  3. DHT + Relay Sketch
DHT + Relay Sketch
10 Posts 3 Posters 5.1k Views 3 Watching
  • mehrdad.silataniM
    mehrdad.silataniM
    mehrdad.silatani
    wrote on last edited by mehrdad.silatani
    I am trying to combine a DHT sensor with a Relay module in one sketch. I already looked up the example of how to combine two IDEs together and used some of its information. However, once I combine the sketches and upload it to Arduino, I can see an error in my SerialPort:
    0_1473504434530_upload-7938b4b4-a234-4087-beda-e8ac305c9e37
    Also when I am running the sketch and let it to communicate with GW, my HA (controller) doesnt recognise any entity for my relay !
    Any help would be much appreciated!
    This is the current sketch:
    // Enable debug prints
    //#define MY_RS485
    #define DHT_DATA_PIN 3
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 60000;
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_RLAY 2
    #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
    void before() {
        pinMode(pin, OUTPUT);
      sendSketchInfo("TempHumidRelay", "1.1");
      present(CHILD_ID_RLAY, S_LIGHT);
      present(CHILD_ID_HUM, S_HUM);
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
        nNoUpdatesHum++;
      sleep(UPDATE_INTERVAL);
    TheoLT 1 Reply Last reply
    • mehrdad.silataniM mehrdad.silatani
      //#define MY_RS485
      float lastTemp;
      float lastHum;
      bool metric = true;
      DHT dht;
      void before() {
          if (!metric) {
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
          nNoUpdatesHum++;
      TheoLT
      TheoLT
      TheoL
      @mehrdad.silatani The serial monitor is telling you, that it's not able to connect to your gateway (FPAR). This most likely a power issue and some ways to solve it are:
      • add a 47uf or 100uf capacitor to the radio (see build page)
      • try powering the components from an external adapter.
      Hope you can get it to work!
      • mehrdad.silataniM
        mehrdad.silataniM
        mehrdad.silatani
        @TheoL THank you for your reply, I already have 47uF capacitor connected to the radio module, and its already running on an external power supply.
        All being said, I suspect, I am missing something in the sketch.
        Cheers,
        Mehrdad
        • mehrdad.silataniM
          mehrdad.silataniM
          mehrdad.silatani
          Ok, I made one step forward. Now the two sketches are combined and I managed to get the HA to recognise the attributes. However, in HA, the temperature sensor keeps appear as a switch !
          0_1473548173348_upload-842b69f8-da2b-4434-80db-7c75b9309d03
          This is my sketch:
          #define MY_REPEATER_FEATURE
          #define MY_NODE_ID 1
          #define RELAY_PIN  4
          #define RELAY_ON 1
          #define RELAY_OFF 0
          Bounce debouncer = Bounce();
          bool state = false;
          bool initialValueSent = false;
          float lastTemp;
          float lastHum;
          bool metric = true;
          MyMessage msgRlay(CHILD_ID_RLAY, V_STATUS);
          DHT dht;
            present(CHILD_ID_RLAY, S_BINARY);
            //sleep(dht.getMinimumSamplingPeriod());
            pinMode(RELAY_PIN, OUTPUT);
              if (!initialValueSent) {
              Serial.println("Sending initial value");
              send(msgRlay.set(state?RELAY_ON:RELAY_OFF),2);
              Serial.println("Requesting initial value from controller");
              request(CHILD_ID_RLAY, V_STATUS);
              wait(2000, C_SET, V_STATUS);
            if (debouncer.update()) {
              if (debouncer.read()==LOW) {
                state = !state;
                // Send new state and request ack back
                send(msgRlay.set(state?RELAY_ON:RELAY_OFF), true);
              if (!metric) {
              nNoUpdatesTemp = 0;
              #ifdef MY_DEBUG
              nNoUpdatesTemp++;
              lastHum = humidity;
              nNoUpdatesHum = 0;
              #ifdef MY_DEBUG
              nNoUpdatesHum++;
           wait(2000);
            if (message.isAck()) {
                Serial.println("Receiving initial value from controller");
                initialValueSent = true;
              state = (bool)message.getInt();
              send(msgRlay.set(state?RELAY_ON:RELAY_OFF,2));
          I would really sincerely appreciate if someone can shed some light on what I am doing wrong !
          Plus, I read mysensors website millions time but still I can't find clear description of some of the functions that are being used in V2 of the library, any idea where I can look up functions used in mysensors examples ?
            This is my sketch:
            #define RELAY_PIN  4
            #define RELAY_ON 1
            #define RELAY_OFF 0
            bool state = false;
            float lastTemp;
            float lastHum;
            bool metric = true;
            DHT dht;
                  state = !state;
                if (!metric) {
                nNoUpdatesTemp = 0;
                #ifdef MY_DEBUG
                nNoUpdatesTemp++;
                lastHum = humidity;
                nNoUpdatesHum = 0;
                #ifdef MY_DEBUG
                nNoUpdatesHum++;
             wait(2000);
            @mehrdad.silatani the sketch looks good to me, but I don't use HA so I don't know what could go wrong there.
            The functions should be documented at https://www.mysensors.org/download/sensor_api_20
            Let us know if any function is missing, or if some aspect is poorly presented.
            • mehrdad.silataniM
              mehrdad.silataniM
              mehrdad.silatani
              @mfalkvidd Thank you so much for your comment. I already checked the link you send me and it is very insightful but I guess I am still too beginner to find my solution from those explanations.
              Since you asked about missing functions, I couldn't find any description on " C_SET".
              Also if you don't mind I would like to ask for your help to understand some of the functions used in my code. These are the functions I am not fully understanding;
              • "send(msgHum.set(humidity, 1))"
                What is the action of that number "1" after the payload (i.e. humidity)? can it be any number ?
