  3. 3-in-1 Humidity Temp and Motion
motion3 in 1temphumidity
47 Posts 28 Posters 49.1k Views 22 Watching
  • NuubiN
    NuubiN
    Nuubi
    Upper picture: a repurposed old movement alarm unit, was on sale for 2€ several years ago on a local store.
    Lower one: from dx.com (http://www.dx.com/p/wall-mount-pir-motion-detector-with-80db-alarm-siren-7-10-meter-110-degrees-15278), just swapped the internals. A bit small for my spider net constructions, though.
    • O
      O
      Opus40
      I am trying out your 3-in-1 Humidity Temp and Motion sensor with a DHT11 and get the following in the serial out put
      sensor started, id 5
      send: 5-5-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
      send: 5-5-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
      read: 0-0-5 s=255,c=3,t=6,pt=0,l=1:M
      send: 5-5-0-0 s=255,c=3,t=11,pt=0,l=15,st=ok:Humidity/Motion
      send: 5-5-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
      send: 5-5-0-0 s=0,c=0,t=7,pt=0,l=5,st=ok:1.4.1
      send: 5-5-0-0 s=1,c=0,t=6,pt=0,l=5,st=ok:1.4.1
      send: 5-5-0-0 s=2,c=0,t=1,pt=0,l=5,st=ok:1.4.1
      send: 5-5-0-0 s=2,c=1,t=16,pt=0,l=1,st=ok:1
      Failed reading temperature from DHT
      Failed reading humidity from DHT
      so the motion is working but not the temp or humidity, do I have to do some thing different in the scetch for the DHT11 over the DHT22?
      Thanks for any help.
      • K
        K
        Konrad Walsh
        Hey
        From what I just read it shouldnt matter.. you I would double check you wiring of the DHT11. Your output should be on PIN 4.. Also, have you placed the resistor on the DHT1`1
        • O
          O
          Opus40
          hi,
          thanks I did some reading my self and realised I needed the resistor works a treat now. thanks for the reply.
          K 1 Reply Last reply
          • O Opus40
            hi,
            K
            K
            Konrad Walsh
            @Opus40 Great!
            I am currently finalising a 5 in 1 sensor... just testing and so far its working fantastic
            NuubiN 1 Reply Last reply
            • K Konrad Walsh
              @Opus40 Great!
              NuubiN
              NuubiN
              Nuubi
              wrote on last edited by Nuubi
              Hum-temp-motion-light-???
              • NuubiN Nuubi
                K
                K
                Konrad Walsh
                @Nuubi LOL.. its a secret!!!
                and I will share my carefully guarded secret... Air quality sensor!! or in other words.. smoke and gas detector...
                • N
                  N
                  NotYetRated
                  Did you mount your PIR behind the rounded screen area on those cases? It works through that?
                  I have yet to get to integrating PIR's in to my sensors, but do plan to, and was curious how to effectively mount them. Need to offer protection from the circuitry, but visibility to the sensor itself.
                  • C4VetteC
                    C4VetteC
                    C4Vette
                    wrote on last edited by C4Vette
                    Question about a minor detail:
                    Wouldn't a motionsenser trip be missed during:
                    delay(dht.getMinimumSamplingPeriod()); ?
                    For a DHT22 this is 2 seconds... or does the interrupt still has precedence?
                    • C4VetteC C4Vette
                      BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      @C4Vette you could just use a non-blocking method to read the temperature instead of the delay.
                      The delay is method is in the library and used so that multiple reads to the sensor don't affect the reading (overheating the sensor).
                      since SLEEP_TIME is 30s in the code above... I'd just read the temperature each time the sensor was awakened.
                      you could just timestamp the last reading and check that at least the 2 seconds elapsed since the last reading before you take a new one (in the case that motion was detected.
                      C4VetteC 1 Reply Last reply
                        C4VetteC
                        C4VetteC
                        C4Vette
                        @BulldogLowell
                        Ok, thanks for explaining. I'm no programmer but trying to understand the code. So because there is also a sleep-periode, the earlier mentioned delay could be omitted? I do not fully understand how the motion interrupt is working but I replaced the 30 second sleep with a few lines using millis, as you implied so that the loop keeps on running to do other things.
                        At the moment my sensor is a working combination of a LED-dimmer with a motion-sensor and now trying to add a DHT. This stuff is fun!
                        Posted some photo's at http://forum.mysensors.org/topic/781/my-led-dimmer-motion-temp-hum-sensor
                        • D
                          Dean
                          Nice set up!
