  2. Announcements
  3. 💬 Battery Powered Sensors
battery
347 Posts 55 Posters 226.8k Views 53 Watching
  • GertSandersG GertSanders
    @chaeron
    Correct :-)
    C
    C
    chaeron
    @GertSanders
    Thanks! I'll use that approach for all my house sensors, since right now all I send is battery percentage..
    ...at least until/if they add support for a I_Battery_Voltage internal value. 😈
    • meanmrgreenM
      meanmrgreenM
      meanmrgreen
      Realy n00b in electronics here but do you need to use those exact values of the resistors when hooking this up?
      • meanmrgreenM meanmrgreen
        #60
        @meanmrgreen are you reffering to the 470K+1M resistors? (This is a long thread)
        If so, they can be any size but the code will need to be adjusted if the ratio between the resistors is changed.
        Also, less resistance will drain the battery faster.
        • meanmrgreenM
          meanmrgreenM
          meanmrgreen
          Yes i do.
          This is like going back to school... but fun!
          • G
            G
            giovaFr
            can someone explains why using analogReference(INTERNAL) ?
            for the moment i only have 5V nano suplyed by a 7.4V lipo (i know, this is not a good choice, but i just have this right now) so with that hardware, 1.1V seems too low.
            I mean that resistance ratio to reach 1.1V max smells a very inacurate result; isn't it?
            • G giovaFr
              tonnerre33T
              tonnerre33T
              tonnerre33
              #63
              @giovaFr Hello, try to replace 470k(R2) by a 180k ;)
              for obtain this value i did : R2 = R1 / ( Vbatmax - Vref); R2 = 1.1^6 / (7.5 - 1.1) = 172k, i taked a normalized value = 180k.
              • G
                G
                giovaFr
                wrote on last edited by giovaFr
                #64
                I think i've finnaly understood :
                1.1V is not a reference like an offset it is a reference as a max readable voltage
                Analog Input will always return values between 0 and 1023
                5V / 1023 bits = 0.0048 V per bit
                1.1V /1023 bits = 0.001075 V per bit
                so with 1.1V we are allmost 5 times more accurate. Moreover it seems that 1.1V will stay stable even if battery voltage becomes low. (so understand now why using it)
                And that's what mfalkvidd explained : if we type in code : analogReference(INTERNAL); then voltage must never exceed 1.1V on A0 (it is different on an arduino Mega)
                Now to choose R1 and R2 here what i've made :
                A0maxV = VbattMax * (R2 / (R1+R2)
                for me it means
                1.1V = 8.4V * (R2 / (10^6 Ohms + R2)
                so i use R2 around 150k Ohms
                A0voltage = A0value * 0.001075
                A0Voltage = VBatt * (R2 /(R1+R2))
                A0Voltage = VBatt * rRatio
                VBatt = A0Voltage / rRatio = (A0Value *0.001075 ) /rRatio
                So here the magic formula:
                VBatt = (A0Value *0.001075 ) /rRatio
                Let me know if i'm wrong somewhere.
                • G giovaFr
                  for me it means
                  tonnerre33T
                  tonnerre33T
                  tonnerre33
                  #65
                  @giovaFr said in 💬 Battery Powered Sensors:
                  A0maxV = VbattMax * (R1 / (R1+R2)
                  Are you sure about that ? I think is A0maxV = VbattMax * (R2 / (R1+R2)
                  R2 = 150k Ohms for 8.4V with R1 always at 1M Ohms
                  • G
                    G
                    giovaFr
                    #66
                    oops you are right i mixed both :)
                    i fixed my error, thanks
                    • EfflonE
                      EfflonE
                      Efflon
                      If I power my 3.3V miniPro through VCC, do I still need to remove/cut the voltage regulator?
                      I thought the current moved from vvc-in/raw through the regulator and then to the MCU and VCC :confused: .
                      My battery powered nodes are dying and I suspect I need to change BOD and eventually something more (LED gone )..
                      • EfflonE Efflon
                        GertSandersG
                        GertSandersG
                        GertSanders
                        @Efflon
                        VCC pin is directly connected to the MCU.
                        The RAW or IN pin is connected to the regulator input. Th eregulator output is connected to VCC pin and thus to the MCU power input pin.
                        On a 3V3 promini you can give between 3V3 and 12V (on most promini's, some can handle up to 16V) on the RAW or IN pin. The regulator on the promini will bring that down to 3V3 (which you will be able to measure on the VCC pin).
                        By giving 3V3 on the VCC pin, some power is lost via the output pin of the regulator (through the regulator) towards the GND pin of the regulator. This should be minimal, but on bad regulators it can be enough to drain a battery in weeks. So yes, I would cut the regulator output line when giving power via VCC.
                        Cutting the line of the powerLED (on either side of it, doesn't matter) will make sure that the LED does not drain the battery either. This LED can pull between 5 -15mA depending on the protection resistor that sits in series with it.
                        So VCC pin and RAW pin are NOT the same.
                        EfflonE 1 Reply Last reply
                          @Efflon
                          EfflonE
                          EfflonE
                          Efflon
                          @GertSanders Thanks for you explanation. I thought vvc on the short end next to rx was going through the voltage regulator just as RAW. Anyhow I have already de-soldered the LED's and are powering through vcc next to A3. Apparently my voltage regulators are bad so I'll cut the lines and give it a try and hope power consumption stays low.
                          • maghacM
                            maghacM
                            maghac
                            I've used the Vcc library to read the battery level without voltage divider or any other external components. Is this not a reliable way to measure?
                            • maghacM
                              maghacM
                              maghac
                              I'll answer myself - no, the Vcc lib is not realiable :) I had a sensor that died yesterday and it reported 100% battery until the end...
                              AWIA 1 Reply Last reply
                              • maghacM maghac
                                AWIA
                                AWIA
                                AWI
                                @maghac The Vcc library is reliable. It uses the internal 1.1 v reference of the MCU to measure the voltage on the Vcc pin. If your sensor keeps reporting 100% I guess you either power the arduino through a regulator (or the raw pin) or missed something in the Vcc initialisation/ calibration.
                                • maghacM
                                  maghacM
                                  maghac
                                  @AWI It's possible that I missed something in the code. I am powering the arduino directly on VCC though and I'm not using a regulator.
                                  Will have another look tonight.
                                  • A
                                    aclertant
                                    Do you think that the use of a piezo electric switch is possible ?
                                    I found one that deliver 24v and 0,2A... The goal would be to create wireless switch...
                                    AWIA gohanG 2 Replies Last reply
                                    • A aclertant
                                      AWIA
                                      AWIA
                                      AWI
                                      @aclertant Interesting idea... Energy harvesting with piezo-electric components is certainly possible. From MySensors point of view the energy (very very little) has to be stored and boosted to power the radio and mcu for message processing. There are a few examples of "harvesting" remotes (i.e. Philips HUE) but I am not sure if these use a piezo element.
                                      • H
                                        H
                                        hiddenuser
                                        I removed the both the LED and the Voltage Regulator of an Arduino pro min 3.3v . The simple sketch on it's own works fine. However when I connect an NRF24L01 it does not communicate back to the gateway.. :(
                                        • A aclertant
                                          @aclertant
                                          If you look at enocean products there are already commercial energy harversting switches in case you don't find a way to make it.