              • "send(msgRlay.set(state?RELAY_ON:RELAY_OFF),2)"
                I fully understand up to the part of "send(msgRlay.set" but what happens in "state?RELAY_ON:RELAY_OFF" and also again what is that number "2" at the end doing ?( I randomly typed 2) .... I suspect, in "state?RELAY_ON:RELAY_OFF" it asks the Arduino that which state is true and use that, is that correct?
              • "send(msgRlay.set(state?RELAY_ON:RELAY_OFF), true)"
                What is the "true" at the end of the line doing?
              • "wait(2000, C_SET, V_STATUS)"
                This is where I came across the "C_SET"
              • "state = (bool)message.getInt()"
                I can guess that this line is trying to extract the information of the relay state from the received msg, but I really don't know what is the breakdown of the logic in it (e.g. does adding (bool) at the front of the message.getInt() means only accept boolean type data ? .... )
              • "debouncer.update()"
                I really dont quite get what happens in this line ...
              Sorry for asking too many questions :) .. I am really loving to work with "mysensors" and I am trying to make sure I understand what happens in my codes :)
                Great questions! I'll answer them here now and see if I can get the documentation page updated later.
                That number is the number of decimals to include in the message. So if the humidity is 57.5484, using 1 will send 57.5. Using 2 will send 57.55 (correctly rounded).
                This is called a conditional operator. If state is true, the first value (RELAY_ON) will be used. If state is false, the second value (RELAY_OFF) will be used. This is shorthand for
                if(state)
                    return RELAY_ON;
                    return RELAY_OFF;
                More information: http://www.tutorialspoint.com/cplusplus/cpp_conditional_operator.htm
                The number 2 is, just like before, the number of decimals. For a relay you can omit the number, just use
                send(msgRlay.set(state?RELAY_ON:RELAY_OFF))
                From https://www.mysensors.org/download/sensor_api_20#sending-data :
                ack - Set this to true if you want destination node to send ack back to this node. Default is not to request any ack.
                The ack stuff has confused me immensely. MySensors has two types of ack. They are both called ack but they work very differently. https://forum.mysensors.org/topic/3346/discussion-reliable-delivery/ documents my road from confusion to clarity.
                https://www.mysensors.org/download/sensor_api_20#waiting describes the second parameter as
                cmd - The command type to wait for
                The commands are defined at https://github.com/mysensors/MySensors/blob/e1ccba22d8fe5b6604bc6428ca950e4336654784/core/MyMessage.h#L45 So waiting for C_SET means that you want for an incoming command (message) that wants to set a variable. In this case, set the value of the relay.
                Not quite. It converts to integer to a bool. So if the integer is 0, the result will be false. If the integer is not zero, the result will be true. More details: http://stackoverflow.com/questions/31551888/casting-int-to-bool-in-c-c
                This updates the value from a switch, avoiding contact bounces. More information: https://github.com/thomasfredericks/Bounce2/wiki
                No worries, we're all here to learn :)
                • mehrdad.silataniM
                  mehrdad.silataniM
                  mehrdad.silatani
                  @mfalkvidd WOW ! I am blown away by your detailed answers !!! Nothing is more satisfying than plain answers to puzzling questions :smile: Thank you so so much !!!
                  Meanwhile, by using my "MYSController". I figured out that the sketch is reporting right values as you pointed out before;
                  0_1473586525559_upload-00eadcf7-e899-40cc-b362-dec912d2442b
                  So what I did was to check my "mysensors.json" ... I noticed there are traces of my old sensor node still embedded in the "mysensors.json". So I deleted the file and let the HA to create a new one from scratch ! and then Volla ! HA started to recognise the sensors and switch separately !
                  0_1473586257481_upload-f6491b85-7e83-44a3-9259-c554518b47eb
                  I know everyone here are helping and volunteers, but I thought I will just share my suggestion with you wonderful people, I think it would be invaluable to mysensors users to be able to refer to a language reference page similar to the arduino's website; "https://www.arduino.cc/en/Reference/HomePage"
                  Again, THANK YOU so much for your elaborated answers !
                  Cheers,
                  Mehrdad
                    Cheers,
                    Mehrdad
                    @mehrdad.silatani great that you found and solved the problem. Thanks for sharing! And thanks for your kind words.
                    Great suggestion on the Arduino reference. It will be included in the next update of https://www.mysensors.org/about/arduino
                    • mehrdad.silataniM
                      mehrdad.silataniM
                      mehrdad.silatani
                      One last question !!! :smile:
                      Now that I opened up my "mysensors.json", it made me curious about some of the information in it. Currently it shows;
                      {"0": {"sketch_name": null, "sensor_id": 0, "children": {}, "battery_level": 0, "sketch_version": null, "protocol_version": "2.0.0", "type": 18}, "1": {"sketch_name": "TempHumidRelay", "sensor_id": 1, "children": {"0": {"id": 0, "description": "", "values": {"1": "51.0"}, "type": 7}, "1": {"id": 1, "description": "", "values": {"0": "21.0"}, "type": 6}, "2": {"id": 2, "description": "", "values": {"2": "0"}, "type": 3}}, "battery_level": 0, "sketch_version": "1.1", "protocol_version": "2.0.0", "type": 18}}
                      Inside the "values" brackets, I know the second numbers are the reported values (i.e. payload), but what is the first number in the bracket ? {"0": "21.0"} , {"1": "51.0"} or {"2": "0"}
                      And finally what are the definition of "type": 18 , "type": 3 , "type": 7 and "type":6 ?
                      Cheers,
                      Mehrdad
