S martinhjelmareM jsiddallJ 3 Replies Last reply
                                • chrlyraC chrlyra
                                  skatun
                                  @chrlyra
                                  If I am not completely wrong, this fix is only to 2.0
                                  • chrlyraC chrlyra
                                    martinhjelmareM Offline
                                    martinhjelmare
                                    @chrlyra
                                    Version 2.0 of the mysensors library should be compatible with home assistant, but the new sensor s_types and v_types are not yet supported. I'm working on this.
                                    • chrlyraC chrlyra
                                      jsiddallJ Offline
                                      jsiddallJ Offline
                                      jsiddall
                                      @chrlyra: I don't think local sensors are in the main branch so you need development for that
                                        martinhjelmare
                                        @jsiddall
                                        Version 2.0, which was just released, supports local sensors on gateway, ie you should not need dev branch anymore for that feature.
                                          @jsiddall
                                          jsiddallJ Offline
                                          jsiddallJ Offline
                                          jsiddall
                                          @martinhjelmare: right you are. I didn't realize 2.0 was out. I guess my post would have made more sense 4 days ago!