                          • K Konrad Walsh
                            I am wanted to share my 3-in-1 sensor in case its of use to anyone
                            Its really just a combination of what's already available
                            I used the following hardware:
                            Arduino Nano LINK - Gave me both 3.3v and 5v output without having to mess with extra hardware(steppers)
                            1 x Motion Sensor LINK
                            1 x DHT22 LINK
                            Connections is as all other guides except:
                            Motion Sensor digital to Pin D3
                            and the DHT to Pin D4
                            Here is my code
                            #define CHILD_ID_HUM 0
                            #define CHILD_ID_TEMP 1
                            #define CHILD_ID_MOT 2   // Id of the sensor child
                            DHT dht;
                            float lastTemp;
                            float lastHum;
                            boolean metric = true;
                            MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
                              gw.begin();
                              gw.sendSketchInfo("Humidity/Motion", "1.0");
                              gw.present(CHILD_ID_MOT, S_MOTION);
                              // Read digital motion value
                              Serial.println(tripped);
                              gw.send(msgMot.set(tripped?"1":"0"));  // Send tripped value to gw
                              if (isnan(temperature)) {
                                lastTemp = temperature;
                                if (!metric) {
                                Serial.print("T: ");
                              if (isnan(humidity)) {
                                  lastHum = humidity;
                                  Serial.print("H: ");
                                  Serial.println(humidity);
                              gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
                            If anyone wants more info please ask.. I will put up pictures or diagrams if needed
                            mvader
                            I'm having a problem with this build.
                            i'm using the same hardware.
                            I get nothing in the serial output screen.
                            i am able to compile and load the code.
                            when i measure on the 3.3 rail i get 3.8 (only when the radio is hooked up, i get 3.3 when nothing is hooked to the board)
                            when i measure on the 5v rail, i get 4.7v when the motion and temp sensor are hooked up.
                            I suspect my issues may be voltage related. although i'm not sure why i'm getting nothing on the serial monitor.
                            since you said you didn't need any steppers, do you have any suggestions?
                            thanks
                            • K Konrad Walsh
                              1 x DHT22 LINK
                              Here is my code
                              DHT dht;
                              float lastTemp;
                              float lastHum;
                                gw.begin();
                                  if (!metric) {
                                    lastHum = humidity;
                              Anthony Straw
                              @Konrad-Walsh my nano and pro mini on the way! double each! cant wait!! fed up all confused so have ard r3 n mega n nano n promini all tick tick!
                              • D
                                djolafritte
                                Works like a charm...
                                Thanks for sharing :)
                                • D
                                  Dylano
                                  dear all.
                                  What battery u use?
                                  And what is the battery time?
                                  Domoticz, with a lot of working hardware, include mysensors :-)
                                  OpenPLI, RuneAudio, Solarmeter, etc......
                                  Not a great builder of software and hardware, more a user...
                                  Only i try to do my best :-(
                                  • V
                                    V
                                    viableoption
                                    Looks pretty sweet. How is it working comparing to existing products with the same features?
                                    • Łukasz KostrzewaŁ
                                      Łukasz KostrzewaŁ
                                      Łukasz Kostrzewa
                                      Hi Konrad
                                      Thx for great code. It works like charm but...
                                      I have a question... It is possible to add to Your code one more (Door/Window) sensor?
                                      Mayby You can post that code on this forum?
                                      Best regards
                                      • Łukasz KostrzewaŁ
                                        Łukasz KostrzewaŁ
                                        Łukasz Kostrzewa
                                        wrote on last edited by Łukasz Kostrzewa
                                        #29
                                        Hi to all
                                        I changed a little Konrad sketch and add to 3in1 Humidity Temp and Motion one more sensor (Door\Window)
                                        Here is my code:
                                        #define CHILD_ID_DOOR 3
                                        #define BUTTON_PIN_DOOR 2
                                        Bounce debouncer = Bounce();
                                        int oldValue=-1;
                                        DHT dht;
                                        float lastTemp;
                                        float lastHum;
                                        MyMessage msgDoor(CHILD_ID_DOOR,V_TRIPPED);
                                        gw.begin();
                                        pinMode(BUTTON_PIN_DOOR,INPUT);
                                        digitalWrite(BUTTON_PIN_DOOR,HIGH);
                                        debouncer.attach(BUTTON_PIN_DOOR);
                                        debouncer.interval(5);
                                        gw.sendSketchInfo("4in1", "1.0");
                                        gw.present(CHILD_ID_DOOR, S_DOOR);
                                        if (!metric) {
                                        lastHum = humidity;
                                        debouncer.update();
                                        // Get the update value
                                        int value = debouncer.read();
                                        if (value != oldValue) {
                                        // Send in the new value
                                        gw.send(msgDoor.set(value==HIGH ? 1 : 0));
                                        oldValue = value;
                                        //gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
                                        Now it is 4in1 :)
                                        • Łukasz KostrzewaŁ
                                          Łukasz KostrzewaŁ
                                          Łukasz Kostrzewa
