  3. 💬 AC-DC double solid state relay module
hlk-pm01solid state relaylight switchlightacdc
226 Posts 67 Posters 170.5k Views 65 Watching
  • laster13L
    laster13L
    laster13
    @tonnerre33, je suis également en France et je n'ai pas de neutre dans mes interrupteurs. Peux tu me dire comment tu as pu tester le pcb stp. Mon anglais est loin d être top desolé !!
    • Nca78N Nca78
      @JonnyDev13 said:
      @mr_const said:
      ybe that aliexpress listing has changed). Project uses same relay, but 5V version
      Uggh, I just received 20 of the 12v ones yesterday that I purchased from the BOM link. Is it safe to say that these will absolutely not work, or is there some way to adapt them with a step-up converter or something?
      You cannot adapt them with a step-up converter, there's no space on the PCB for that. But you should test them with 5V, if you are lucky they might work. I'm using 5V relays with 3.3V without any problem. The "must switch off" value in datasheet (for the original, remember what you bought is a clone...) is 0.9V which should be ok (real switch off value will probably be closer to this than to 5V) but the "must switch on" value is 8.4V which is quite far away from the 5V. The only way you will know if it will reliably switch one with 5V is to give it a try.
      @okos said:
      Hello.
      I tried to upload my two boards ( arduino pro mini 8Mhz , 3,3 V ) modified sketches but returned to sketch Nca78 (with DS18B20), unfortunately, does not operate a physical switch. Sometimes phisical switch changes state in domoticz ( not every time ) but relays do not change state.
      Switching on and switching off the lights of domoticz changes state relay without a problem.
      What could be wrong ?
      Sorry I'm a bit short on free time at the moment, didn't have time to take a look at the sketch yet.
      What you are saying is sometimes you change the physical switch position, it changes the status in domoticz, but the light status is not matching the status of the physical switch and the value of the switch in Domoticz ?
      For example: light is off and domoticz says off. Then you push the switch and domoticz says the light is on. But in fact the light is still off ?
      JonnyDev13J
      JonnyDev13J
      JonnyDev13
      @Nca78 Thanks for your thoughts. I will try testing it with 5v and see what happens.
      • laster13L laster13
        tonnerre33T
        tonnerre33T
        tonnerre33
        #137
        @laster13 hi, i have tried this pcb with my bedroom lamp. Indeed, these lamps are powered by electrical socket which include neutral wire.
        For the others lamps, i need to find how to command them without neutral wire ;)
        I am looking at this project but this is an smd project :
        https://www.openhardware.io/view/249/MDMSNode-Lighting
        @laster13 salut, en fait mes lampes de chambres sont sur prises commandées (donc accès au neutre), du coup j'utilise ce module pour ces lampes mais pour les autres bin il va falloir que je trouve autre chose ;)
        Je regarde un peu du coté de ce projet mais c'est du cms : voir le lien au dessus
          wrote on last edited by hek
          #138
          @laster13
          English please...
          • laster13L
            laster13L
            laster13
            I Will tried to speak english 😗.
            Thanks tonnerre33 for your help. Could you give me à shema of your installation in the bedroom ?
              tonnerre33T
              tonnerre33T
              tonnerre33
              #140
              @laster13
              Here is a schema of my installation without the node :
              http://electric.system.free.fr/schemas/schemas/schema-prise-commandee.jpg
              and one with the pcb :
              http://www.photorapide.com/images.php?photoName=2whnu7.png&photoId=935027
              Edit : and the node with connectors :
              http://www.photorapide.com/images.php?photoName=074tl3.jpg&photoId=935034
              • laster13L
                laster13L
                laster13
                thanks, I'll try. You say that your lamps are powered by electrical socket .
                Is mounting possible on simple sockets with neutral wire? (non commandées)?
                • tonnerre33T
                  tonnerre33T
                  tonnerre33
                  #142
                  Sure you can use an electrical socket without switch control.
                  But caution, max current is 2A ! It is ok for lamps but you can't supply a receiver which consumes more than 460VA per relay ( = 460W for resistive receiver).
                  I didn't see protection for relays, be careful ;)
                  • laster13L
                    laster13L
                    laster13
                    I am trying to test a montage which I am not sure about and besides when I plug the pcb on the socket the lamp remains on. I invite you to read my post on the Domoticz forum.
                    http://easydomoticz.com/forum/viewtopic.php?f=20&t=2680&p=25219#p25219
                    I am sorry for my english, I use the traducer of google
                    • Richard_SkeR
                      Richard_SkeR
                      Richard_Ske
                      Hi All,
                      This is my first post on this site!!
                      Yes this is a really good project but for the UK controlling a light inside of a wall switch you would need to do the following.
                      Re-wire the ceiling rose as in the UK there is a live feed from the rose that is switched by the switch and then returns to the rose to the "switched live" See http://www.diydoctor.org.uk/project_images/lights_and_switches/ceilingroseb2.jpg
                      Put an extra cable up to the ceiling rose with the return cable from the board that goes to the switched live and add an extra terminal in the ceiling rose to link the neutral to the other side of the lamp fitting.
                      If the back box is metal, it would need to be changed to a plastic box , I wouldn't myself want to mount the board in an earthed metal box!!
                      As other contributors have noted there isn't any fusing on the live and neutral feeds if the SSR were to fail short because of a short circuit in the lamp or ceiling rose then there could be a large current going through board that could potentially cause a fire, safety is always the first thought with any mains electrical circuit.
                      I could see this board being used in a plastic box inline to a table lamp etc. but it would need a lot of work to re-wire your house if you intended to use it behind a wall switch.
                        tonnerre33T
                        tonnerre33T
                        tonnerre33
                        @laster13 Yes your schema is correct.
                        The sketch has been modified by Nca78, you can try it first.
                        The problem does not come from the unused switch, because i use this node without switch.
                        • E
                          E
                          Eawo
                          I'm going to do these for my light switches but what should I use for in wall on off switch without relay?
                          • HilltanH
                            HilltanH
                            Hilltan
                            The link to to DirtyPCBs is broken, got a new one?
                            • HilltanH Hilltan
                              tonnerre33T
                              tonnerre33T
                              tonnerre33
                              @Hilltan Hello, i think this link will be ok : http://dirtypcbs.com/store/details/885/mysensors-v3-3-2-light-switch
                              For information, a few members have too many PCB of this node that's why if you are living in Vietnam or asia, Nca78 can send you PCB and if you are in france, i can send too (contact by pm for terms).
                              I use this node since 20 days ago, and it's working well ;)
                              • johnym30J
                                johnym30J
                                johnym30
                                Hi everyone.
                                I can not find anywhere Slow Blow Fuse (250v 0.2A). Does anyone has an available link??
                                Thanks in advance.
                                • johnym30J
                                  johnym30J
                                  johnym30
                                  Never mind, got them. thank you!!!
                                  • laster13L
                                    laster13L
                                    laster13
                                    @tonnerre33
                                    I will be really interested to buy you all the components you would no longer need. NRF, pcb, fuse thermal ... If you agree, can you tell me a list of what you offer thanks
                                    • C
                                      C
                                      chickey
                                      If anyone in the UK is after boards/parts i have spares.
                                      • Rodolfo VieiraR
                                        Rodolfo VieiraR
                                        Rodolfo Vieira
                                        hello, anyone use this project with home assistant?
                                        • proddyP
                                          proddyP
                                          proddy
                                          Thanks for this. One question about the SSR. Does it matter if its a zero crossing relay or not if just switching lamps with fixed amps? That the difference between the G3MB-202P and G3MB-202PL. I'm not sure which to get.
                                          Nca78N 1 Reply Last reply
