  3. 💬 In Wall AC/DC Pcb (with Relay) for MySensors (SMD)
switchin-wallrelayacdchlk-pm01
89 Posts 27 Posters 35.4k Views 29 Watching
    I hope to add a stl 3d viewer soon.. starting to get a grip on three.js :).
    • vladimirV
      vladimirV
      vladimir
      Hello. Please write size of the device in the box.
      • sundberg84S
        sundberg84S
        @vladimir The PCB is 50x36 cm.
        • vladimirV
          vladimirV
          vladimir
          @sundberg84 Please tell me, how you can connect a maximum output devices into an outlet controlled by the relay? As I understand it, it will not sustain even the kettle?
          I apologize in advance for the stupid question, I'm not good at electronics.
          • C
            C
            Chester
            wrote on last edited by Chester
            @vladimir , you are correct, in that you can only connect a load that is less than the rating of the relay's, or you can cause damage. Realistically what you would do is use this unit for lighting where the load required can be calculated and won't really change, or if you were using it for a switch, you would need to have some kind of labelling noting that it was only for a maxmium xxxW output.
            • sundberg84S
              sundberg84S
              @vladimir - yep, and for protection there is a fuse.
              Maximum for the G3MC-202PL is 2 A at 100 to 240 VAC
              • ragflyerR
                ragflyerR
                ragflyer
                Cool design! Could you post the dimensions including box and relay?
                I understand one can update firmware through the MYSX connector?
                • ragflyerR ragflyer
                  sundberg84S
                  sundberg84S
                  #21
                  @ragflyer - Thank you!
                  I suggest using the ISCP to update firmware. There isnt any DTR (to reset) on the MysX (this design - its coming next revision).
                  The box is 56mm wide and 43mm deep and the height is 24.6mm
                  Uncluding the SSR relay sticking out its 29mm height.
                  • fra290F
                    fra290F
                    fra290
                    Hi sundberg84,
                    what's the status of this great project? can I produce the PCB? I want use this for sopstitute my current X10 plant based on around 20 micro module.
                    only one question, I need to control light also by a traditional switch (momentary button) where a can connect the normal switch, A1 or A2 to GND is OK? in my case can be lot of distance from the node to switch, in some case more them 4 meters and the wire for control switch run in a same pipe to grid linee, can this plant create interference? what do you think to insert one optical cupolaed?
                    Thanks..
                    MArco
                    • fra290F fra290
                      Hi sundberg84,
                      Thanks..
                      MArco
                      sundberg84S
                      sundberg84S
                      @fra290 - Hi!
                      Status is that I have just received the updated new PCB and are planning to test them... but havent had the time.
                      I have updated openhardware.io with 7.1 which is the latest and the one im testing.
                      You can download the gerber or eagles files and manufacture.
                      I have also made a request for the pcbhouses to add 7.1 so you can buy them from openhardware.io
                      Its small revisions and I dont think there should be any major issues with 7.1
                      • proddyP
                        proddyP
                        proddy
                        @sundberg84 Thanks for sharing this. I'm gathering the components and plan to build it soon when the PCB v7.1 is available.
                        I do have a few questions if I may
                        • with the Relay, is it important to have one that has zero crossover? E.g the difference between getting the G3MC-202PL over a G3MC-202P
                        • what were you planning to use the 16Mhz oscillator for eventually?
                        • do you see any issues if I build the first prototype using an ESP-12 (ESP8266 with onboard Serial WiFi running at 3.3v)?
                        • proddyP proddy
                          sundberg84S
                          sundberg84S
                          @Paul-Derbyshire
                          1. It must depend on what you are planning to connect to the relay
                          2. The oscillator is for the MCU - you can program a bootloader without it and use the internal.
                          3. No issue - please do! Im glad i can make stuff that gets the community forward. Best of luck!
                          proddyP 1 Reply Last reply
                          • sundberg84S sundberg84
                            @Paul-Derbyshire
                            proddyP
                            proddyP
                            proddy
                            It would use it to switch on and off an external mounted lamp - so with a fixed Watt & Voltage. Probably an LED 220V Lamp. Should I avoid zero-crossover as I've read somewhere that zero-crossover can cause a surge current of perhaps 10 to 40 times the steady state current when switched on.
                            • proddyP proddy
                              sundberg84S
                              sundberg84S
                              @Paul-Derbyshire - sorry, to be hones i missunderstood you.
                              Most SSR sold for arduino are P and not PL it seems.
                              "The light from the diode is beamed into a light-sensitive semiconductor that, in the case of zero-voltage crossover relays, conditions the control circuit to turn on the output solid-state switch at the next zero-voltage crossover. In the case of nonzero-voltage crossover relays, the output solid-state switch is turned on at the precise voltage occurring at the time."
                              • Jose SimoesJ
                                Jose SimoesJ
                                Jose Simoes
                                hi, just an idea, do you think it is possible to add a current sensor to the PCB in order to add a power meter function to the node to monitor power consumption? say up to 20A
                                • Jose SimoesJ Jose Simoes
                                  sundberg84S
                                  sundberg84S
                                  @Jose-Simoes - no clue about current sensors... sorry I just cant answer that at the moment.
                                  Jose SimoesJ 1 Reply Last reply
                                  • Jose SimoesJ
                                    Jose SimoesJ
                                    Jose Simoes
                                      Jose SimoesJ
                                      Jose SimoesJ
                                      Jose Simoes
                                      @sundberg84 -hey, i was meaning something like the ACS712 Module, but add the ic to the PCB for better integration.
                                        sundberg84S
                                        sundberg84S
                                        @Jose-Simoes said in 💬 In Wall AC/DC Pcb (with Relay) for MySensors (SMD):
                                        ACS712
                                        Well, to safe space and meet my goal to be able to have it so small so it fits inside a wallsocket i have excluded all sensors and included the MysX connector. This way every user can add their own sensor.
                                        • J
                                          J
                                          Justas
                                          Hi, @sundberg84
                                          I'm really interested in this module. Maybe stupid question, but I'm very new with openhardware and would like to understand: if I will go and buy through the link provided (10xPCB for 15$), will I receive already assembled unit with all the parts, or I have to go and buy parts and assemble it myself?
                                          Thanks & Regards
                                          tonnerre33T gohanG 2 Replies Last reply
