716 Posts 111 Posters 706.2k Views 93 Watching
  • meanmrgreenM
    meanmrgreenM
    meanmrgreen
    wrote on last edited by meanmrgreen
    #273
    • meanmrgreenM
      meanmrgreenM
      meanmrgreen
      • N
        N
        N00phi
        Hi
        I've tried to order the capaciter and voltage regulator from our local electronics supplier. The choice is too big. Could anyone please help a "newbie" to select the right parts for a raw powered 5V version
        • 4.7uF capacitor
        • voltage regulator
        • 0.1 and 10uF cap
          http://www.distrelec.ch/ can't select the parts because of missing size and especially for the voltage regulator the exact type.
        • N N00phi
          Hi
          • 4.7uF capacitor
          • voltage regulator
          • 0.1 and 10uF cap
          sundberg84S
          sundberg84S
          @N00phi - I usually just select the ones at www.mysensors.org/store but if you have a specific site you wish to order from I can choose for you.
          N 1 Reply Last reply
          • sundberg84S sundberg84
            N
            N
            N00phi
            @sundberg84 It would be absolutely great if you could do so! I would order at http://www.distrelec.ch ...
            • N N00phi
              sundberg84S
              sundberg84S
              @N00phi for the capacitors: http://www.distrelec.ch/search?q=electrolytic+capacitor&filter_Rated+voltage~~VDC=50&filter_Diameter+housing~~mm=4&filter_Diameter+housing~~mm=5 (choose the axial types which is the one with two legs).
              As for the voltage regulator I use LE33ACZ 5V-3.3V which i cant find on that site.
              dbemowskD N 2 Replies Last reply
                dbemowskD
                dbemowskD
                @sundberg84 said in 💬 Easy/Newbie PCB for MySensors:
                Just for clarification, there is axial lead and radial lead components. The axial leads have both wires coming out of one side (as @sundberg84 mentions it looks like two legs). Radial leads have one wire coming out each side. I almost never use radial lead capacitors.
                  N
                  N
                  N00phi
                  wrote on last edited by N00phi
                  #280
                  @sundberg84 Thank you! One more question.. on the photo, there is a flat broun capacitor, what are the specifications for that one? Is it 0,1uF? But thats not an aluminium electrolytic capacitor, is it?
                  Oh, and the voltage regulator is available on aliexpress, found that one.
                  Nca78N 1 Reply Last reply
                  • N N00phi
                    @N00phi said in 💬 Easy/Newbie PCB for MySensors:
                    Yes it's the 0.1uF capacitor. It's a ceramic disc capacitor, but you won't have to search for the type of capacitor on aliexpress, low value capacitors are most of the time (always ?) ceramic disks if they are not of SMD type.
                    • cmrockwellC
                      cmrockwellC
                      cmrockwell
                      I would like to use this PCB with a 3.3V I2C sensor (data line and power must be <3.6V) and AC power. Is there a recommended way to accomplish this?
                      • cmrockwellC cmrockwell
                        sundberg84S
                        sundberg84S
                        @cmrockwell - Sorry, Im not following...
                        AC Power? You need some AC-DC converter then and this is not the intend of the PCB, sorry.
                        cmrockwellC 1 Reply Last reply
                          cmrockwellC
                          cmrockwellC
                          cmrockwell
                          @sundberg84
                          Sorry, I wasn't clear. I just meant running from a DC power supply, not batteries. It seems that the intended use is to have 5V Vcc when running from a power supply, but I would like a 3.3V Vcc. Thanks for your help. I have 10 of these PCBs in hand.
                          Nca78N sundberg84S 2 Replies Last reply
                            @sundberg84
                            @cmrockwell You can use a 3.3V / 8MHz pro-mini board and power everything with 3.3V.
                              @sundberg84
                              sundberg84S
                              sundberg84S
                              @cmrockwell - yes, the pcb is designed like @cmrockwell said. You can use either 3.3v or below (batteries) or a 5v regulated voltage. If you choose the 3.3v/bat version you need a 3.3v pro mini.
                                cmrockwellC
                                cmrockwellC
                                cmrockwell
                                @sundberg84
                                OK, I figured out how to do what I wanted. I am planning to connect a regulated power supply that provides ~3.3VDC. The main thing I had to figure out was how to configure the PCB when neither a battery booster nor a regulator are needed. I think either shorting the REG pin and shorting the regulator or shorting the BAT pin and shorting the battery booster would each achieve the desired result.
                                  @sundberg84
                                  sundberg84S
                                  sundberg84S
                                  @cmrockwell - well done!
                                  Yes, digging deeper into it you can probably hack it many ways with jumpers and wires.
                                    If I want to use a mini pro 3.3v and a 18650 battery that I have lying around, should I use something like THIS or do you think there is a better/more efficient way?
                                      sundberg84S
                                      sundberg84S
                                      @gohan - im not that good in efficiency in boosters and converting voltage. Im sure that would work! The main thing is 1) deliver correct voltage and 2) if they are to noicy they will interfere with the radio and make the communication fail.
                                      • P
                                        P
                                        popunonkok
                                        I having trouble to order this board from DirtyPCB.
                                        Both the link in the beginning of this thread (Rev8) and the link in the OpenHarware page just directs me to an empty DirtyPCB order page, with no board preloaded. It wants me to upload files.
                                        Does anyone know how to order from DirtyPcb without uploading the boardfiles?
                                        • P popunonkok
                                          sundberg84S
                                          sundberg84S
                                          #292
                                          @popunonkok - the link to DirtyPCB is not posted or maintained by me. If you want the latest revisions please go to order under openhardware.io = https://www.openhardware.io/order/4/PCB10X. DirtyPCB is not an option there so if you want to use them you need to download the gerberfiles for the project = https://www.openhardware.io/view/4/EasyNewbie-PCB-for-MySensors#tabs-design and upload them according to their instructions = http://dirtypcbs.com/store/pcbs/about (see order)
