  3. Lua script
Lua script
12 Posts 4 Posters 6.5k Views 4 Watching
  • D Offline
    Dragon
    wrote on last edited by Dragon
    I have made a simple lua script to count pellet and show this on a virtuell counter in Domoticz. The problem is that the counter dont shows decimals. Can anyone tell me if it is some more i have to write in the script. Here it is
    counter = otherdevices_svalues['Counter']
    counter = tonumber(counter)
    commandArray = {}
    if
    devicechanged['Pellets'] == 'On'
    then
    counter = counter + 0.015
    commandArray['UpdateDevice'] = 82 .. '|0|' .. tostring(counter)
    end
    return commandArray
    F 1 Reply Last reply
    • B Offline
      B Offline
      blacey
      Try string.format("%.3f", counter)
      For example: commandArray['UpdateDevice'] = 82 .. '|0|' .. string.format("%.3f", counter)
      • D Offline
        Dragon
        Thanks but that didnt help.
        B 1 Reply Last reply
        • D Dragon
          B Offline
          B Offline
          blacey
          wrote on last edited by blacey
          @Dragon I must have misunderstood what you are trying to accomplish. In lua 5.1.5, here is the result for what I thought you were trying to accomplish.
          Perhaps you should print(commandArray['UpdateDevice']) after you set it to confirm the value at that point. If the value of commandArray contains the string with decimals, as I suspect it will, then it must be something else or a Domoticoz issue. I also believe that tostring(counter) will include the decimals; the advantage of string.format() is that you can control the format of the resulting string...
          • D Offline
            Dragon
            I can try explain more how i made it. Sorry for my bad English, on my pellet boiler i have a switch that sends on to domoticz every turn with is 15 gram pellet. In domoticz is the switch called Pellets. Then i made a viruell counter in domoticz with name Counter. I want the lua script to + 0.015 to every turn the boiler do to Count how mutch pellet it use. It works now but shows without decimals like 2kg, 3kg and so. I can have so but it would be fun to se more exact weight.
            • F Offline
              F Offline
              flopp
              What is your Device in DZ?
              I guess it is a Dummy but is it a general counter, switch etc?
              D 1 Reply Last reply
              • D Dragon
                commandArray = {}
                if
                then
                end
                return commandArray
                F Offline
                F Offline
                flopp
                wrote on last edited by flopp
                print(counter)
                print(counter)
                commandArray = {}
                if
                then
                print(counter)
                end
                return commandArray
                put print after each change you do with counter to see what actually happen with your values, as @blacey wrote
                • A Offline
                  A Offline
                  Affe
                  Interesting projects
                  I'm looking to create a counter that counts the number of times the temperature reaches above 30 degrees.
                  Intend to use it when I bonfires
                  Have you learned LUA on the internet?
                  • F flopp
                    Dragon
                    @flopp In DZ the counter is incremental but i tried general to.
                    • F flopp
                      print(counter)
                      print(counter)
                      commandArray = {}
                      if
                      then
                      print(counter)
                      end
                      return commandArray
                      Dragon
                      @flopp When i put in print(counter) it shows with decimals in the logg but the counter doesnt
                      • A Affe
                        Dragon
                        @Affe I can not lua :smiley: i read on lua pages on internet and experiment
                        • F Offline
                          F Offline
                          flopp
                          This my script with decimals
                          commandArray = {}
                          if devicechanged['Panna_V'] or devicechanged['Huset_V'] then
                              local panna_v = otherdevices_svalues["Panna_V"]
                              local huset_v = otherdevices_svalues["Huset_V"]
                              local hushall_kwh = uservariables['Hushåll_kWh']
                              local huset_kwh = uservariables['Huset_kWh']
                              local panna_kwh = uservariables['Panna_kWh']
                              local panna, energy, huset, energy2
                              --print(pan)
                              --print(hus)
                              _,_,panna, energy = string.find(panna_v, "(.+);(.+)")
                              _,_,huset, energy2 = string.find(huset_v, "(.+);(.+)")
                              --print(panna)
                              --print(huset)
                              --print(energy)
                              --print ("energy2="..energy2)
                              --print ("huset_kwh="..huset_kwh)
                              husetdiff_kwh = energy2 - huset_kwh
                              --print ("husetdiff kwh")
                              --print (husetdiff_kwh)
                              --print ("energy="..energy)
                              --print ("panna_kwh="..panna_kwh)
                              pannadiff_kwh = energy - panna_kwh
                              --print ("pannadiff kwh")
                              --print (pannadiff_kwh)
                              hushal_kwh = husetdiff_kwh - pannadiff_kwh
                              hushall_kwh = hushall_kwh + hushal_kwh
                              --print ("hushåll_kwh")
                              --print (hushall_kwh)
                              panna = tonumber(panna)
                              huset = tonumber(huset)
                              hush = huset - panna
                              ener = energy2 - energy
                              --print(hush)
                              --print(ener)
                              if hush > 0 then
                                  --print(el)
                                  commandArray['Variable:Hushåll_kWh']= tostring(hushall_kwh)
                                  commandArray['Variable:Huset_kWh']= tostring(energy2)
                                  commandArray['Variable:Panna_kWh']= tostring(energy)
                                  abc = tostring(hush)
                                  def = tostring(hushall_kwh)
                                  commandArray['UpdateDevice'] = '272|0|'..abc..';'..def..''
                              end
                          end
                          return commandArray
                          I am using Dummy, Electric(Instant&Counter) version 3.5721 of DZ
                          Panna_V(heating system) and Huset_V(whole house) is electric usage meters that report every 5 minute. I use my Dummy to show my electric consumption without(minus) my heating system
