  3. 💬 AC-DC double solid state relay module
hlk-pm01solid state relaylight switchlightacdc
226 Posts 67 Posters 170.7k Views 65 Watching
    You can disable this behaviour by defining:
    #define MY_TRANSPORT_DONT_CARE_MODE
    #define MY_PARENT_NODE_ID 0
    mr_constM
    mr_constM
    mr_const
    @hek
    This is a really good news, I'll give it a try to check if it works correctly with controller and when controller is lost.
      okosO
      okosO
      okos
      sorry for the ridiculous question but I have to enter into a sketch? or MyConfig.h?
        In the sketch before including MySensors.h
          mr_constM
          mr_constM
          mr_const
          @hek
          Tried it. Doesn't work. Btw, I searched all mysensors sources (2.0) and didn't find any use of a MY_TRANSPORT_DONT_CARE_MODE definition.
            Sorry, yes, It's all in the development branch:
            https://github.com/mysensors/MySensors/search?utf8=✓&q=MY_TRANSPORT_DONT_CARE_MODE
            • okosO
              okosO
              okos
              wrote on last edited by okos
              #101
              It possible implement this option in mysensors 2.0 ?
              • okosO okos
                @okos it will be included in the next release yes.
                • okosO
                  okosO
                  okos
                  #103
                  Hello.
                  I tried to upload my two boards ( arduino pro mini 8Mhz , 3,3 V ) modified sketches but returned to sketch Nca78 (with DS18B20), unfortunately, does not operate a physical switch. Sometimes phisical switch changes state in domoticz ( not every time ) but relays do not change state.
                  Switching on and switching off the lights of domoticz changes state relay without a problem.
                  What could be wrong ?
                  • L
                    L
                    ludoarchi
                    Hi
                    Does somebody can post a picture of the back side please.
                    Thinks
                    okosO 1 Reply Last reply
                    • L ludoarchi
                      Hi
                      Thinks
                      okosO
                      okosO
                      okos
                      L 1 Reply Last reply
                      • okosO okos
                        L
                        L
                        ludoarchi
                        @okos thinks !
                        • Nca78N
                          That's where the biggest problem is on this board. I think the previous revision without the DS18 is safer, here there is less than 2mm creepage/clearance between main and low voltage traces and solder points, not enough :(
                          There's also problem of mixing both main/low voltage everywhere in the board like near the NRF24.
                          • L
                            L
                            ludoarchi
                            Hi
                            Noob questions sorry !
                            1/ Can i used it with 3way switches ?
                            2/ what are the pins 7 GND and 4 for ?
                            Thinks
                            mr_constM 1 Reply Last reply
                            • L ludoarchi
                              Hi
                              Thinks
                              mr_constM
                              mr_constM
                              mr_const
                              wrote on last edited by mr_const
                              #109
                              @ludoarchi
                              7 and 4 pins are mapped to 7 and 4 in/out of an arduino module. GND is for ground. These pins could be used to manually control relay state.
                              • mr_constM mr_const
                                @ludoarchi
                                L
                                L
                                ludoarchi
                                @mr_const ok i understand ! Thinks
                                • rozpruwaczR
                                  rozpruwaczR
                                  rozpruwacz
                                  wrote on last edited by rozpruwacz
                                  #111
                                  hi, great project. I have one idea, is it possible to add current and voltage measurement ?
                                  • Sander CrombeenS
                                    Sander CrombeenS
                                    Sander Crombeen
                                    Ordered all the components for this project but now i see there are 12 v solid state relays on the list?? mine is not working, does it not need to have 5V version??
                                    • AchimA
                                      AchimA
                                      Achim
                                      one question to the SSR Relay. The Arduino works with 5V, the SSR in the BOM is a 12V type. Is this a mistake? According to the Datasheet of the relay, the 12V type has an operating range from 9,6v to 14,4V
                                      • AchimA Achim
                                        mr_constM
                                        mr_constM
                                        mr_const
                                        @Achim looks like a mistake in BOM (maybe that aliexpress listing has changed). Project uses same relay, but 5V version is needed.
                                        JonnyDev13J 1 Reply Last reply
                                        • tonnerre33T
                                          tonnerre33T
                                          tonnerre33
                                          #115
                                          Hello all,
                                          I have finished to assemble one of this board today.
                                          You can see some pictures of my board here :
                                          http://www.photorapide.com/albums/jordan/khreln/ac-dc-double-solid-state-relay-module.html
                                          If you want more pictures, ask me ;)
                                          The skecth works fine.
                                          Thx for this project.
