  3. 3-in-1 Humidity Temp and Motion
motion3 in 1temphumidity
47 Posts 28 Posters 49.1k Views 22 Watching
  • K
    K
    Konrad Walsh
    no. usb charger powered. No idea where to start with battery powering this stuff
    • C
      C
      chilump
      Very cool. Could you list the hardware you used for this project?
      K 1 Reply Last reply
      • C chilump
        K
        K
        Konrad Walsh
        wrote on last edited by Konrad Walsh
        @chilump
        Yes of course... I'll update the original post shortly..
        EDIT: UPDATED
        • AtomicGrogA
          AtomicGrogA
          AtomicGrog
          Interested in how you will package this? will the recorded temp be affected by the duino if it's enclosed?
          • K
            K
            Konrad Walsh
            No its not affected as the temp sensor is on the outside of the case along with the motion sensor
            • bobnataleB
              bobnataleB
              bobnatale
              Do you have a picture of it in the case? Pictures rule =)
              • NuubiN
                NuubiN
                Nuubi
                I found out quite marked difference between different setups! On the surface of the enclosure there's >3C warmer than few centimeters further from the enclosure, see pictures :-)
                First picture: temp, light level, door sensor, movement, patio PWM led lightning. DS sensor on the bottom of the enclosure
                Second: temp, light, movement
                RJ_MakeR 1 Reply Last reply
                • NuubiN Nuubi
                  RJ_MakeR
                  RJ_MakeR
                  RJ_Make
                  @Nuubi Where did you get those cases?
                  RJ_Make
                  • NuubiN
                    NuubiN
                    Nuubi
                    Upper picture: a repurposed old movement alarm unit, was on sale for 2€ several years ago on a local store.
                    Lower one: from dx.com (http://www.dx.com/p/wall-mount-pir-motion-detector-with-80db-alarm-siren-7-10-meter-110-degrees-15278), just swapped the internals. A bit small for my spider net constructions, though.
                    • O
                      O
                      Opus40
                      I am trying out your 3-in-1 Humidity Temp and Motion sensor with a DHT11 and get the following in the serial out put
                      sensor started, id 5
                      send: 5-5-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
                      send: 5-5-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                      read: 0-0-5 s=255,c=3,t=6,pt=0,l=1:M
                      send: 5-5-0-0 s=255,c=3,t=11,pt=0,l=15,st=ok:Humidity/Motion
                      send: 5-5-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                      send: 5-5-0-0 s=0,c=0,t=7,pt=0,l=5,st=ok:1.4.1
                      send: 5-5-0-0 s=1,c=0,t=6,pt=0,l=5,st=ok:1.4.1
                      send: 5-5-0-0 s=2,c=0,t=1,pt=0,l=5,st=ok:1.4.1
                      send: 5-5-0-0 s=2,c=1,t=16,pt=0,l=1,st=ok:1
                      Failed reading temperature from DHT
                      Failed reading humidity from DHT
                      so the motion is working but not the temp or humidity, do I have to do some thing different in the scetch for the DHT11 over the DHT22?
                      Thanks for any help.
                      • K
                        K
                        Konrad Walsh
                        Hey
                        From what I just read it shouldnt matter.. you I would double check you wiring of the DHT11. Your output should be on PIN 4.. Also, have you placed the resistor on the DHT1`1
                        • O
                          O
                          Opus40
                          hi,
                          thanks I did some reading my self and realised I needed the resistor works a treat now. thanks for the reply.
                          • O Opus40
                            hi,
                            K
                            K
                            Konrad Walsh
                            @Opus40 Great!
                            I am currently finalising a 5 in 1 sensor... just testing and so far its working fantastic
                            NuubiN 1 Reply Last reply
                            • K Konrad Walsh
                              @Opus40 Great!
                              NuubiN
                              NuubiN
                              Nuubi
                              wrote on last edited by Nuubi
                              Hum-temp-motion-light-???
                              • NuubiN Nuubi
                                K
                                K
                                Konrad Walsh
                                @Nuubi LOL.. its a secret!!!
                                and I will share my carefully guarded secret... Air quality sensor!! or in other words.. smoke and gas detector...
                                • N
                                  N
                                  NotYetRated
                                  Did you mount your PIR behind the rounded screen area on those cases? It works through that?
                                  I have yet to get to integrating PIR's in to my sensors, but do plan to, and was curious how to effectively mount them. Need to offer protection from the circuitry, but visibility to the sensor itself.
                                  • C4VetteC
                                    C4VetteC
                                    C4Vette
                                    wrote on last edited by C4Vette
                                    Question about a minor detail:
                                    Wouldn't a motionsenser trip be missed during:
                                    delay(dht.getMinimumSamplingPeriod()); ?
                                    For a DHT22 this is 2 seconds... or does the interrupt still has precedence?
                                    • C4VetteC C4Vette
                                      BulldogLowellB
                                      BulldogLowellB
                                      BulldogLowell
                                      @C4Vette you could just use a non-blocking method to read the temperature instead of the delay.
                                      The delay is method is in the library and used so that multiple reads to the sensor don't affect the reading (overheating the sensor).
                                      since SLEEP_TIME is 30s in the code above... I'd just read the temperature each time the sensor was awakened.
                                      you could just timestamp the last reading and check that at least the 2 seconds elapsed since the last reading before you take a new one (in the case that motion was detected.
                                      C4VetteC 1 Reply Last reply
                                        C4VetteC
                                        C4VetteC
                                        C4Vette
                                        @BulldogLowell
                                        Ok, thanks for explaining. I'm no programmer but trying to understand the code. So because there is also a sleep-periode, the earlier mentioned delay could be omitted? I do not fully understand how the motion interrupt is working but I replaced the 30 second sleep with a few lines using millis, as you implied so that the loop keeps on running to do other things.
                                        At the moment my sensor is a working combination of a LED-dimmer with a motion-sensor and now trying to add a DHT. This stuff is fun!
                                        Posted some photo's at http://forum.mysensors.org/topic/781/my-led-dimmer-motion-temp-hum-sensor
                                        • D
                                          Dean
                                          Nice set up!
