  3. 3-in-1 Humidity Temp and Motion
motion3 in 1temphumidity
47 Posts 28 Posters 49.1k Views 22 Watching
  • K
    K
    Konrad Walsh
    wrote on last edited by Konrad Walsh
    I am wanted to share my 3-in-1 sensor in case its of use to anyone
    Its really just a combination of what's already available
    I used the following hardware:
    Arduino Nano LINK - Gave me both 3.3v and 5v output without having to mess with extra hardware(steppers)
    1 x Motion Sensor LINK
    1 x DHT22 LINK
    Connections is as all other guides except:
    Motion Sensor digital to Pin D3
    and the DHT to Pin D4
    Here is my code
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_MOT 2   // Id of the sensor child
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
      gw.begin();
      gw.sendSketchInfo("Humidity/Motion", "1.0");
      gw.present(CHILD_ID_MOT, S_MOTION);
      // Read digital motion value
      Serial.println(tripped);
      gw.send(msgMot.set(tripped?"1":"0"));  // Send tripped value to gw
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
      gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
    If anyone wants more info please ask.. I will put up pictures or diagrams if needed
    RJ_MakeR M A 3 Replies Last reply
    • K Konrad Walsh
      1 x DHT22 LINK
      Here is my code
      DHT dht;
      float lastTemp;
      float lastHum;
        gw.begin();
          if (!metric) {
            lastHum = humidity;
      RJ_MakeR
      RJ_MakeR
      RJ_Make
      @Konrad-Walsh
      Battery powered?
      RJ_Make
      • K
        K
        Konrad Walsh
        no. usb charger powered. No idea where to start with battery powering this stuff
        • C
          C
          chilump
          Very cool. Could you list the hardware you used for this project?
          K 1 Reply Last reply
          • C chilump
            K
            K
            Konrad Walsh
            @chilump
            Yes of course... I'll update the original post shortly..
            EDIT: UPDATED
            • AtomicGrogA
              AtomicGrogA
              AtomicGrog
              Interested in how you will package this? will the recorded temp be affected by the duino if it's enclosed?
              • K
                K
                Konrad Walsh
                No its not affected as the temp sensor is on the outside of the case along with the motion sensor
                • bobnataleB
                  bobnataleB
                  bobnatale
                  Do you have a picture of it in the case? Pictures rule =)
                  • NuubiN
                    NuubiN
                    Nuubi
                    I found out quite marked difference between different setups! On the surface of the enclosure there's >3C warmer than few centimeters further from the enclosure, see pictures :-)
                    First picture: temp, light level, door sensor, movement, patio PWM led lightning. DS sensor on the bottom of the enclosure
                    Second: temp, light, movement
                    RJ_MakeR 1 Reply Last reply
                    • NuubiN Nuubi
                      RJ_MakeR
                      RJ_MakeR
                      RJ_Make
                      @Nuubi Where did you get those cases?
                      RJ_Make
                      • NuubiN
                        NuubiN
                        Nuubi
                        Upper picture: a repurposed old movement alarm unit, was on sale for 2€ several years ago on a local store.
                        Lower one: from dx.com (http://www.dx.com/p/wall-mount-pir-motion-detector-with-80db-alarm-siren-7-10-meter-110-degrees-15278), just swapped the internals. A bit small for my spider net constructions, though.
                        • O
                          O
                          Opus40
                          I am trying out your 3-in-1 Humidity Temp and Motion sensor with a DHT11 and get the following in the serial out put
                          sensor started, id 5
                          send: 5-5-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
                          send: 5-5-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                          read: 0-0-5 s=255,c=3,t=6,pt=0,l=1:M
                          send: 5-5-0-0 s=255,c=3,t=11,pt=0,l=15,st=ok:Humidity/Motion
                          send: 5-5-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                          send: 5-5-0-0 s=0,c=0,t=7,pt=0,l=5,st=ok:1.4.1
                          send: 5-5-0-0 s=1,c=0,t=6,pt=0,l=5,st=ok:1.4.1
                          send: 5-5-0-0 s=2,c=0,t=1,pt=0,l=5,st=ok:1.4.1
                          send: 5-5-0-0 s=2,c=1,t=16,pt=0,l=1,st=ok:1
                          so the motion is working but not the temp or humidity, do I have to do some thing different in the scetch for the DHT11 over the DHT22?
                          Thanks for any help.
                          • K
                            K
                            Konrad Walsh
                            Hey
                            From what I just read it shouldnt matter.. you I would double check you wiring of the DHT11. Your output should be on PIN 4.. Also, have you placed the resistor on the DHT1`1
                            • O
                              O
                              Opus40
                              hi,
                              thanks I did some reading my self and realised I needed the resistor works a treat now. thanks for the reply.
                              • O Opus40
                                hi,
                                K
                                K
                                Konrad Walsh
                                @Opus40 Great!
                                I am currently finalising a 5 in 1 sensor... just testing and so far its working fantastic
                                NuubiN 1 Reply Last reply
                                • K Konrad Walsh
                                  @Opus40 Great!
                                  NuubiN
                                  NuubiN
                                  Nuubi
                                  wrote on last edited by Nuubi
                                  Hum-temp-motion-light-???
                                  • NuubiN Nuubi
                                    K
                                    K
                                    Konrad Walsh
                                    @Nuubi LOL.. its a secret!!!
                                    and I will share my carefully guarded secret... Air quality sensor!! or in other words.. smoke and gas detector...
                                    • N
                                      N
                                      NotYetRated
                                      Did you mount your PIR behind the rounded screen area on those cases? It works through that?
                                      I have yet to get to integrating PIR's in to my sensors, but do plan to, and was curious how to effectively mount them. Need to offer protection from the circuitry, but visibility to the sensor itself.
                                      • C4VetteC
                                        C4VetteC
                                        C4Vette
                                        wrote on last edited by C4Vette
                                        Question about a minor detail:
                                        Wouldn't a motionsenser trip be missed during:
                                        delay(dht.getMinimumSamplingPeriod()); ?
                                        For a DHT22 this is 2 seconds... or does the interrupt still has precedence?
                                        • C4VetteC C4Vette
                                          BulldogLowellB
                                          BulldogLowellB
                                          BulldogLowell
                                          @C4Vette you could just use a non-blocking method to read the temperature instead of the delay.
                                          The delay is method is in the library and used so that multiple reads to the sensor don't affect the reading (overheating the sensor).
                                          since SLEEP_TIME is 30s in the code above... I'd just read the temperature each time the sensor was awakened.
                                          you could just timestamp the last reading and check that at least the 2 seconds elapsed since the last reading before you take a new one (in the case that motion was detected.
                                          C4VetteC 1 Reply Last reply
