  2. Announcements
  3. 💬 Battery Powered Sensors
battery
347 Posts 55 Posters 226.9k Views 53 Watching
  • N Nicklas Starkel
    Good article/site on why Alkaline is the best way to go for Mysensors nodes :)
    http://batteryuniversity.com/learn/article/elevating_self_discharge
    AWIA
    AWIA
    AWI
    @Nicklas-Starkel The article mostly talks about rechargeable batteries. I prefer non rechargeable Lithium batteries (like coin cells) for their energy density and very low self discharge.
    My major concern with (cheap) alkaline batteries is their leakage of aggressive chemicals. I had to trash my first nodes because of this :unamused:
    N tonnerre33T 2 Replies Last reply
    • AWIA AWI
      N
      N
      Nicklas Starkel
      @AWI in the first part it states:
      "Primary cells such as lithium-metal and alkaline retain the stored energy best, and can be kept in storage for several years."
      So you are correct and between Alkaline and Lithium-metal maybe the latter would be best. :)
      I have no experience with coin cells and will do some testing with them as soon as I can.
      Since this is the battery article, would you please tell me what you use and how you use it. What you expected and if the batteries lived up to your expectations. Would be cool to know as you've had more experience then me (and many like me)!
      AWIA 1 Reply Last reply
      • AWIA AWI
        tonnerre33T
        tonnerre33T
        tonnerre33
        @AWI I'm agree with you but coin cells have less capacity. The difference of the self discharge between coin cells and alkaline is not important (1% vs 2%), but the capacity and size are.
        Here is a link with the Battery self-discharge rates :
        http://www.gammon.com.au/power
        • N Nicklas Starkel
          AWIA
          AWIA
          AWI
          @Nicklas-Starkel I mostly use a 'large' version lithium cell i.e. Cr123. These were used large in compact camera's and have a huge capacity and very little self discharge. My best example is the sensor in the fridge which measure temp and humidity every 10 secs and sends with nrf24l01 (MySensors of course). This one runs for almost two years now and has a stable 3.02V since the second month.
          The coin cells need special care a these have a high 'internal resistance'. You need to be careful with designing the sketch so that the load is as short and light as possible.
          There are some of my postings on this site which elaborate on the subject. (I'm on a mobile phone right now...)
          N 1 Reply Last reply
          • AWIA AWI
            N
            N
            Nicklas Starkel
            @AWI OMG there is so many options when you look at it!
            I think it all boils down to design (size) or money.
            Normal AA roughly 0.3EUR/pc are quite large but OK power but cheap
            CR123 roughly 2.5EUR/pc are quite small and OK power but expensive
            Coin cell roughly 1EUR/pc and they are the smallest but not packing a good punch while being semi cheap/expensive.
            Obviously I have to build one node with each and put them in flowerpots around the flat to see in in action :)
            And to top it off, I know there is a company in USA that has created a new battery that will double 'Ah' in same size batteries. They should launch this month i think, but think they will go for cellphone makers in the beginning.
            parachutesjP 1 Reply Last reply
            • N Nicklas Starkel
              parachutesjP
              parachutesjP
              parachutesj
              I am not getting it...
              I have a 3.3V Pro Mini, it is connected to my table power supply and want it to be powered by a coin cell later. To test the VCC lib, I set
              const float VccExpected   = 3.21;
              What do I need to put here?
              const float VccCorrection = 3.21/3.21;
              It always returns BatteryPercentage of 2 or 3% seems the function is not calculating right. Anyhow I saw there is another function to call Read_Volts()
              float volts = (float)vcc.Read_Volts();
              int myPerc = volts *100 / VccExpected;
              So "myPerc" returns a value of 98% which seems feasible, also when reducing Voltage it drops.
              But still, not getting the values with the build in function read_Perc()
              • Moebius LutchingM
                Moebius LutchingM
                Moebius Lutching
                I'm building my home automation with a few Whisper Nodes (https://talk2.wisen.com.au/product-talk2-whisper-node-avr/) and I just got them working with the MySensor code. I'm running most of my projects with two AA but I just setup one with a CR2032 transmitting my attic temperature every 5 minutes to see how it goes. One thing I discovered is that the board comes two "built-in" resistor divider to monitor the battery and power supply voltage, which is pretty handy... also they have added a Mosfet on the battery voltage divider, I guess to eliminate the constant current leak consumed by the voltage divider, am I right?! (https://bitbucket.org/talk2/whisper-node-avr/overview#markdown-header-voltage-monitor)
                • bjacobtB bjacobt
                  I'm sorry what do you mean by "control your resistance value"
                  this is my circuit,
                  1M resistor to +V rail, 470K resistor to GND and middle point to A0.
                  0_1478097209731_IMG_1543.JPG ,
                  GertSandersG
                  GertSandersG
                  GertSanders
                  @bjacobt
                  It seems you are missing the capacitors connecting each side of the crystal to ground. Those should be between 15 and 25pf (depends on the crystal), normally ceramic type.
