  3. Juggling different MySensor versions?
18 Posts 8 Posters 7.6k Views 8 Watching
  • TD22057T
    TD22057T
    TD22057
    I think what @hek is suggesting is something like this: clone the repository and branches (dev, main, etc) to your local machine. Point the IDE at that location. Then when you want to do a build with a different version, use git to switch the repository to the other branch. And better yet, tag the software you use for a specific sensor deployment when you build it, then when you need to go back to it, checkout the tag.
    If that doesn't sound good, you may want to look at other IDE/build choices. Any of the Arduino make/cmake systems will let you explicitly point a compile step at different directories to pick up specific versions of the software. So you can have all the branches checked out and sitting there on a disk and just point at different ones as part of the build process. You should still use tags to track exactly what you deployed, but it lets you keep all the versions of the library you're using visible and it may be less confusing than trying to remember to switch the code using git. It's just more expensive (in time) to set up the initial build system to use this vs the Arduino IDE.
    DidiD 1 Reply Last reply
    • TD22057T TD22057
      DidiD
      DidiD
      Didi
      @TD22057
      I understand that,what was confusing me was the Eclipse/Arduino IDE thing
      • mfalkviddM
        Thanks for the feedback. I'll go for the git solution.
        • fetsF
          fetsF
          fets
          Can somebody gives a way to make a diff between my local version and the online repository.
          When I use git diff (or git status), it only gives differences between local files and local repository (stuck at the version/date when I cloned it).
          My purpose is to compare my version vs online development branch.
          • fetsF fets
            @fets git fetch --all will update your local repository with the changes on github.
            You can then use
            git diff origin/master localbranch
            or similar to compare.
            fetsF 1 Reply Last reply
              You can then use
              fetsF
              fetsF
              fets
              @mfalkvidd thanks. But is fetch only update local repository and not local files ? I wasn't sure
              • fetsF fets
                @fets not sure what you mean. The files are stored in the reprository (unless you have local changes that have not been committed).
                  fetsF
                  fetsF
                  fets
                  @mfalkvidd I use development version which is still evolving on github. BEFORE upgrading my local files, I would like to know the differences between my local version and the remote repo.
                  • fetsF fets
                    @fets this should be sufficient:
                    git fetch --all # downloads all updates from github to the local git repository but does not update the current branch
                    git diff origin/development # shows difference between current branch/ref and development on github
                    fetsF TheoLT 2 Replies Last reply
                      fetsF
                      fetsF
                      fets
                      @mfalkvidd thanks.
                      I'll try next time i'll get repo files
                        TheoLT
                        TheoLT
                        TheoL
                        @mfalkvidd I'm really spoiled by my employee. I use different images for different versions. 1.5 though is the one I currently use on OsX - thus no virtual image.
                        • alexsh1A
                          alexsh1A
                          alexsh1
                          I'm using Windows
                          I have two Arduino installations.
                          One folder called 'Arduino-old' - with MySensors 1.5.4
                          Another folder called Arduino - with MySensors 2.0
                          If I need to work on an older version, I rename 'Arduino' to 'Arduino-new' and 'Arduino-old' to 'Arduino'
                          I have the same version of Arduino installed in both folders 1.6.9
                          Works fine for me
                          B 1 Reply Last reply
                          • alexsh1A alexsh1
                            I'm using Windows
                            Works fine for me
                            B
                            B
                            boozz
                            Hi all,
                            I'm struggling somewhat with the different MySensor versions as well on Windows machines (windows XP, windows 7 and windows 10).
                            I'm using sync (sync.com) to keep all versions of sketches (and libraries) on 3 computers in synchronised. Works perfect for me.
                            I write my sketches using the notebook -while sitting in the livingroom with my family- and do the real debugging and testing and deploying at 2 different locations (in the attick and in my shed). In the preferences.txt (Arduino IDE... C:\Users\xxxxxx\AppData\Local\Arduino15\preferences.txt) I've declared the sketschbook location as being the 'sync' location. This is on all 3 computers the same.
                            Here the trouble begins for 2 different MySensor versions: the libraries are in this 'sync' location as well. Even if multiple Arduino IDE's are installed, the preferences.txt remains the same one, always pointing at the same sync location....and thus the same libraries....
                            My goal is to have 2 different configurations to switch between MySensors 1.5 and 2.0 while keeping the 'sync' option I created before. Has anyone an idea how to accomplish that? Would git be and option (I have zero experience with this) and how should this be implemented in Windows? Or would the method described by @alexsh1 a simple but robust solution. Any help appreciated!
                            Boozz
                            • mfalkviddM
                              I haven't tried yet, but I've been thinking about having two installations of the Arduino IDE. One for each MySensors version.
                              12.5k
