  3. Not seeing child id 0 Humidity from DHT
3 Posts 2 Posters 1.3k Views 2 Watching
  • derksuhD Offline
    derksuhD Offline
    derksuh
    Hello all,
    i made myself a sketch and uploaded it to a arduino nano.
    I'm using pimatic and can find the temperature and the relay but i don't see the humidity.
    This is the sketch.
    #define NODE_ID 5 // ID of node
    //child ids
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_VLIGHT0 2
    //pin definitions
    #define RELAY_PIN0 4
    //relay state
    #define RELAY_ON 0
    #define RELAY_OFF 1
    #define NUMBER_OF_RELAYS 1
    //sleep timer settings
    unsigned long SLEEP_TIME = 1000; // Sleep time var, first read is 0
    unsigned long SLEEP_TIME_POST = 60000; // Sleep time var changes to this value after
    unsigned long LAST_SLEEP_TIME = millis(); // Sleep time between reads (in milliseconds)
    bool state;
    //mysensors setup
    MyMessage msgLSW0(CHILD_ID_VLIGHT0, V_LIGHT);
    //dht setup
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    digitalWrite(RELAY_PIN0, RELAY_OFF);
    pinMode(RELAY_PIN0, OUTPUT);
    // mysensor startup and Send the Sketch Version Information to the Gateway
    gw.begin(incomingMessage, NODE_ID, true);
    gw.sendSketchInfo("DHT&relay&button", "1.1");
    gw.present(CHILD_ID_VLIGHT0, S_LIGHT);
    delay(1000);
    state = gw.loadState(CHILD_ID_VLIGHT0);
    digitalWrite(RELAY_PIN0, state?RELAY_ON:RELAY_OFF);
     if (millis() - LAST_SLEEP_TIME > SLEEP_TIME) {
    dhtupdate();
    LAST_SLEEP_TIME=millis();
    if (SLEEP_TIME < SLEEP_TIME_POST) {
    SLEEP_TIME=SLEEP_TIME_POST;
    if (message.isAck()) {
    if (message.sensor == CHILD_ID_VLIGHT0){
    // Change relay state
    digitalWrite(RELAY_PIN0, message.getBool()?RELAY_ON:RELAY_OFF);
    // Store state in eeprom
    Serial.print("Incoming change for relay1 sensor:");
    void dhtupdate() {
    if (isnan(temperature)) {
    lastTemp = temperature;
    if (!metric) {
    Serial.print("T: ");
    if (isnan(humidity)) {
    lastHum = humidity;
    Serial.print("H: ");
    Serial.println(humidity);
    • derksuhD Offline
      derksuhD Offline
      derksuh
      Fixed it! i manually added the sensor in pimatic and now it works
      • derksuhD derksuh
        @derksuh great work. Thanks for reporting back.
