  3. 3-in-1 Humidity Temp and Motion
motion3 in 1temphumidity
47 Posts 28 Posters 49.1k Views 22 Watching
  • C
    C
    chilump
    Very cool. Could you list the hardware you used for this project?
    K 1 Reply Last reply
    • C chilump
      K
      K
      Konrad Walsh
      wrote on last edited by Konrad Walsh
      @chilump
      Yes of course... I'll update the original post shortly..
      EDIT: UPDATED
      • AtomicGrogA
        AtomicGrogA
        AtomicGrog
        Interested in how you will package this? will the recorded temp be affected by the duino if it's enclosed?
        • K
          K
          Konrad Walsh
          No its not affected as the temp sensor is on the outside of the case along with the motion sensor
          • bobnataleB
            bobnataleB
            bobnatale
            Do you have a picture of it in the case? Pictures rule =)
            • NuubiN
              NuubiN
              Nuubi
              I found out quite marked difference between different setups! On the surface of the enclosure there's >3C warmer than few centimeters further from the enclosure, see pictures :-)
              First picture: temp, light level, door sensor, movement, patio PWM led lightning. DS sensor on the bottom of the enclosure
              Second: temp, light, movement
              RJ_MakeR 1 Reply Last reply
              • NuubiN Nuubi
                RJ_MakeR
                RJ_MakeR
                RJ_Make
                @Nuubi Where did you get those cases?
                RJ_Make
                • NuubiN
                  NuubiN
                  Nuubi
                  Upper picture: a repurposed old movement alarm unit, was on sale for 2€ several years ago on a local store.
                  Lower one: from dx.com (http://www.dx.com/p/wall-mount-pir-motion-detector-with-80db-alarm-siren-7-10-meter-110-degrees-15278), just swapped the internals. A bit small for my spider net constructions, though.
                  • O
                    O
                    Opus40
                    I am trying out your 3-in-1 Humidity Temp and Motion sensor with a DHT11 and get the following in the serial out put
                    sensor started, id 5
                    send: 5-5-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
                    send: 5-5-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                    read: 0-0-5 s=255,c=3,t=6,pt=0,l=1:M
                    send: 5-5-0-0 s=255,c=3,t=11,pt=0,l=15,st=ok:Humidity/Motion
                    send: 5-5-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                    send: 5-5-0-0 s=0,c=0,t=7,pt=0,l=5,st=ok:1.4.1
                    send: 5-5-0-0 s=1,c=0,t=6,pt=0,l=5,st=ok:1.4.1
                    send: 5-5-0-0 s=2,c=0,t=1,pt=0,l=5,st=ok:1.4.1
                    send: 5-5-0-0 s=2,c=1,t=16,pt=0,l=1,st=ok:1
                    Failed reading temperature from DHT
                    Failed reading humidity from DHT
                    so the motion is working but not the temp or humidity, do I have to do some thing different in the scetch for the DHT11 over the DHT22?
                    Thanks for any help.
                    • K
                      K
                      Konrad Walsh
                      Hey
                      From what I just read it shouldnt matter.. you I would double check you wiring of the DHT11. Your output should be on PIN 4.. Also, have you placed the resistor on the DHT1`1
                      • O
                        O
                        Opus40
                        hi,
                        thanks I did some reading my self and realised I needed the resistor works a treat now. thanks for the reply.
                        • O Opus40
                          hi,
                          K
                          K
                          Konrad Walsh
                          @Opus40 Great!
                          I am currently finalising a 5 in 1 sensor... just testing and so far its working fantastic
                          NuubiN 1 Reply Last reply
                          • K Konrad Walsh
                            @Opus40 Great!
                            NuubiN
                            NuubiN
                            Nuubi
                            wrote on last edited by Nuubi
                            Hum-temp-motion-light-???
                            • NuubiN Nuubi
                              K
                              K
                              Konrad Walsh
                              @Nuubi LOL.. its a secret!!!
                              and I will share my carefully guarded secret... Air quality sensor!! or in other words.. smoke and gas detector...
                              • N
                                N
                                NotYetRated
                                Did you mount your PIR behind the rounded screen area on those cases? It works through that?
                                I have yet to get to integrating PIR's in to my sensors, but do plan to, and was curious how to effectively mount them. Need to offer protection from the circuitry, but visibility to the sensor itself.
                                • C4VetteC
                                  C4VetteC
                                  C4Vette
                                  wrote on last edited by C4Vette
                                  Question about a minor detail:
                                  Wouldn't a motionsenser trip be missed during:
                                  delay(dht.getMinimumSamplingPeriod()); ?
                                  For a DHT22 this is 2 seconds... or does the interrupt still has precedence?
                                  • C4VetteC C4Vette
                                    BulldogLowellB
                                    BulldogLowellB
                                    BulldogLowell
                                    @C4Vette you could just use a non-blocking method to read the temperature instead of the delay.
                                    The delay is method is in the library and used so that multiple reads to the sensor don't affect the reading (overheating the sensor).
                                    since SLEEP_TIME is 30s in the code above... I'd just read the temperature each time the sensor was awakened.
                                    you could just timestamp the last reading and check that at least the 2 seconds elapsed since the last reading before you take a new one (in the case that motion was detected.
                                    C4VetteC 1 Reply Last reply
                                      C4VetteC
                                      C4VetteC
                                      C4Vette
                                      @BulldogLowell
                                      Ok, thanks for explaining. I'm no programmer but trying to understand the code. So because there is also a sleep-periode, the earlier mentioned delay could be omitted? I do not fully understand how the motion interrupt is working but I replaced the 30 second sleep with a few lines using millis, as you implied so that the loop keeps on running to do other things.
                                      At the moment my sensor is a working combination of a LED-dimmer with a motion-sensor and now trying to add a DHT. This stuff is fun!
                                      Posted some photo's at http://forum.mysensors.org/topic/781/my-led-dimmer-motion-temp-hum-sensor
                                      • D
                                        Dean
                                        Nice set up!
                                        • K Konrad Walsh
                                          I am wanted to share my 3-in-1 sensor in case its of use to anyone
                                          Its really just a combination of what's already available
                                          I used the following hardware:
                                          Arduino Nano LINK - Gave me both 3.3v and 5v output without having to mess with extra hardware(steppers)
                                          1 x Motion Sensor LINK
                                          1 x DHT22 LINK
                                          Connections is as all other guides except:
                                          Motion Sensor digital to Pin D3
                                          and the DHT to Pin D4
                                          Here is my code
                                          #define CHILD_ID_HUM 0
                                          #define CHILD_ID_TEMP 1
                                          #define CHILD_ID_MOT 2   // Id of the sensor child
                                          DHT dht;
                                          float lastTemp;
                                          float lastHum;
                                          boolean metric = true;
                                          MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
                                            gw.begin();
                                            gw.sendSketchInfo("Humidity/Motion", "1.0");
                                            gw.present(CHILD_ID_MOT, S_MOTION);
                                            // Read digital motion value
                                            Serial.println(tripped);
                                            gw.send(msgMot.set(tripped?"1":"0"));  // Send tripped value to gw
                                            if (isnan(temperature)) {
                                              lastTemp = temperature;
                                              if (!metric) {
                                              Serial.print("T: ");
                                            if (isnan(humidity)) {
                                                lastHum = humidity;
                                                Serial.print("H: ");
                                                Serial.println(humidity);
                                            gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
                                          If anyone wants more info please ask.. I will put up pictures or diagrams if needed
                                          mvader
                                          I'm having a problem with this build.
                                          i'm using the same hardware.
                                          I get nothing in the serial output screen.
                                          i am able to compile and load the code.
                                          when i measure on the 3.3 rail i get 3.8 (only when the radio is hooked up, i get 3.3 when nothing is hooked to the board)
                                          when i measure on the 5v rail, i get 4.7v when the motion and temp sensor are hooked up.
                                          I suspect my issues may be voltage related. although i'm not sure why i'm getting nothing on the serial monitor.
                                          since you said you didn't need any steppers, do you have any suggestions?
                                          thanks