                  • GertSandersG GertSanders
                    Here is a view of a node running exactly 1year. The effect of a bad radio is seen here as the fast voltage drops. I had a very low charged battery to start with, replaced it with new batteries which also discharged fast, and replaced both batteries and the radio. Since mid january 2016 the node has been running as expected. My guess is that this combo will run for 2 years (given how it has been working the past 9 months).
                    This node measures battery voltage, temperature and humidity and sends 3 messages about every 5 minutes.
                    And here is the battery measurement of the second node that went "online" the same day (18/sep/2015, with a good radio, and similarly used batteries from the start). This node sends very few messages (at least 1 every 24 hours, and when one of 3 contacts are opened). Most days it just sends 1 message.
                    So even with batteries already at a low level, you can make useful nodes using the MySensors setup :-)
                    C
                    C
                    chaeron
                    @GertSanders
                    How are you sending the voltage?
                    Sensor = S_MULTIMETER and value = V_VOLTAGE in a normal message?
                    Thx!
                    • C chaeron
                      @GertSanders
                      Thx!
                      GertSandersG
                      GertSandersG
                      GertSanders
                      @chaeron
                      Correct :-)
                      C 1 Reply Last reply
                        @chaeron
                        Correct :-)
                        C
                        C
                        chaeron
                        @GertSanders
                        Thanks! I'll use that approach for all my house sensors, since right now all I send is battery percentage..
                        ...at least until/if they add support for a I_Battery_Voltage internal value. 😈
                        • meanmrgreenM
                          meanmrgreenM
                          meanmrgreen
                          Realy n00b in electronics here but do you need to use those exact values of the resistors when hooking this up?
                          • meanmrgreenM meanmrgreen
                            #60
                            @meanmrgreen are you reffering to the 470K+1M resistors? (This is a long thread)
                            If so, they can be any size but the code will need to be adjusted if the ratio between the resistors is changed.
                            Also, less resistance will drain the battery faster.
                            • meanmrgreenM
                              meanmrgreenM
                              meanmrgreen
                              Yes i do.
                              This is like going back to school... but fun!
                              • G
                                G
                                giovaFr
                                can someone explains why using analogReference(INTERNAL) ?
                                for the moment i only have 5V nano suplyed by a 7.4V lipo (i know, this is not a good choice, but i just have this right now) so with that hardware, 1.1V seems too low.
                                I mean that resistance ratio to reach 1.1V max smells a very inacurate result; isn't it?
                                • G giovaFr
                                  tonnerre33T
                                  tonnerre33T
                                  tonnerre33
                                  #63
                                  @giovaFr Hello, try to replace 470k(R2) by a 180k ;)
                                  for obtain this value i did : R2 = R1 / ( Vbatmax - Vref); R2 = 1.1^6 / (7.5 - 1.1) = 172k, i taked a normalized value = 180k.
                                  • G
                                    G
                                    giovaFr
                                    wrote on last edited by giovaFr
                                    #64
                                    I think i've finnaly understood :
                                    1.1V is not a reference like an offset it is a reference as a max readable voltage
                                    Analog Input will always return values between 0 and 1023
                                    5V / 1023 bits = 0.0048 V per bit
                                    1.1V /1023 bits = 0.001075 V per bit
                                    so with 1.1V we are allmost 5 times more accurate. Moreover it seems that 1.1V will stay stable even if battery voltage becomes low. (so understand now why using it)
                                    And that's what mfalkvidd explained : if we type in code : analogReference(INTERNAL); then voltage must never exceed 1.1V on A0 (it is different on an arduino Mega)
                                    Now to choose R1 and R2 here what i've made :
                                    A0maxV = VbattMax * (R2 / (R1+R2)
                                    for me it means
                                    1.1V = 8.4V * (R2 / (10^6 Ohms + R2)
                                    so i use R2 around 150k Ohms
                                    A0voltage = A0value * 0.001075
                                    A0Voltage = VBatt * (R2 /(R1+R2))
                                    A0Voltage = VBatt * rRatio
                                    VBatt = A0Voltage / rRatio = (A0Value *0.001075 ) /rRatio
                                    So here the magic formula:
                                    VBatt = (A0Value *0.001075 ) /rRatio
                                    Let me know if i'm wrong somewhere.
                                    • G giovaFr
                                      for me it means
                                      tonnerre33T
                                      tonnerre33T
                                      tonnerre33
                                      #65
                                      @giovaFr said in 💬 Battery Powered Sensors:
                                      A0maxV = VbattMax * (R1 / (R1+R2)
                                      Are you sure about that ? I think is A0maxV = VbattMax * (R2 / (R1+R2)
                                      R2 = 150k Ohms for 8.4V with R1 always at 1M Ohms
                                      • G
                                        G
                                        giovaFr
                                        #66
                                        oops you are right i mixed both :)
                                        i fixed my error, thanks
                                        • EfflonE
                                          EfflonE
                                          Efflon
                                          If I power my 3.3V miniPro through VCC, do I still need to remove/cut the voltage regulator?
                                          I thought the current moved from vvc-in/raw through the regulator and then to the MCU and VCC :confused: .
                                          My battery powered nodes are dying and I suspect I need to change BOD and eventually something more (LED gone )..
