  3. 💬 AC-DC double solid state relay module
hlk-pm01solid state relaylight switchlightacdc
226 Posts 67 Posters 170.7k Views 65 Watching
    In the sketch before including MySensors.h
      You can disable this behaviour by defining:
      #define MY_TRANSPORT_DONT_CARE_MODE
      #define MY_PARENT_NODE_ID 0
      mr_constM
      mr_constM
      mr_const
      @hek
      Tried it. Doesn't work. Btw, I searched all mysensors sources (2.0) and didn't find any use of a MY_TRANSPORT_DONT_CARE_MODE definition.
        Sorry, yes, It's all in the development branch:
        https://github.com/mysensors/MySensors/search?utf8=✓&q=MY_TRANSPORT_DONT_CARE_MODE
        • okosO
          okosO
          okos
          wrote on last edited by okos
          #101
          It possible implement this option in mysensors 2.0 ?
          • okosO okos
            @okos it will be included in the next release yes.
            • okosO
              okosO
              okos
              #103
              Hello.
              I tried to upload my two boards ( arduino pro mini 8Mhz , 3,3 V ) modified sketches but returned to sketch Nca78 (with DS18B20), unfortunately, does not operate a physical switch. Sometimes phisical switch changes state in domoticz ( not every time ) but relays do not change state.
              Switching on and switching off the lights of domoticz changes state relay without a problem.
              What could be wrong ?
              • L
                L
                ludoarchi
                Hi
                Does somebody can post a picture of the back side please.
                Thinks
                okosO 1 Reply Last reply
                • L ludoarchi
                  Hi
                  Thinks
                  okosO
                  okosO
                  okos
                  L 1 Reply Last reply
                  • okosO okos
                    L
                    L
                    ludoarchi
                    @okos thinks !
                    • Nca78N
                      That's where the biggest problem is on this board. I think the previous revision without the DS18 is safer, here there is less than 2mm creepage/clearance between main and low voltage traces and solder points, not enough :(
                      There's also problem of mixing both main/low voltage everywhere in the board like near the NRF24.
                      • L
                        L
                        ludoarchi
                        Hi
                        Noob questions sorry !
                        1/ Can i used it with 3way switches ?
                        2/ what are the pins 7 GND and 4 for ?
                        Thinks
                        mr_constM 1 Reply Last reply
                        • L ludoarchi
                          Hi
                          Thinks
                          mr_constM
                          mr_constM
                          mr_const
                          wrote on last edited by mr_const
                          #109
                          @ludoarchi
                          7 and 4 pins are mapped to 7 and 4 in/out of an arduino module. GND is for ground. These pins could be used to manually control relay state.
                          • mr_constM mr_const
                            @ludoarchi
                            L
                            L
                            ludoarchi
                            @mr_const ok i understand ! Thinks
                            • rozpruwaczR
                              rozpruwaczR
                              rozpruwacz
                              wrote on last edited by rozpruwacz
                              #111
                              hi, great project. I have one idea, is it possible to add current and voltage measurement ?
                              • Sander CrombeenS
                                Sander CrombeenS
                                Sander Crombeen
                                Ordered all the components for this project but now i see there are 12 v solid state relays on the list?? mine is not working, does it not need to have 5V version??
                                • AchimA
                                  AchimA
                                  Achim
                                  one question to the SSR Relay. The Arduino works with 5V, the SSR in the BOM is a 12V type. Is this a mistake? According to the Datasheet of the relay, the 12V type has an operating range from 9,6v to 14,4V
                                  • AchimA Achim
                                    mr_constM
                                    mr_constM
                                    mr_const
                                    @Achim looks like a mistake in BOM (maybe that aliexpress listing has changed). Project uses same relay, but 5V version is needed.
                                    JonnyDev13J 1 Reply Last reply
                                    • tonnerre33T
                                      tonnerre33T
                                      tonnerre33
                                      #115
                                      Hello all,
                                      I have finished to assemble one of this board today.
                                      You can see some pictures of my board here :
                                      http://www.photorapide.com/albums/jordan/khreln/ac-dc-double-solid-state-relay-module.html
                                      If you want more pictures, ask me ;)
                                      The skecth works fine.
                                      Thx for this project.
                                      • tonnerre33T tonnerre33
                                        Hello all,
                                        okosO
                                        okosO
                                        okos
                                        #116
                                        @tonnerre33
                                        Avesome photogallery :smile:
                                        whose sketch you used? because I have a problem with phisycal switches if I use sketch of Nca78 (I wrote about this earlier)
                                        Nca78N 1 Reply Last reply
                                        • tonnerre33T
                                          tonnerre33T
                                          tonnerre33
                                          I used the sketch of Nca78 (2 months ago) but i only command relays from jeedom.
                                          I didn't test physical switch change because i don't have neutral wire in my switch box :(
