  3. 💬 In Wall AC/DC Pcb (with Relay) for MySensors (SMD)
switchin-wallrelayacdchlk-pm01
89 Posts 27 Posters 35.4k Views 29 Watching
  • sundberg84S
    sundberg84S
    I have a small update so you know this isn't dead. Still much irl to do and cant find enough time at the moment but... the 5v side with the Mysensors time aware sketch works great.
    Some small changes was made to the schematics but nothing major. Next upp is 240v av side that needshe to be tested and then the relay.
    • gusG
      gusG
      gus
      @sundberg84 yes, irl can be tough 😊
      I'll be watching your project, keep up!
      • sundberg84S
        sundberg84S
        Everything is moving along slowly... :)
        Today i tested the relay function, the AC - DC (HLK) and if everything fitted inside the 3d box.
        Found some issues with the relay... it opens ok, but I cant close it again so the relay remains open... I need to figure out (or ask) if there is something wrong with my schematics or if the relay I used was bad.
        Also I have to add some mm on the 3dbox in the holes for the relay and HLK.
        I have uploaded some images and the eaglesfiles - but I would not recommend to create any pcbs yet - im not satisfied with the result and things will change on the layout and other.
        • sundberg84S
          sundberg84S
          Updated the 3dbox with some variants...
          From left...
          Box with access to MysX Connector
          Box wthout any access to inside (except AC screw terminal)
          Box with hole for a g3mc-202 relay and no other access.
            I hope to add a stl 3d viewer soon.. starting to get a grip on three.js :).
            • vladimirV
              vladimirV
              vladimir
              Hello. Please write size of the device in the box.
              • sundberg84S
                sundberg84S
                @vladimir The PCB is 50x36 cm.
                • vladimirV
                  vladimirV
                  vladimir
                  @sundberg84 Please tell me, how you can connect a maximum output devices into an outlet controlled by the relay? As I understand it, it will not sustain even the kettle?
                  I apologize in advance for the stupid question, I'm not good at electronics.
                  • C
                    C
                    Chester
                    wrote on last edited by Chester
                    @vladimir , you are correct, in that you can only connect a load that is less than the rating of the relay's, or you can cause damage. Realistically what you would do is use this unit for lighting where the load required can be calculated and won't really change, or if you were using it for a switch, you would need to have some kind of labelling noting that it was only for a maxmium xxxW output.
                    • sundberg84S
                      sundberg84S
                      @vladimir - yep, and for protection there is a fuse.
                      Maximum for the G3MC-202PL is 2 A at 100 to 240 VAC
                      • ragflyerR
                        ragflyerR
                        ragflyer
                        Cool design! Could you post the dimensions including box and relay?
                        I understand one can update firmware through the MYSX connector?
                        • ragflyerR ragflyer
                          sundberg84S
                          sundberg84S
                          #21
                          @ragflyer - Thank you!
                          I suggest using the ISCP to update firmware. There isnt any DTR (to reset) on the MysX (this design - its coming next revision).
                          The box is 56mm wide and 43mm deep and the height is 24.6mm
                          Uncluding the SSR relay sticking out its 29mm height.
                          • fra290F
                            fra290F
                            fra290
                            Hi sundberg84,
                            what's the status of this great project? can I produce the PCB? I want use this for sopstitute my current X10 plant based on around 20 micro module.
                            only one question, I need to control light also by a traditional switch (momentary button) where a can connect the normal switch, A1 or A2 to GND is OK? in my case can be lot of distance from the node to switch, in some case more them 4 meters and the wire for control switch run in a same pipe to grid linee, can this plant create interference? what do you think to insert one optical cupolaed?
                            Thanks..
                            MArco
                            • fra290F fra290
                              Hi sundberg84,
                              Thanks..
                              MArco
                              sundberg84S
                              sundberg84S
                              @fra290 - Hi!
                              Status is that I have just received the updated new PCB and are planning to test them... but havent had the time.
                              I have updated openhardware.io with 7.1 which is the latest and the one im testing.
                              You can download the gerber or eagles files and manufacture.
                              I have also made a request for the pcbhouses to add 7.1 so you can buy them from openhardware.io
                              Its small revisions and I dont think there should be any major issues with 7.1
                              • proddyP
                                proddyP
                                proddy
                                @sundberg84 Thanks for sharing this. I'm gathering the components and plan to build it soon when the PCB v7.1 is available.
                                I do have a few questions if I may
                                • with the Relay, is it important to have one that has zero crossover? E.g the difference between getting the G3MC-202PL over a G3MC-202P
                                • what were you planning to use the 16Mhz oscillator for eventually?
                                • do you see any issues if I build the first prototype using an ESP-12 (ESP8266 with onboard Serial WiFi running at 3.3v)?
                                • proddyP proddy
                                  sundberg84S
                                  sundberg84S
                                  @Paul-Derbyshire
                                  1. It must depend on what you are planning to connect to the relay
                                  2. The oscillator is for the MCU - you can program a bootloader without it and use the internal.
                                  3. No issue - please do! Im glad i can make stuff that gets the community forward. Best of luck!
                                  proddyP 1 Reply Last reply
                                  • sundberg84S sundberg84
                                    @Paul-Derbyshire
                                    proddyP
                                    proddyP
                                    proddy
                                    It would use it to switch on and off an external mounted lamp - so with a fixed Watt & Voltage. Probably an LED 220V Lamp. Should I avoid zero-crossover as I've read somewhere that zero-crossover can cause a surge current of perhaps 10 to 40 times the steady state current when switched on.
                                    • proddyP proddy
                                      sundberg84S
                                      sundberg84S
                                      @Paul-Derbyshire - sorry, to be hones i missunderstood you.
                                      Most SSR sold for arduino are P and not PL it seems.
                                      "The light from the diode is beamed into a light-sensitive semiconductor that, in the case of zero-voltage crossover relays, conditions the control circuit to turn on the output solid-state switch at the next zero-voltage crossover. In the case of nonzero-voltage crossover relays, the output solid-state switch is turned on at the precise voltage occurring at the time."
                                      • Jose SimoesJ
                                        Jose SimoesJ
                                        Jose Simoes
                                        hi, just an idea, do you think it is possible to add a current sensor to the PCB in order to add a power meter function to the node to monitor power consumption? say up to 20A
                                        • Jose SimoesJ Jose Simoes
                                          sundberg84S
                                          sundberg84S
                                          @Jose-Simoes - no clue about current sensors... sorry I just cant answer that at the moment.
                                          Jose SimoesJ 1 Reply Last reply
