  3. Force re-routing
Force re-routing
4 Posts 3 Posters 1.1k Views 3 Watching
  • xaleriusX Offline
    xaleriusX Offline
    xalerius
    Hi, I have built a sensor to keep track of the power meter of my house. I have sporadic loss of communication which I think is due to poor reception (the power meter is located outside). On the desk the sensor works for days.
    I have tried adding a repeater node without success so far, but this could be due to the sensor initially getting contact directly with the GW (I need to disassemble the sensor to access the reset button) and later losing contact for some reason.
    When I look at the source code I get the impression that 10 seconds needs to pass before the mysensors library attempts to find another route to the GW, and do I understand things correctly if I say that could take quite a while on a node that sleeps most of the time?
    If so, is there a way to poke the library and find out the connection status and also initiate a re-routing?
    • F Offline
      F Offline
      flopp
      wrote on last edited by flopp
      In version 1.5.1 the node need 6 failures in a row to start looking for new way to GW.
      You can hold your hands around the node to make the signal weak.
      Maybe power off GW and wait 6 sends to make the node to look for new way then when you see LED flashing in repeater you can power on the GW again.
      • Mark SwiftM Offline
        Mark SwiftM Offline
        Mark Swift
        Force the right parent...
        • xaleriusX Offline
          xaleriusX Offline
          xalerius
          Thank you both for your advice. I ended setting a fixed ID for the repeater node and forcing that as parent ID in the sensor. So far it has been working for 6 hours without any hiccup so things looks promising! :thumbsup:
