  2. Announcements
  3. 💬 FOTA (Wireless Programming)
wirelessupdateover the airsensebenderfotafirmware over the airwireless programming
130 Posts 46 Posters 81.8k Views 44 Watching
    wrote on last edited by hek
    This thread contains comments for the article "FOTA (Wireless Programming)" posted on MySensors.org.
    • xydixX
      xydixX
      xydix
      Is it possible to flash bootloader to a pro mini with the radio attached?
      I want OTA but have some nodes with not-so-easy-to-remove radios =)
        yes this is possible.
        • xydixX
          xydixX
          xydix
          Can i even have it powered during the process?
            that should work depending of the different voltage source. if your mini pro is 3v and also your programming tool, this is ok (but not the best advice ;) ). or keep your batt, and don't connect vcc from your programming tool. It's always better to use only one source if you're not sure and, also not sure if there are all protection .
            • xydixX
              xydixX
              xydix
              Sorry for asking stupid questions but, "USBtinyISP AVR ISP Programmer" from the shopping guide. Is this able to do the same as "usbasp (clone, USBASP 2.0 LC Technology)" in this guide.
                yes this should work
                • C
                  C
                  cdr
                  For some reason I can't set the extended fuse to 0x06, it always reverts to 0xFE;
                  avrdude.exe: verifying ...
                  avrdude.exe: WARNING: invalid value for unused bits in fuse "efuse", should be set to 1 according to datasheet
                  This behaviour is deprecated and will result in an error in future version
                  You probably want to use 0xfe instead of 0x06 (double check with your datasheet first).
                  avrdude.exe: 1 bytes of efuse verified
                  Anyone knows why?
                    @cdr
                    The Extended fuse handle the bod level. Only the 3 least significant bits are meaningful. Others are not used.
                    Be careful: This is true for this fuse, not for all fuses, check datasheet or fuses calculator!
                    That's why :
                    • 0x06 = 00000110
                    • 0xFE = 11111110
                    are doing the same job for the extended fuse. It depends of the tool you use for burning this fuse. Simply, if you get this warning, use the "equivalent".
                    • C
                      C
                      cdr
                      Thanks for the explanation, first try didn't work so I suspected the fuses, but turned out to be a voltage issue. :)
                      • starfish133S
                        starfish133S
                        starfish133
                        Is it possible to do OTA over RS485 connections?
                          Yes, it should be possible. The node doesn't really care which transport that was used.
                          • skywatchS
                            skywatchS
                            skywatch
                            Does OTA work with the NRF24L01+ modules?
                            • skywatchS skywatch
                              @skywatch yes.
                              skywatchS 1 Reply Last reply
                                @skywatch yes.
                                skywatchS
                                skywatchS
                                skywatch
                                @mfalkvidd
                                Thanks for the (very) fast reply!
                                I have arduino in my greenhouse and in winter when it can be constantly wet and cold it is a real pain to take the laptop out to make any changes. This would be a good solution that would allow me and my laptop to stay warm and dry! - - - But how do I stop any one else programming it remotely? Is there some security to stop random programs being installed (it is controlling mains electricity and I need to be sure it is a safe option.
                                tbowmoT 1 Reply Last reply
                                  @mfalkvidd
                                  tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @skywatch
                                  You can use signing to authenticate a firmware upload. Then the attacker first need to get your pre shared keys to reprogram via ota
                                  • AndurilA
                                    AndurilA
                                    Anduril
                                    @skywatch just to be complete: using signing as @tbowmo suggested only works with dualoptiboot bootloader.
                                    When using MYSBootloader it will, as far as I know, accept any firmware when booting. To attack the node the attacker would have to reboot your node (power cycle,...) and then send his own firmware. So this is possible, but needs quite a good amount of control of your systems.
                                    • AndurilA Anduril
                                      tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @Anduril
                                      @tekka have been looking at making a secure Ota boot loader, if I remember right. I thought that it was released already.
                                      But if an intruder is able to get yo your node to do a reset in order to have the mysbootloader kick in, he could just as well put a new firmware in by attaching a programmer directly to the node.
                                      • b0rmannB
                                        b0rmannB
                                        b0rmann
                                        Is it possible OTA from linux without MYSController?
                                        • skywatchS
                                          skywatchS
                                          skywatch
                                          Thank you all for the responses. If someone gets physical access then the game is over anyway. I just want to protect from some bored malicious person getting remote access and causing problems or even a fire.
                                          If it is secure from 'others' hacking it remotely I might give it a try.
