  3. 💬 Wall Socket Insertable Node
rfm69atsha204amysensorsrelaypower supply
77 Posts 21 Posters 34.3k Views 27 Watching
  • Sander TeunissenS Sander Teunissen
    I just bumped into these too:
    https://www.openhardware.io/view/102/Wall-Switch-Insertable-Node#tabs-instructions
    So interesting ! will these be sold too ?
    KoreshK
    KoreshK
    Koresh
    @Sander-Teunissen
    I will make a small presentation of new boards tomorrow in Breda. Of course I will try to start mass production asap :) You can check estimated prices of all boards in button size radionode thread.
    • tonnerre33T
      tonnerre33T
      tonnerre33
      Hi, it's a very intersting project but what about the protections of the switching power supply ?
      I see a varistor but neither fuse nor Thermal Cutoffs.
      KoreshK 1 Reply Last reply
      • tonnerre33T tonnerre33
        KoreshK
        KoreshK
        Koresh
        @tonnerre33 do not worry. It will be in final version + we can use temperature sensor in rfm modult to switch of the relay.
        • sinczeS
          sinczeS
          sincze
          MySensors Evangelist
          Very nice to see this device today live in Breda ;-)
          • fisherF
            fisherF
            fisher
            Very nice project. Looking forward to buy it. It would be nice to have possibility to trigger switch via local button (as in Fibaro) and not only via radio. It's possible from software point of view but board should be modified slightly. Is it in your todo list @Koresh?
            • Y
              Y
              yury
              wrote on last edited by yury
              #25
              @fisher are you referring to touch sensor button or momentary push button?
              • fisherF
                fisherF
                fisher
                @yury yes
                • fisherF fisher
                  KoreshK
                  KoreshK
                  Koresh
                  wrote on last edited by Koresh
                  #27
                  Thanks! We thought about this feature, thanks for your reminder. I've successully added pins for button. You can see new JST connector for button on the screenshot below. I hope this solution is reliable enough
                  I almost forgot... Now this board contains SPI flash which implements OTA upgrade ability :wink:
                  fisherF 2 Replies Last reply
                  • KoreshK Koresh
                    fisherF
                    fisherF
                    fisher
                    @Koresh Perfect! Do you know when the modules will be ready for sale? How they will be sold? Direct sale, ebay, ...?
                    Do you have further development plans, ex. dimmers, wall node with two relays, blind controllers?
                    • KoreshK Koresh
                      fisherF
                      fisherF
                      fisher
                      @Koresh Another thing I forgot. Are you considering to design and sale any plastic case to your modules? Putting raw electronics to tight wall socket is not the safest solution :)
                      KoreshK Y 2 Replies Last reply
                      • fisherF fisher
                        KoreshK
                        KoreshK
                        Koresh
                        We plan to supply small plastic case because without this case it is impossible to get CE mark (it must be on the case). After buying you can extract the board and put it under socket if you want. But I do not agree with your thesis about safety. We tried to explain it in our presentation in Breda. The safest case - no case :wink: Do not forget this module will have all of fuses (thermal cutt off, overvoltage varistor, slow fuse) and of course we will do all possible steps to isolate danger points.
                        fisherF 1 Reply Last reply
                        • KoreshK Koresh
                          fisherF
                          fisherF
                          fisher
                          @Koresh Is there any video from Breda meeting?
                          • fisherF fisher
                            Y
                            Y
                            yury
                            We think to use as "standalone case" this one:
                            https://www.alibaba.com/product-detail/72-25-mm-LED-drive-power_60426277938.html?spm=a2700.7724838.0.0.QARRdD
                            As for safety in "tight wall socket", the point here is:
                            1. All those wall socket boxes is really safe Ip 20 or 44 certified together with socket itself.
                            2. If something happens inside this crimped space will stay there.
                            This node will have thermal fuse, Over-voltage varistor, and if you short cut the relay - ACS 712 has build in "fuse".
                            So I think inside a wall is still much safer. How to put it safely there - it is another topic. At least you have to have experience in fixing things at home and for sure cut off power!
                            I tried to burn this thing many times as we tested it. so far most impressive was relay short cut test. Re-soldering new ACS712 fixed thing back. Relay survived also.
                            Traces of the test on the case. Not even melting traces, just smoked out:
                            • PierreStP
                              PierreStP
                              PierreSt
                              Would it be possible for the diameter of the box to be smaller? In Germany the standard wall sockets are 68mm. So 60-65 mm fot the box would be ideal.
                              Y 1 Reply Last reply
                              • PierreStP PierreSt
                                Y
                                Y
                                yury
                                #34
                                @PierreSt
                                www.aliexpress.com/item/55-22mm-5pcs-LED-ceiling-circular-drive-casing-fire-retardant-PC-power-supply-housing-with-cooling/32643161481.html?spm=2114.13010608.0.72.VRC6ws
                                is the smallest. will get them soon. not sure if the thing will fit inside though.
                                So far we a bit stuck with our PCBA contractor. Negotiating hard for better prices.
                                • Sander TeunissenS
                                  Sander TeunissenS
                                  Sander Teunissen
                                  Any update on your progress ? I am really watching out for this one !
                                    KoreshK
                                    KoreshK
                                    Koresh
                                    @Sander-Teunissen Thanks for your attention to this project. There are Chinese national holidays until 8 october. So there are no updates now.
                                    • J
                                      J
                                      jkandasa
                                      @Koresh This project looks super cool and very small. Thanks to the open hardware. Can you post SMPS transformer design specifications?
                                      • J
                                        J
                                        jacikaas
                                        Hello, great project! I'm very intrested in it and waiting for testing results :)
                                        One quick question: in this and also in other your profects with RFM69 you are don't using antenna for it. Is it not necessary, becose in introduction about radios (https://www.mysensors.org/build/connect_radio) there is note:
                                        IMPORTANT: You MUST attach an antenna to the board. Aside from not working without an antenna, transmitters can be damaged if they transmit without an antenna present.
                                        So does antenna for RFM69 is necessary?
                                        • J jacikaas
                                          KoreshK
                                          KoreshK
                                          Koresh
                                          @jacikaas Thanks for your attention. Of course antenna is necessary, I use 17cm wire as antenna for all projects (so flexible antenna :))
                                          Unfortunately I was extremely busy last months. I became a father :baby: and I had a rush job with my work projects :worried: . But I hope I will have a little more time. Now I am waiting for the boards for the first relatively large batch of all my projects. I am waiting for the large pack of components too :satisfied: Also I found a reliable pcba partner (I hope). So I really hope to introduce my boards (preassembled) for purchase soon.
                                          Latest version of this board, for example looks as these screenshots:
                                          I also have very interesting new modifications of this and other boards (it is secret for now :stuck_out_tongue_winking_eye: , but I will show it soon ).
